Guys pls tell me should I get TRD shocks or 5100 shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sanga700, Oct 13, 2009.
  1. Oct 13, 2009 at 4:31 PM
    sanga700
    sanga700 [OP] Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    I just bought 09 Taco SR5 4x4 and im thinking to do TRD shocks or 5100 blestein shocks so I can lift up 2.5' . should I have to get the springs with 5100 shocks or no need . Guys give me advices which one should I get ? I appreciated your time .
    Sang
  2. Oct 13, 2009 at 4:45 PM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    check out this group buy on this forum.
    http://www.tacomaworld.com/forum/toytec-lifts/54949-group-buy-feeler-toytec-eibach-kits.html
    I have the same truck as you. Just had the TSB done and the rear sits higher in the back than the front. I just want to level it out without spending a lot money....but want it to ride good. 5100's are the way to go....but be careful or you will compress your springs and give you a rough ride.
    Of course there are other options you can look into.
  3. Oct 13, 2009 at 4:47 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Go with 5100's they are awesome, no need for new springs these shocks were designed to use the oem springs. you wont regret it.
  4. Oct 13, 2009 at 5:00 PM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    ^He's right. My wife and I put them on my truck today set at 2.5", I was worried about the harsh ride, but it really is better than the stock TRD shocks by FAR. We did the rear 5100's as well with an AAL from Toytec for TSB springs.
    I'd say to go the 5100 route, well, because I went that route, and I'd look dumb saying go any other...
    EDIT: Oh and the "TRD" springs you speak of will not lift your truck... FYI
  5. Oct 13, 2009 at 5:01 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
  6. Oct 13, 2009 at 5:10 PM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    2007 | TRD |1ST 2012+ CONVERSION
    2012 CONVERSION | A LOT OF TOTAL CHAOS & ICON DYNAMICS
    Since you'll need to install either set.
    Just get the 5100's. Best Bang for your Buck!
  7. Oct 13, 2009 at 5:14 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Ditch the factory stuff, and go 5100's or OME.. 5100s are very easy, and work great. Be sure to replace the front and rear.
  8. Oct 13, 2009 at 5:18 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    get the 5100's
  9. Oct 13, 2009 at 5:28 PM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    SamSter0077, why do you need to replace the rear with 5100's? I have a TRD with the package. Would I need to replace the rears with the 5100's?
    I want to level out the front, but am happy with the TRD Bilsten shocks I have. Thanks
  10. Oct 13, 2009 at 5:35 PM
    SamSter0077
    Katy, TX
    I just replaced my rear TRD shock absorbers with the OME shock absorbers and it made a significant difference in the ride quality.. the factory TRD shock absorbers were plumb "bumpy" and the build quality as compared to the higher performance model was dramatic.
    Doing the rear will only change the ride quality.. it will not affect the height of the back at all. I am putting OME struts up front this weekend for lift.
    if you just want to level it, go for the 5100's up front and find the setting that levels it. I think you can find a set of four for around $300.00.. OME is going to be around 699.00 or so Front/Back.
  11. Oct 13, 2009 at 6:42 PM
    sanga700
    San Diego, CA
    Thanks for all your advices . Sorry for a dump question . What is the OME ?
  12. Oct 13, 2009 at 7:24 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Old Man Emu
  13. Oct 13, 2009 at 7:30 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Old Man Emu. A suspension company that is based out of Australia. They were recently bought out by ARB which specializes in lockers and bumpers among other things, of which they also make for the Tacoma
  14. Oct 13, 2009 at 7:38 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    you can get the 5100's from downsouth motorsports for 295 shipped. email them and they will give you the coupon code for being apart of tacomaworld.com ill be ordering my set soon
  15. Oct 13, 2009 at 7:40 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Thanks for making my answer look like shit.
  16. Oct 14, 2009 at 2:35 PM
    SamSter0077
    Katy, TX
    I don't think any help was needed.. :p
