GUYS!! need to know what else to buy with bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12taco12, Jan 14, 2021.
  1. Jan 14, 2021 at 3:57 PM
    12taco12
    12taco12 [OP] Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    im getting wheel hub/bearing pre-assembled. what other seals/bushings do i need to do at the same time?
  2. Jan 14, 2021 at 4:01 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    If it's pre assembled it should already have the seals no?
    whatstcp likes this.
  3. Jan 14, 2021 at 4:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Inner and outer dust seals.
    One is on the axle, the other is in the back side of the spindle.
    The o-ring is usually supplied with the hubs.
    Muddinfun, 12taco12[OP] and whatstcp like this.
  4. Jan 14, 2021 at 4:50 PM
    12taco12
    rochester NY
    2012 TX Pro
    dust seals. for the life of me i couldn't think of it. how hard are they to swap on each side. haven't done them on the truck yet
  5. Jan 14, 2021 at 5:13 PM
    TnShooter
    Deogee
    STOCK
    po35042 and whatstcp like this.
  6. Jan 14, 2021 at 5:23 PM
    12taco12
    rochester NY
    2012 TX Pro
    Do I need to remove the cv from both ends? (Cv and bracket)
  7. Jan 14, 2021 at 5:24 PM
    Muddinfun
    Muddinfun Well-Known Member
    If you haven't done the ECGS bushing yet, now is the time. Doing the wheel bearings, you're 80% there towards installing the bushing.
    dtaco10 and TnShooter like this.
  8. Jan 14, 2021 at 5:27 PM
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    I have done 3 wheel bearings in 7 years and 100k on my taco. Never put on the seals. I have gotten to the point where i can take apart my front suspension in about 30 minutes. And I found a source of 4x4 bearings and hubs for 120 bucks. So plus one for pretty much ignoring the additional seals.
  9. Jan 14, 2021 at 5:30 PM
    12taco12
    rochester NY
    2012 TX Pro
    That may be the reason you have to change them so much. Dust and dirt are getting in cuz of the seals.
    joshhh, Too Stroked and Muddinfun like this.
  10. Jan 14, 2021 at 5:30 PM
    12taco12
    rochester NY
    2012 TX Pro
    Already had the ecgs done couple years ago but good point
    Muddinfun[QUOTED] likes this.
  11. Jan 14, 2021 at 5:31 PM
    12taco12
    rochester NY
    2012 TX Pro
    What bearings are you using
  12. Jan 14, 2021 at 5:31 PM
    TnShooter
    Deogee
    STOCK
    I believe the CV can stay in the differential. But it is not going to be easy if you are doing it yourself.
    Having a buddy keep it still while you beat the new seal on helps a lot.
    I didn’t replace my seal on the CV, but it was due to time constraints.
    You should replace it, it helps keep water out of the bearing.
  13. Jan 14, 2021 at 5:45 PM
    Muddinfun
    Yep, here's my post from a few months ago.
    Here’s something worth mentioning. There are 3 seals per side of the truck. 1 outer and 2 inners. If you buy a bearing and hub assembly it comes with the outer seal already installed. Many people cheap out and don’t replace the inner seals, which leads to water getting into the bearing.
    “Replacing the wheel bearing is an easy job. I’ve done it lots of times. I’ve got the time down to 20 minutes per side.”
    These are the guys that are just slapping in bearings without doing the inner seals. That’s why they’ve done it lots of times.
    Lester Lugnut and TnShooter like this.
  14. Jan 14, 2021 at 5:47 PM
    TnShooter
    Deogee
    STOCK
    Might as well throw this out there.
    Depending on where you live and the condition of your truck.
    You might or might not want to remove the Speed Sensor.
    You should, but sometimes when you do they break off.
  15. Jan 14, 2021 at 5:49 PM
    Muddinfun
    And they're expensive AF.
    TnShooter[QUOTED] likes this.
  16. Jan 14, 2021 at 5:51 PM
    12taco12
    rochester NY
    2012 TX Pro
    So I should at least do the seal on the inside of the bracket since the out seal is in the bearing assembly. And possibly but not needed to do the seal on the cv
  17. Jan 14, 2021 at 5:58 PM
    Muddinfun
    What is this "bracket" you keep referring to? You mean the knuckle?
    TnShooter likes this.
  18. Jan 15, 2021 at 1:55 AM
    12taco12
    rochester NY
    2012 TX Pro
    yes the knuckle
  19. Jan 15, 2021 at 7:35 AM
    Muddinfun
    It’s your truck and you can do what you want, but if you want to do the best quality work possible, you need to replace both seals. The CV seal is the 1st line of defense against water intrusion. The knuckle seal is the 2nd line of defense. Like if you live in a bad neighborhood, you need to lock your doors and keep a gun by your bed. It’s not smart to leave your door unlocked, just because you’re ready to blast the crackhead.
  20. Jan 15, 2021 at 9:41 AM
    12taco12
    rochester NY
    2012 TX Pro
    maybe im lost now , so the o ring looking one will be inside my assembled hub. then right behind the hub assembly on the face of the knuckle is a dust shield. then directly on the backside of the knuckle is another dust shield? so i jus need 2 dust shields per side? no o ring
