H4 for headlight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coach23, Nov 17, 2019.
  1. Nov 17, 2019 at 6:13 AM
    coach23
    coach23 [OP] Active Member
    Sorry for the double post.
    Just want to know if its ok to use H4 on the headlights.
    I know its an H11, but I have read some links that it is ok.
    Wasnt sure if its ok on 2015 Tacoma
  2. Nov 17, 2019 at 6:16 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Nov 17, 2019 at 6:32 AM
    4xdog
    4xdog Well-Known Member
    Saint Louis MO
    2003 Tacoma DC 4WD TRD, 2015 Tacoma DC 4x4 TRD, 2008 Lexus RX350, 1962 Triumph TR3B
    The headlamps on my 2015 Tacoma use H4 or HB2/9003 bulbs, not H11. H4 is not interchangeable with H11.
    HB2/9003 and H4 are insignificantly different, IMO. I run H4 bulbs in my truck.
  4. Nov 17, 2019 at 6:40 AM
    coach23
    Let me clarify.
    I have a 2015 2.7 SR5. Standard halogen lamp headlights.
    I looked up the bulb list for the truck as I was looking to upgrade the stock bulbs and I found that the size is listed as H11.
    My friend had some new H4 Philips Diamond vision bulbs. If I am not mistaken there is no physical difference and I also read they are somewhat interchangeable.
    I wasnt sure and tried searching, but find nothing.
    Sounds like its prob not a good idea.
  5. Nov 17, 2019 at 6:53 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    The harnesses are not even the same to connect the lights
  6. Nov 17, 2019 at 6:56 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    2015 Tacoma uses a 9003/H4 headlight. Whatever source you are looking at that says H11 is wrong. 2016+ takes H11.
    Dimond Vision and other blue coated bulbs reduce output. The bulb you mentioned will work, light color will be whiter, but output will be lower than stock.
    LAMCKMA007 likes this.
  7. Nov 17, 2019 at 6:57 AM
    coach23
    100% exactly the same. 3 prong. It fits perfectly. Seems to work....but I am nervous about effects I may be missing.
  8. Nov 17, 2019 at 7:00 AM
    coach23
    My apologies folks. I am complete idiot.
    Yes. The bulb is 9003. The new one is H4.
    And yes, supposedly they are interchangeable.
    Deepest apologies to everyone.
  9. Nov 17, 2019 at 7:03 AM
    4xdog
    Saint Louis MO
    The bulbs for your 2015 are shown on p536 of your owners manual. It doesn't take much searching to find that.
    https://www.toyota.com/t3Portal/document/om-s/OM04009U/pdf/OM04009U.pdf
    In all seriousness, if you're this out of touch with details like this, a dealer or mechanic is your best bet.
  10. Nov 17, 2019 at 7:04 AM
    coach23
    Again, my apologies.
    First Tacoma. Bought it used and didnt come with a manual.
    Just trying to learn.
    gasgasman and 4xdog like this.
  11. Nov 17, 2019 at 7:06 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    9003 and H4 are interchangeable, just slightly different specs for output tolerances.
    gotoman1969 likes this.
  12. Nov 17, 2019 at 7:29 AM
    coach23
    @ crash.
    I agree the light output is less. Going back to stock.
    Any suggestions for a whiter bright light than stock?
    In the past I have tried LED, but in halogen lamps they blind oncoming traffic way too much.
    That was a couple of years ago....not sure if LED technology has changed to help that.
    Bulbfacts.com shows a few LED brands that apparently work well in halogens housings.
    This subject I did find. And a boatload of different opinions.
    Any suggestions?
  13. Nov 17, 2019 at 7:35 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Why not get some Silverstars?
  14. Nov 17, 2019 at 7:39 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    All the headlight data on output and color temp options is in the 2nd Gen headlight thread mentioned earlier, scroll down to the output charts.
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    Philips Racing Vision +150 H4 is the whitest output and highest stock wattage output without coating the low beam filament to negatively affect performance. It does coat the high beam though.
    LEDs have improved but still create irregular patterns and glare.
  15. Nov 17, 2019 at 8:54 AM
    coach23
    Crash,
    If I am understanding the lighting post correctly, the Philips CAN be used with a stock wiring harness and will not run too hot for housing....correct?
  16. Nov 17, 2019 at 3:21 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Nice bulbs , I might just have to get them . Which fogs then would go with those you think ?
  17. Nov 17, 2019 at 3:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Go Hawks!
    Correct, they are stock wattage.
    Dedicated fog upgrade thread is here:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    Rigid Selective Yellow SAE fogs is what I would recommend:
  18. Nov 17, 2019 at 4:10 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Headlight 9003/h4 fog light h11
