H1 led bulbs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deathpunch8210, Feb 20, 2020.
  1. Mar 5, 2020 at 5:43 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Running HIDs in a reflector housing like the OEM 2nd Gen headlights or fogs is an extremely bad and unsafe practice. You create extreme glare for oncoming drivers and don’t have pattern control, it doesn’t work. To run HIDs you need to do so in a projector based housing, and to do it right it should be in an HID projector. You mention 6 ballasts, so presumably you are talking separate HID highs, which is problematic as HIDs are not instant on, meaning the high beams require warm up time. Hence why OEMs do not use that and instead stick to a bi-xenon HID projector or use a separate halogen high beam.
  2. Mar 5, 2020 at 6:40 AM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    $80 SHIPPED for both sets
  3. Mar 14, 2020 at 9:37 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    The ballast only have to charge once, then both hi and lo are instant on. In other words, the first time you turn on the hi beams, yes they do take a couple seconds to get to totally bright. After that, hi/lo flashes back and forth like a strobe.
