H.i.d. Help
Discussion in 'Lighting' started by JAK3, Oct 29, 2009.
  1. Oct 29, 2009 at 1:10 AM
    JAK3
    JAK3 [OP] O.G.
    JAKE
    O.C.
    09 double cab
    tint
    Bout the xnenon hids from the gb from slimcubby and the right side is fine its just the left side seems like something is cutting the light off. Any suggestions =/
  2. Oct 29, 2009 at 1:27 AM
    Robtrd
    Robtrd Member
    Robert
    Riverside, CA
    08 TRD SPORT
    Most likely not getting ground good.
  3. Oct 29, 2009 at 9:03 AM
    YotaComa
    YotaComa Well-Known Member
    NorCal
    2004 Tacoma Double Cab
    the left side beam is supposed to be a little lower and cutoff. So you dont blind oncoming traffic.
    Thats just how good headlight housings are designed.
  4. Oct 31, 2009 at 9:31 AM
    cohrmundt
    cohrmundt Well-Known Member
    Cullen
    TEXAS
    2006 TRD SPORT 4X4
    4.88 nitro gears, Detroit rear, Projector headlights, Relentless Fab custom bumpers and sliders, 6" Pro Comp suspension, all pro leafs, 37x13.5x17 toyo open country tires, method racing wheels, Flowmaster exhaust w/cutout, DTLT headers, K&N CAI, URD MAF calibrator, grillcraft grill with 30" and 20" led bars behind, windshield mounted 50" led bar, Infinity 6x9 speakers, Custom box w/MTX 7500 10"sub, MTX 1200 watt amp, blue led gauge cluster and radio mod, URD short shifter, fiberwerx fenders
    if your battery isnt sending enough juice to your HID's, this will cause one or both of your lights to cut out. Is your light cutting out while you are driving, or just when you start your truck?
  5. Nov 1, 2009 at 9:18 PM
    JAK3
    JAK3 [OP] O.G.
    JAKE
    O.C.
    09 double cab
    tint
    we just had the shields in upside down sorry for the inconvinece but thanks for all your help they work perfect now! =]
  6. Nov 3, 2009 at 3:57 PM
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    i'm only getting the light in the top half of the lens on low beam and then on high beam i'm getting the top half plus a little more.. is that right?
  7. Nov 3, 2009 at 4:03 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    That's correct. That's how they are designed.
    The reflection off the top of the inter housing will reflect the light downward - not blinding people. If the bottom of the housing would get lit up, it would reflect the light up at the sky/oncoming traffic.
  8. Nov 3, 2009 at 4:04 PM
    freesample
    oh ok cool.. jsut making sure im getting the best of my lights
