Gutterstuff gutter guards-anyone use them?
Discussion in 'Off-Topic Discussion' started by scocar, Dec 1, 2011.
  1. Dec 1, 2011 at 9:37 AM
    scocar
    scocar [OP] hypotenoper
  2. Dec 1, 2011 at 9:39 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Poop!
    All the sponge holes will get filled with debris and if your in a winter climate they will freeze solid and rip your gutters off from the shear weight.
    I use these with no issues
    Dick!
  3. Dec 1, 2011 at 9:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't put them on my house. I'd get something like B... I mean XXXX showed.
  4. Dec 1, 2011 at 9:46 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    :wave: Scott, Will check back on this as mom in law has 4 big oaks around her house so every time I go there guess what I do.. Thanks Jim :cool: ( AKA, THE FLA.DICK)
  5. Dec 1, 2011 at 9:59 AM
    scocar
    No freezing/ice/snow loading issues here.
    Aren't the metal leaf guard ones integrated with the main gutter, or can you add them on after? Also, don't they still allow lots of small blown debris in? Small leaves, flying seed pods? Which still need to be cleaned out at some point? And f'ing expensive?
    Also, I believe I saw a video of those in which you could watch leaves get pulled around an into the gutter by water...but maybe that was a slightly differnet brand. Dunno, I wasn't convinced.
    Thanks Jim.
  6. Dec 1, 2011 at 10:15 AM
    XXXX
    sKiP
    05 Prius
    :anonymous:
    Nope they can be added on later.
    I wouldn't say "lots" of debris, but the small stuff does get in there. You have seen my lawn and I have leaves and pine needles covering 100% of it. I remove one grate per run and spray them out once a year. Yes, they are expensive, but worth it to me.
    The major saving grace for me is that they don't fill with ice/snow and rip off the house in winter and I don't have to clean them by hand.
    The ones you show, stop short of the top of the gutter so debris will be laying on top. I think the sponge ones will need to be totally removed to be cleaned out. Not sure, but that's what I'm thinking.
  7. Dec 1, 2011 at 10:27 AM
    Pugga
    Massachusetts
    I'll echo what he said. They are expensive, they can be added on later and they are worth it. The small debris that does make it through can be hosed out as long as it doesn't collect for years and gum up. Also, I agree with the statement about the sponges sitting too low. I can see a bunch of say pine needles sitting on top of those and then those will catch leaves, dirt, etc and you'll end up having to remove all the foam to get the debris off the top and also hosing the foam itself to get the fine particles out. Over time I can see the foam getting choked out by dirt so water can no longer easily pass through. Might work if you put them on at the beginning of fall just for the heavy leaf falling but even then it's a stretch in my opinion.
  8. Dec 1, 2011 at 10:29 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You can also get a perforated aluminum screen that will apply directly to the top of your existing gutters
  9. Dec 1, 2011 at 10:40 AM
    scocar
    Hmmm. Good points to consider. Fortunately, I don't have needles to contend with, either. I can see how needles could turn these foam things into porcupines if the end got stuck in the foam. I have mainly huge sycamore leaves that would be blown off if resting on top. But then there are all the flying seedpods and crap in the spring too.
    Seems that with the open channel at the bottom, one section of foam could be removed and then the whole channel blown out with water as Boyd does with his. Or just spray them hard from above once evey 3 or 4 years to blast fines down into the channel and wash them out.
    My thought was to test them on a short run of gutter at the front of the house where the Sycamores drop a lot and see how they perform before deciding on full install.
  10. Dec 1, 2011 at 10:44 AM
    scocar
    Yeah, I've seen those, too, but for the stuff around my house, it seemed they would still let a lot of crap through and not be as easy to remove when necessary or fit as tightly (seams between sections). Or maybe I am imagining a different product. I'll have to take a closer look at what is available.
  11. Dec 1, 2011 at 10:55 AM
    scocar
  12. Dec 1, 2011 at 12:17 PM
    OZ-T
    Peter North
    British Columbia
  13. Dec 1, 2011 at 12:31 PM
    scocar
    well
  14. Dec 1, 2011 at 12:34 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  15. Dec 1, 2011 at 12:36 PM
    Pugga
    Massachusetts
    gooud (OZ always seems to throw random 'U's in words, he must have forgotten this time)
  16. Dec 1, 2011 at 12:44 PM
    scocar
    OUZ-T
  17. Dec 1, 2011 at 8:06 PM
    OZ-T
    Peter North
    British Columbia
    BLOUW MUE
