H0H-Crankshaft Position Sensor recall
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Jul 24, 2017.
  1. Jul 31, 2017 at 9:27 AM
    #201
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The ring gear/flexplate has nothing to do with the crank position sensor. It is mounted much further forward on the engine and picks up from a specific timing rotor on the crankshaft.
    Jeff
    The hammer[QUOTED] likes this.
  2. Jul 31, 2017 at 9:29 AM
    #202
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Better yet how about Toyota stand behind there product?
    Blazingbluesport and speedtre like this.
  3. Jul 31, 2017 at 9:31 AM
    #203
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Whatever floats your boat.
  4. Jul 31, 2017 at 9:33 AM
    #204
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Then hold them on the carpet at the dealership. No one will call you from Toyota for complaining on an Internet forum.
  5. Jul 31, 2017 at 9:33 AM
    #205
    IPNPULZ
    going to be fun!
    Again.....
  6. Jul 31, 2017 at 9:34 AM
    #206
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    This doesn't seem very productive, guys.
    swimmer likes this.
  7. Jul 31, 2017 at 9:35 AM
    #207
    IPNPULZ
    going to be fun!
    That's exactly whats going to happen trust me Toyota has been put on Notice!
  8. Jul 31, 2017 at 11:36 AM
    #208
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Well that would definitely complicate cleaning since that's a tiny hole lmaoo!
    Edit: That being the case thought (internally housed), why would it need much if any coating at all??
  9. Jul 31, 2017 at 11:44 AM
    #209
    The hammer
    I wouldn't put any stock on what Toyota or any other maker publicly states in these matters as they have to be sanitize to avoid any unforeseen liabilities that may arise as a consequence, just like the TSB and diff language used. The actual repair procedure tells more about the problem.
    Moreover, you bring up an interesting point I hadn't thought about, that being inspecting the CPS for unusual deposits and cleaning. I would use electric cleaner, but now will take it out on my next service and look at to see if It has any special coating to be aware of hmm.
    Cheers!
    bshammer0[QUOTED] likes this.
  10. Jul 31, 2017 at 1:21 PM
    #210
    dimead0zen
    dimead0zen Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    Getting my truck "inspected" and sensor replaced tomorrow. According to the VIN it's affected by this H0H nonsense. All fo free.
    bshammer0 likes this.
  11. Jul 31, 2017 at 2:56 PM
    #211
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Replacing a sensor when you have a bad timing wheel is fixing the wrong end of the parts chain. This is going down the path of floor mats causing a throttle problem. If it was a bad sensor and a bad timing wheel why doesn't it have issues from the time the motor was first started. The parts were no further or closer than the day they were first assembled. Putting the hall effect sensor next to the exhaust system was a bad move. You heat up any electronics it is not a good Idea. This extra coating bs is for the sheep. If it had extra coating it did on day one so why does the engine run at all. I'll bet the integrated exhaust manifold or the raised catalytic converter is going to be the culprit. You watch next will be a bolt on heat shield for the sensor.
    lapoltba and bshammer0 like this.
  12. Jul 31, 2017 at 5:52 PM
    #212
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    In the automotive world and recalls, it's about damage control. If you can come up with a plausible cause and resolution (and the data to back it up), you buy yourself some time to find (and find a solution for) the actual problem. At some point they will probably try to pin this on a tier 1/2 supplier to clear their name.
  13. Aug 1, 2017 at 5:47 AM
    #213
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    So, I ran through most of the premium I had left in the tank and refilled with my tried and true BP 89 last night. Also reset the battery (which I hadn't done after replacing the CKP this time as of yet). Ran the same, heavier steering still present, didn't feel any stutters though, and MPG on the way in was almost 21 (and I was having to "get on it" a bit more since it's relearning...).
    Still, low ignition timing seems to be an issue? and, of course I still log misfires on every trip - this time sprinkled throughout the drive and not just after startup. That said, I felt like the truck was driving decent - just not as well as it has. I guess consistency was never meant to be a friend of the Taco (at least with this version of the software..).
  14. Aug 1, 2017 at 5:52 AM
    #214
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Looks like when you get those high spikes in load or rpm, it misfires.
    Ever log any misfires before it's warmed up?
  15. Aug 1, 2017 at 5:59 AM
    #215
    bshammer0
    Brandon
    Nashville, TN
    Yes, generally I log a misfire or 3 after a cold start when pulling out of my driveway within the first couple of minutes before it's warmed up.
    I probably would have logged them that way this AM, but I didn't connect my OBD until it had somewhat heated up (3-4 minutes into my drive)
  16. Aug 2, 2017 at 6:08 AM
    #216
    bshammer0
    Brandon
    Nashville, TN
    Still misfires, but today only shortly after pulling out of my neighborhood. Didn't feel bogged, shifted decently, but steering was still very heavy and every bump in the road was jarring w/o much to soften it. It's driven much better than this. I will say that I hit a record high MPGs on the way in though... before my initial CKP replacement, I was getting 16-17mpg on the same trip, then 19-20 after replacing with "89", this morning I got 22mpg with my "98" sensor. Hmmm...
    speedtre likes this.
  17. Aug 2, 2017 at 6:16 AM
    #217
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Honestly man, I think you may read too much into the variances that this truck has in driving behavior and making correlations to things that aren't really correlated.
    GPsevinSixx and Casinater like this.
  18. Aug 2, 2017 at 6:20 AM
    #218
    bshammer0
    Brandon
    Nashville, TN
    I can't disagree there - wandering in the dark trying to understand why the constant variability in drivability and enjoyment and it is a fools errand for sure...
    GPsevinSixx likes this.
  19. Aug 2, 2017 at 6:20 AM
    #219
    Casinater
    Casinater Well-Known Member
    Casey
    2017 Quicksand Tacoma TRD OR DCSB
    Yeah I don't think a CKP sensor is ever going to effect steering feel or dampen the ride on a rough road.
    lapoltba, GPsevinSixx and bshammer0 like this.
  20. Aug 2, 2017 at 6:24 AM
    #220
    bshammer0
    Brandon
    Nashville, TN
    Not directly, no. But I can tell you for a certain fact that when I first replaced my CKP from my stock one, I instantly felt an easiness in the steering that had NEVER been present with this truck then slowly got heavier intermittently but still sometimes "easy" and then has gotten back to just being heavy all the time. It makes no sense - agree. But I've had my power steering inspected (by the dealership which may not be worth much considering my experiences) and fluid is good. It's just not fun to drive like that - the difference in steering feel is night/day. When it's good I look forward to the drive and enjoy the truck, when it's heavy like that its just jarring and uncomfortable. If I can't get it to consistently drive in a manner I enjoy, I will have to consistently drive something else once it makes financial sense to do so...
