H1 LED Headlight bulb recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RRProductionsAZ, Oct 1, 2020.
  1. Oct 1, 2020 at 12:00 AM
    RRProductionsAZ
    RRProductionsAZ [OP] rrproductionsAZ
    Rene
    2007 Silver Tacoma TRD
    LED Headlights, LED Fogs, LED Dome lights, LED map lights, Newer OEM Wheels, Upgraded Pioneer 7 inch receiver, Upgraded Rockford Fosgate speakers, 12' subwoofer
    Greetings,
    Can anyone recommend a reputable/durable H1 LED headlight bulb? I just put some Spyder projector headlights on my '07 Tacoma and plan to retrofit the stock bulbs to LED. The low beam H1 Projector bulbs have been purchased but am looking for another H1 for the high beams. I'm fairly certain the LED's (With fan) for the low beams won't fit in the housing of the high beams.. I could be wrong though.
    The H1 bulbs that i've found on Amazon/eBay don't have very good reviews, and most claim they are fairly dim.
    Thanks for any input.
  2. Oct 1, 2020 at 12:21 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Unfortunately those assemblies are well known to have horrible optics and poor quality focus resulting in performance that is far worse than stock in every way. Many that run those poor quality Spyder products end up going back to stock to restore performance. Using an LED bulb in a low quality halogen assembly actually makes performance even worse and they further reduce focus and have worse optical performance.
    These are likely your best bet. I'll be testing them in the 2nd Gen headlight thread soon.
    https://www.powerbulbs.com/us/product/philips-x-tremevision-pro150-h1-twin
    If you are really set on LED, check out Hikari Ultras. They will likely produce more foreground light and less distance intensity light than the halogens, but are among the best LED designs.
  3. Oct 1, 2020 at 12:55 AM
    RRProductionsAZ
    Rene
    Thanks for your reply, I actually just picked up a set of Hikari LED's a few days ago for the low beams.
  4. Oct 1, 2020 at 8:09 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Hikari has 2 models, you want to get the Hikari Ultras, which do a far better job of replicating a halogen and perform better than the other lower end model.
  5. Oct 2, 2020 at 8:18 PM
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
  6. Oct 2, 2020 at 8:32 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Correct, those are the ones as they are the “Ultra” version. Fan clearance can be a problem in some vehicles, in a 3rd Gen with OEM lights it is not. Cannot comment on clearance on other setups.
  7. Oct 3, 2020 at 2:31 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    I'd do a projector retrofit but if you aren't willing to do that I had good luck with these https://www.amazon.com/KATANA-H1-He...adlight+H1&qid=1601760623&s=automotive&sr=1-4
    The highbeams are going to be blinding even moreso than usual with any LED bulb no matter how well they say they keep to a halogen like patter.
    Trust me I know as I had the Katana/F2s in my low beam and Morimoto 2.0 in the high beams.
  8. Oct 3, 2020 at 3:23 PM
    prone2xl
    Mississippi
    hi @Jacked Burton I can't really tell by the pic are your headlights the same kind that ours were and u retrofitted them ? you had those Katana bulbs in before ?? if so did they fit in the housings alright with the fan or whatever people are saying about them ?
  9. Jul 28, 2022 at 7:50 AM
    Iangoodreau
    Iangoodreau New Member
    Ian
    2006 Tacoma SR5
    what low beam bulb did you go with? I’m having trouble finding the one for my headlights
