Guy backed into my front bumper, cost to replace?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toast, May 24, 2010.
  1. May 24, 2010 at 6:36 AM
    toast
    toast [OP] Well-Known Member
    JW if anyone on here has replaced the OEM front bumper and had it resprayed. Reason being is that someone I know backed into me, and I'm now looking at getting an ARB or AllPro instead of replacing it like new.
    My guess is $4-500 for a new OEM bumper and having it resprayed. He is paying for the repairs.
    If I go ARB or AllPro, am I looking at upgrading the suspension too? Stock '09 Prerunner Access Cab.
    Also can someone point me to a cheap supplier of the ARB?
  2. May 24, 2010 at 6:58 AM
    High-Gear
    High-Gear Zombie Killer
    Newton, KS
    09 TRD Off Road
    TRD Supercharger, TRD Cat Back Exhaust, DR / Icon 2.5 Coilovers, Camburg UCA, TSB with AAL, Walker Evans 2.0 reservoir rear shocks, ARB Bull Bar, Smittybilt 10K Comp Winch, ARE Camper Shell, Con-Ferr Safari Rack, 4 KC Highlights on rack, 2 KC Rallye 800 on Bumper Armortech Off Road plate rear bumper. Firestone Airbags in rear, with Firestone compressor.
    TRD Parts 4 U, (Toyota of Dallas) is where I got mine. Jacque is a very cool guy and great to work with! A new ARB with fogs will set you back about a grand, while the older style will be about $850 shipped to your door. What color is your truck? I just removed a front bumper cover with fog lights in Metallic Grey from my truck. I'd make you a good deal on it, but I don't know what shipping would be to Florida.
  3. May 24, 2010 at 7:00 AM
    toast
    Pyrite is my color unfortunately. I take it my stock fogs will not fit into the ARB?
  4. May 24, 2010 at 7:02 AM
    High-Gear
    Newton, KS
    09 TRD Off Road
    No they are a different size, and cost an additional $70. You can use your factory wiring though. I decided on the older style, as one was in stock in Dallas, and I was going to use KC driving beams anyway.
  5. May 24, 2010 at 7:04 AM
    toast
    ah ok. did you color match yours or go with black? pics?
  6. May 24, 2010 at 7:08 AM
    High-Gear
    Newton, KS
    09 TRD Off Road
    Went with Black. mouse over the little camera icon on the left side in my profile and you will be able to click on a photo of my truck.
  7. May 24, 2010 at 10:16 AM
    toast
    Looks awesome. Any idea if I can run ARB or AP without upgrading the front suspension?
  8. May 24, 2010 at 10:33 AM
    High-Gear
    Newton, KS
    09 TRD Off Road
    You can do it, but I think the weight will make it sag quite a bit. You can replace with OME springs to offset the weight if you dont want to lift it.
  9. May 24, 2010 at 12:39 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  10. May 24, 2010 at 1:27 PM
    toast
  11. May 24, 2010 at 1:39 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    It was about an inch. Next time I'm at the hall I'll bust out the tape measure for you. Deal?
  12. May 24, 2010 at 1:42 PM
    toast
    sweet thanks man
  13. May 25, 2010 at 4:10 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Running 265x75R16 BFG A/Ts, measured from the ground to the fender, dead center of the wheel and hub it's just shy of 2'10".
  14. May 25, 2010 at 4:12 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    I would check CBI over ARB or All Pro.
  15. May 25, 2010 at 5:29 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    If you like the ARB, shockworks has a similar style bumper but it looks a bit more aggressive.
    I regularly see another Taco around town that is stock plus an ARB front bumper (no winch installed) and it doesn't look like it sags at all.
