H10s stopped working?
Discussion in 'Lighting' started by krimson, Feb 16, 2012.
  1. Feb 16, 2012 at 8:12 AM
    krimson
    krimson [OP] Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    I was driving to work this morning and stopped behind a F150 at a light noticed my fog lights weren't on in the reflection of the tail gate. So I toggled my lights on and off, still wouldn't come back on. When I did get to work I tried it again in parking lot but it will come on for a little bit and shut off. What could be causing this problem? The only thing I can think of is a bad relay and from what I've read DDM tuning has horrible customer service when it comes to warranty work.
  2. Feb 16, 2012 at 8:18 AM
    Shaggy
    Shaggy Well-Known Member
    Woodbridge, VA
    2010 Pyrite Mica DC TRD Off Road
    also could be dirty or loose connections. I had a similar problem and disconnected and cleaned the connections with contact cleaner...has been working problem free since then.
  3. Feb 16, 2012 at 8:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do they share a common relay? If so, I'd start with that. To me it sounds unlikely that both ballasts would go bad at exactly the same time.
  4. Feb 16, 2012 at 8:24 AM
    krimson
    krimson [OP] Nothin
    TRD Off Road
    Yes they do.. I'm just gonna check the connections and give it a shot later. If the problem persists I guess I will be calling DDMtuning.... That's what I was thinking, It couldn't be the ballasts going out at the same time.
  5. Feb 16, 2012 at 8:32 AM
    Pugga
    Massachusetts
    You can get another relay from an autoparts store really cheap. If you think it's the relay, I'd just buy a new one and not waste the time dealing with DDM Tuning and their legendary customer service.
    Start simple though, double check your connections and make sure nothing is loose. With electrical work, it's usually best to start with the simple stuff, then moving down the line to the other hardware items.
  6. Feb 16, 2012 at 8:36 AM
    krimson
    krimson [OP] Nothin
    TRD Off Road
    Is there a specific type of relay I should get? Or they're all the same?
  7. Feb 16, 2012 at 8:43 AM
    Pugga
    Massachusetts
    Automotive relays are generally the same. Some are rated for more amperage than others though. The old relay should have a rating on it somewhere, just get one with the same or higher rating and you'll be good to go. I don't know what DDM uses for relays in their kit, but chances are the auto store relay will look a lot less fancy, they're just a black plastic box with copper prongs sticking out the bottom. I think the ones I've been using are made by Bosch (I don't really pay attention to the brand to be honest).
  8. Feb 16, 2012 at 8:59 AM
    krimson
    krimson [OP] Nothin
    TRD Off Road
    Thanks man, I'll give it a shot and let you know what the outcome will be...
  9. Feb 16, 2012 at 11:08 AM
    Cajun1
    Cajun1 Well-Known Member
    Brooks
    Abbeville, LA
    Brush Gaurd 265 Destinations 5100's @ 1.75 LED Lighting Center console Home made Saatchi DDM 5K HID
    dont call DDM..they SUCK...i had a set and had the same problem...one thing to do is check to see if your ballast are on...if so...it's something with the connection between the ballast and bulb...of just that the bulb is bad...more than likely because it got real hot...or moisture got into the houseing b/c the seal wasnt good...which was my case b/c the H10 or a bitch to get in
  10. Feb 16, 2012 at 12:05 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    Crap parts are crap, and relays are no different. Panasonic, Omron, and Tyco/Bosch are good parts. Most random PNP kits are not supplied with good parts, as far as I know.
    Your best bet for fixing your fog lights is to remove that PNP kit and install factory halogens. You'd be doing everyone a favor. :)
