Gun Shot Wound to My 23’ TRD OR.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Drew2you, Sep 27, 2024.
Thread Status:
Not open for further replies.
  1. Sep 27, 2024 at 6:56 PM
    Drew2you
    Drew2you [OP] Active Member
    23’ TRD OF
    throttle response controller
    welp only i could have this kinda thing happen and i’m really worried it has been a fatal wound to my truck with 30k mi. i’ll cut to the important things you should know to possibly ease my mind and tell me everything is gonna be ok. i mean it’s bad. the 5.56 bullet passed thru the passenger floorboard in the crease where it begins to angle up. first it got a rubber hose coming from trans cooler and almost all coolant was leaked out. The projectile was then into the O2 sensor bank 1 sensor2 where it severed all 4 wires from sensor. i had repaired coolant leak and driving as i thought would be ok without sensor. i have a scangauge 2 in my ODB and getting 0037 which refers to previously mentioned sensor. well i was clearing code and it seemed ok. that is until the check engine light not only came on but flashed along with warning of high trans fluid temp followed by shut down. i have tried restarting a couple times but it doesn’t sound right turning over and i’m really beginning to worry i have made a mistake some could argue several. would love some thoughts on this. any and all info is welcome along with a little name calling because i possibly deserve it. lemme know folks
    The backstory for those interested isn’t that exciting which is why i really didn’t mention it initially since it was gonna be a long post anyway but since you asked…. passenger was swapping uppers on AR from 22 to the 5.56. last time 5.56 was on it the clip wasn’t emptied so there was one still in chamber he didn’t know enough about what he was doing and when he was trying to put clip in it wouldn’t lock in. foolish as he is tried to fix that by pulling trigger with the safety off. i would have much rather it have hit my leg or something better yet his foot instead of what it’s done to my truck
  2. Sep 27, 2024 at 7:16 PM
    sarcastictechsupport
    sarcastictechsupport Well-Known Member
    SoCal (805) - Mohave Desert
    2020 Super White TRD OR
    What are the codes? Check engine light flashing is a misfire.
    You need to fix the wiring for the O2 sensor.
    For the trans, either you didn’t fix the hose, the trans fluid level is incorrect or there is additional damage you haven’t found.
    HondaGM, TnShooter and vivid02 like this.
  3. Sep 27, 2024 at 7:22 PM
    Redhead fishin
    Redhead fishin Well-Known Member
    We gotta know the story behind this.
  4. Sep 27, 2024 at 7:22 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I would let Toyota evaluate. Oil change personnel are lowest grade, but they do have master technicians to evaluate complex problems.
    Not sure how the cost of the master technician is covered ... you provided no details of "how" and I am not asking. But insurance company may take a dim view if it happened from an accidental misfire inside the cab.
    HondaGM and SandyTaco4x4 like this.
  5. Sep 27, 2024 at 7:44 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Alright well first of all, you can’t come on here posting this without the backstory cmon now.
    secondly…well Godspeed lol
  6. Sep 27, 2024 at 7:46 PM
    RichochetRabbit
    They have a picture for this ... :infantry:
    HondaGM, SandyTaco4x4 and joeyv141 like this.
  7. Sep 27, 2024 at 7:46 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    subbed for the backstory :popcorn:
  8. Sep 27, 2024 at 7:49 PM
    RichochetRabbit
    One more joke from me ...
    Hole-y smoke! :rimshot:
  9. Sep 27, 2024 at 7:51 PM
    Aaron O.
    Aaron O. Well-Known Member
    Aaron
    Denver, CO
    2023 Tacoma Off Road DCLB
    You shot your truck? I mean I know some guys are down on 3rd gen’s but thats pretty extreme! :quickdraw:
  10. Sep 27, 2024 at 7:59 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
  11. Sep 27, 2024 at 8:02 PM
    RichochetRabbit
    As I said, Toyota better-than-entry-level technician may be your best bet for evaluation.
    Because you are new I will warn you ... Friday is for "ridiculous" threads and responses. I assume you are in earnest looking for an answer, but the nutcases in here may take advantage of "Friday". :notsure:
  12. Sep 27, 2024 at 8:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  13. Sep 27, 2024 at 8:48 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  14. Sep 27, 2024 at 8:49 PM
    scocar
    scocar hypotenoper
    Dude, you are supposed to use 9mm on Japanese brands.
  15. Sep 27, 2024 at 8:52 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Hell of a first post! Welcome to the forum, and keep us posted.
  16. Sep 27, 2024 at 9:01 PM
    MGMDesertTaco
    Definitely Friday worthy. :popcorn:
  17. Sep 27, 2024 at 9:04 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    OP thought they were just air soft guns.
  18. Sep 27, 2024 at 9:12 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Welcome to TW, how is the gear hunting on your 3rd gen?
  19. Sep 27, 2024 at 9:25 PM
    CrazyCrewChief
    CrazyCrewChief Unknown Member
    Gordon
    NorCal
    2015 Tacoma AC TRD Sport MGM
    LOL!
    HondaGM, YOTA 4X4, wilcam47 and 2 others like this.
  20. Sep 27, 2024 at 9:32 PM
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    TOP TACO, HondaGM, TACOTU3 and 9 others like this.
Thread Status:
