Had automatic headlight kit installed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalimited, Feb 16, 2013.
  1. Feb 16, 2013 at 11:09 AM
    tacomalimited
    tacomalimited [OP] Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
  2. Feb 16, 2013 at 12:05 PM
    getfit74
    getfit74 Member
    Tennessee
    12 Tacoma TRD DC Sport
    Westin Bull Bar, Weather Tech Floor mats, Weather Tech Vent Visors
    I'll have to check into that, coming from a 2004 Silverado the auto headlights is one feature i miss.
  3. Feb 16, 2013 at 12:23 PM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Is there only 1 way to install it or does it have a few installation options
    Great price too.
  4. Feb 16, 2013 at 12:35 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Interesting. I wouldn't do it now with HID's but I really like the idea!
  5. Feb 16, 2013 at 2:51 PM
    tacomalimited
    Northern NJ
    There is a few different ways to install it.You can have them come on with your wipers, with the ignition, drl.I chose to only have my headlights come on at night, nothing else. I couldn't be happier!
  6. Feb 18, 2013 at 11:47 AM
    grhopper
    grhopper Well-Known Member
    Louisiana
    2012 DCLB TRD Sport
    Did you install it yourself, or did you have a shop install it?
  7. Feb 18, 2013 at 12:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It has an adjustable turn-off delay, so you can prevent short-cycling the burners.
    My issue with the autos on my Silverado was that in California, we have to have our lights on when it is raining enough for the wipers to be running continuous.
    Problem is, in California, there can still be plenty of sunlight through a decent rain.
    I ended up tossing a ballcap over the sensor. It allowed enough light through to shut off during the day, but they popped on when it was overcast.
    This system apparently avoids that issue by automatically turning on with the wipers.
    Personally? It's dark when I leave for work in the morning, and until March, it's going to be dark when I get home. I just turn them on when I get in the truck. The way the Tacoma is wired, they can be left on 24/7, but if you do a lot of driving during the day it's a bit of a waste.
  8. Feb 18, 2013 at 12:16 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ewww....
    Never mind.
    According to one review, it turns the headlights on as DRLs during the day.
    If it's a reduced voltage, it won't work for HID.
    If it's full brightness, may as well save the money and just leave your lights on 24/7.
  9. Feb 18, 2013 at 12:39 PM
    grhopper
    Louisiana
    2012 DCLB TRD Sport
    I looks like it comes set up as DRL, but if you don't want to run it that way, all you have to do is snip 1 wire.
    http://www.directeddealers.com/manu..._545T_OK-7I_to_current_Installation_Guide.pdf
  10. Feb 18, 2013 at 1:35 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    sub'd.
    Sold my 2004 audi a4 and have a 2013 dcsb. I really miss auto on lights at night. I think I want them come on when its dark, off when light, and be able to use the bypass switch. The need for the bypass switch is the lack of the light stalk thing having a "auto" option. Audi had off, auto on, parking lights, full on.
    I'll watch this thread.
  11. Feb 18, 2013 at 1:43 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Looks like a good option
  12. Feb 18, 2013 at 1:46 PM
    tacomalimited
    Northern NJ
    No.I had a shop install it. They never heard of it until I told them about it, but, it's made by Directed Electronics, and, since their a Directed Electronics dealer, they had no problems getting it.It was the first one they ever did,they said it was very simple!
  13. Feb 18, 2013 at 1:55 PM
    tacomalimited
    Northern NJ
    I leave my drl on all the time, (Thats what i did,i'm not using the kit for drl i told them to snip that wire)at night when it's dark, my headlights automatically turn on, even though my stalk is on drl.Now I never have to do anything with my lights, its perfect! It also has a toggle switch to shut it off if you want.I didnt want my headlights to come on with my wipers, because, I thought, if its daylight & it's only raining a little and I only need my wipers every few minutes, I didn't want my headlights turning on and off.I can always overide the kit and just turn my headlights on manually to if I want.
  14. Feb 18, 2013 at 2:43 PM
    grhopper
    Louisiana
    2012 DCLB TRD Sport
    How much did it cost to have it installed? I might give installing it myself a try, unless it's cheap to have it installed.
  15. Feb 18, 2013 at 2:49 PM
    Pugga
    Massachusetts
    Even at reduced voltage, wouldn't it still work for HID's if you use a harness similar to what TRS provides? The headlight circuit is only used to trigger a relay, the power is drawn elsewhere.
    Even with the delay, I still wouldn't want this type of kit for HID. It'd still cycle the HID's on and off much more frequently than when under manual operation and might not leave them on long enough to get warmed up properly before cutting the power.
  16. Feb 18, 2013 at 3:02 PM
    Agro
    San Diego
    I may talk to my local shop and see if they ca. 2 for 1 -- remove my dealer installed KARR alarm and install this. My guess is 125 for both.
    Both of which I can do. But lazy. Ill see
  17. Feb 18, 2013 at 6:19 PM
    tacomalimited
    Northern NJ
    $192, it might be a little high, but this was the first one they ever did, and, I stressed to them that I wanted it to be a neat clean install, and it was, so, I had no problem paying it.
  18. Feb 18, 2013 at 7:37 PM
    Agro
    San Diego
    Read about Directed Electronics and they are the makers of Viper Alarms. I never had one of those, but I've known of them and they have been solid for years. So I feel good about this unit. They are in Vista, CA (the city directly next to mine), but I dont think they bother with end-users. I'll find a stereo shop real close to them and see about purchasing, installing and removing the KARR. Will report back in to this thread later.
  19. Mar 19, 2013 at 12:09 PM
    BeEatNU
    BeEatNU Well-Known Member
    Nick
    Gardena, CA
    2013 Tacoma Double Cab Limited
    I loved my viper alarm!
    When i sold my other car, I didn't install it into my BMW but I do plan on putting one on for my taco.
    hmmm now that I know they make viper, I may be interested in picking this up.
  20. Mar 19, 2013 at 1:18 PM
    Agro
    San Diego
    Funny this thread got resurrected today.
    I bought the 545T but have concerns before I have it installed at my local DEI dealer. I was hoping to speak to the OP, I sent him a PM.
    The instruction manual is written by someone who has lots of experience with this unit and so while I think it is pretty complete, it is vague for someone like myself that has never used it.
