H.I.D. lights???
Discussion in 'Lighting' started by surfbum1123, Feb 9, 2007.
  1. Feb 9, 2007 at 4:09 AM
    surfbum1123
    surfbum1123 [OP] Member
    I was wondering why the Taco's don't have them installed. I own an '07 and really love the lights. ANy recommendations on what bulbs to get?/ or is it even a good idea?? :confused: :eek: :confused: :eek:
  2. Feb 9, 2007 at 6:53 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have sylvania silver star lights they are really bright and white with the brights on but in reg mode they are just a little whiter than halogen lights... about 25 each. If you find something better let me know, I know HID'S are really expensive aren't they?
  3. Feb 9, 2007 at 8:03 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    I put the Sylvania Silver Star lights in my 03 taco and you can tell the difference in hi and low, I left one OEM bulb in while I was changing them and you can see the difference. The OEM is a dull yellow, and the Sylvania is nice and clear. worth the 30 bucks from Pep Boys.
  4. Feb 9, 2007 at 9:12 PM
    surfbum1123
    i've seen those sylvania stars around, but didn't think they are good quality, are they? they better thank piaa??? i'll continue to look around and see what i can find
  5. Feb 9, 2007 at 9:42 PM
    topdec
    topdec Well-Known Member
    I have a similar experience with Sylvania. They're ok, not great.
    You might want to look at adding the Xenon HID hardware. http://cgi.ebay.com/ebaymotors/97-0...tegoryZ33710QQihZ013QQitemZ230089161297QQrdZ1
  6. Mar 15, 2007 at 2:08 PM
    sunruner19
    sunruner19 Senior Senile Member
    Bill
    Great Sacandaga Lake region Northville NY, South Y
    09 Tacoma 4WD
    supercharger, ARE series 2 lid.
  7. Mar 15, 2007 at 3:24 PM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    thanks for the info sunruner
  8. Mar 30, 2007 at 11:51 AM
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    If you install HID just make sure you get a conversion kit that's meant to replace the type of bulb you currently use (HB2, H4 and 9003 are all the same bulb).
    If you don't use the correct conversion kit the new filament will be in the wrong spot and you'll likely wind up blinding oncomming traffic... which can get you a fine and possibly your vehicle towed if one of those oncomming vehicles is a cop.
  9. Mar 30, 2007 at 1:19 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    You are definitely correct on that. Read the info about HID conversion kits found in this link:
    http://www.danielsternlighting.com/home.html
  10. May 10, 2008 at 2:33 PM
    sunruner19
    Bill
    09 Tacoma 4WD
    I have been absent from this forum for quite sometime. I still havent found what I think is a quality HID kit, but I did find some articles on the companies that so-called advertise their products as the real thing. I am putting a link into this post which I think would make some good reading. One advantage of this article is that the website can be used to search out any company to get info on them BEFORE you buy.
    http://hidreview.com/index.php?option=com_frontpage&Itemid=1
  11. May 10, 2008 at 3:13 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    I got my HID kit on ebay. 6000k. hi/low kit was roughly $120. No problems with them. its just a plug and play kit, no retrofitting or anything. The cut off isnt as bad as I thought it would be, the factory 2nd gen tacoma cut off is pretty decent anyways. I can take pics if needed just let me know.
  12. May 10, 2008 at 7:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Pics of the cut off, and could you get some pics faceing the truck from about 100 ft. away with the lights on?
  13. May 12, 2008 at 3:02 AM
    GotLift37
    North East AL
    07 4Runner 4WD
    sure, will do after work.
