H0H-Crankshaft Position Sensor recall
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Jul 24, 2017.
  1. Jul 27, 2017 at 8:28 AM
    #121
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Thanks Greg, also in for your thoughts on how the truck runs after the swap! Are you tuned?
  2. Jul 27, 2017 at 8:33 AM
    #122
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Yes - I'd be especially interested in any measurements to determine how much of a size difference there is. based on the recall details, it seems we should expect to see a slightly smaller / shorter sensor to account for the coating that makes it a tight fit and thus static electricity?
    MOC221_ likes this.
  3. Jul 27, 2017 at 8:33 AM
    #123
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Do you think you will see a physical different between the 89 CPS and the 98 CPS?
  4. Jul 27, 2017 at 8:39 AM
    #124
    MikeyD.25
    MikeyD.25 Well-Known Member
  5. Jul 27, 2017 at 8:39 AM
    #125
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    This! Please take very detailed measurements if you could as the length could be ever so slightly different. I also talked to online place I ordered my "89" sensor from and they are kind of surprised at the different part number. Hmmmmmmm.
  6. Jul 27, 2017 at 8:39 AM
    #126
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    I'm in the same boat with you. Bought mine in Jan 2016 and not on the recall list. Can't figure it out.
  7. Jul 27, 2017 at 8:42 AM
    #127
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    In on the recall list with a November 15 build date. I have a spare sensor that I bought awhile back. I will need to check the part number.
  8. Jul 27, 2017 at 11:38 AM
    #128
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Vehicle information:
    Production Date: 09/16
    ECU/TCU: Rev 1
    Included in VIN Recall: No
    Theorized Related Symptoms: Stumble/flutter around 1200-1500 rpms under low-moderate load, before a shift. Very rare but occasional hesitation/power loss on incline that goes away after releasing/re-engaging throttle
    Physical dimensions are the same. Measurements between the two came out the exact same. Of note, however, was my stock CKP sensor did have light surface scratches.
    Old left, new right.
    visible scratches:
    Number on old started 0971 - New was 0972. Unsure if this is a part number or an incremental lot number. May be nothing more than production numbers of the same part.
    Hash mark present on old, not on new (two lines on new)
    So far, Stumble/flutter is still there. Completely unchanged driving characteristics noted. Time will tell on the rare power hesitation, but it seems this is not the cure for at least the stumbles.
  9. Jul 27, 2017 at 11:45 AM
    #129
    bshammer0
    Brandon
    Nashville, TN
    Thanks @Scooby24 - very detailed, more than I expected by far so thank you for taking the time to provide the pictures, measurements, etc., Somewhat concerning if the new sensor is the exact same size as the old one, and the old one was getting scratches from coming in contact with the crank rotor, how does replacing with one with the same propensity to come in contact with the rotor fix things.
    Sorry to hear that didn't help with your stumble/flutter at all. Mine definitely decreased massively when I replaced my stock CKP with the "89" though it still does happen it's not as frustrating and persistent. Let us know if you get any better results with drive time.
    Question: Did you reset the ECU when you replaced the sensor?
  10. Jul 27, 2017 at 11:50 AM
    #130
    Scooby24
    Greg
    2017 DCSB OR 4X4
    No I did not reset the ECU as I wanted immediate feedback if it was the sensor itself that was causing the problem. It's possible that abnormal readings, over time, have lead to learned behavior resulting in timing variances/stumbling as a result. Time will tell on that. Resetting the ECU immediately would give me a potential false sense of improvement as it had to go through the relearning phase. I may reset the ECU now that I've got an immediate result but I'm not optimistic.
    taco 16 likes this.
  11. Jul 27, 2017 at 12:07 PM
    #131
    bshammer0
    Brandon
    Nashville, TN
    I followed the directions in the FSM for the replacement and it stated to unplug the negative battery terminal prior to replacement so I did that. I wouldn't be surprised if resetting it does make a difference given those scratches, and in my experience this ECU has a slow learning curve and seems to take a thousand or more miles to adjust to anything. Regardless, sorry you didn't get positive results there. IF you do the ECU reset, in my experience it only takes 5-10 mins. just leave your door open and the lights will bleed out any remaining juice in the system!
    Toytaco2k17 likes this.
  12. Jul 27, 2017 at 12:08 PM
    #132
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    This was the outcome I am afraid of with my truck. They are blaming the ckp sensor for the issues with the stumbling with the OV tune. I'm going to be very disappointed if it does not fix it. My sensor will be here tomorrow so I guess we will see. I will hope for the best since alot of people said the truck was different after changing the sensor.
  13. Jul 27, 2017 at 12:25 PM
    #133
    Scooby24
    Greg
    2017 DCSB OR 4X4
    I have confidence OVTune will be able to resolve the Stumbles. Keep in mind he has ONE tune released, an alpha tune....and he has no datalogging setup yet. Without datalogging, we could only hope to get a positive result from the first tune...the fact that the only real complaint folks have so far is a more prevalent stumble given all the handicaps with any Alpha release speaks volumes.
    Once he starts seeing lots of folks datalogs and identifies the common trend, I think it will get fixed...especially finding out now that this wasn't related to the CKP sensor. Likely all in the tune.
    speedtre, Toytaco2k17 and bshammer0 like this.
  14. Jul 27, 2017 at 12:53 PM
    #134
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    I saw somewhere a detailed process with pictures of the removal and replacement of the CPS. Does anyone know where I might find that again. Thanks in advance
  15. Jul 27, 2017 at 12:58 PM
    #135
    Scooby24
    Greg
    2017 DCSB OR 4X4
    The instructions are in the OP. PDF file outlines it and anyone with basic tools can accomplish it in about 10-20 minutes.
  16. Jul 27, 2017 at 1:23 PM
    #136
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Very disappointing that it didn't seem to help your stumbling problem. (yet)
  17. Jul 27, 2017 at 1:37 PM
    #137
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Reset ECU and stumbles are gone. So, the stumbles are learned and replacing the sensor alone won't fix them. There's a very real possibility they will return after new learning however I will note something that is now unmistakably different.
    I didn't mention it earlier because I thought it was placebo, but idle vibrations after changing the sensor were virtually gone which did stick out as different. After resetting the ECU they are gone, entirely. Like no vibrations at all. Shortly after buying my truck I thought there was something unusual about how much vibration you'd get at idle through the steering wheel. It was always there, but got noticeably worse at periods where I just chalked that up to the secondary injector cleaning cycle. However, after feeling the difference in idle vibrations now, I'm not ready to write off this new sensor. CKP sensors are notorious for having their problems with accurate readings in lower RPMs so the low rpm stumbles may be as a result of learned timing adjustments due to abnormal CKP readings, and the vibrations felt during idle may be symptoms of poor fueling/ignition due to inaccurate CKP readings at the lowest RPMs.
    edit: Here's a thread I made last November about the vibration. Looks like I made the thread around 1k miles. Shouldn't take too long to know if this is a temporary thing or not.
    https://www.tacomaworld.com/threads/idle-vibration-increase-recently.459127/
    swimmer, taco 16, speedtre and 2 others like this.
  18. Jul 27, 2017 at 1:42 PM
    #138
    r1200gs4ok
    O. K.
    Irvine, Ca
    thank you
  19. Jul 27, 2017 at 1:46 PM
    #139
    lapoltba
    CT - 06076
    Positive sign, but we won't know for sure until you rack up some miles. Thank you for resetting the ECU.
    speedtre and shakerhood like this.
  20. Jul 27, 2017 at 2:01 PM
    #140
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    For those resetting the learning / ECU where are you doing that in techstream and how exactly are you doing it?
