Hail Damage, fix or roof rack?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CpuPirate, May 1, 2014.
  1. May 2, 2014 at 4:36 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    under insurance you should get a new hood (can't usually fix) and they'd pull/cut the roof panel between the two seams and replace. The rubber seams would cover the welds. The pther dents would be pulled out by machine [or pdr if possible.]
    Would roof rack be a mileage hog? But if you decide to go with one, if hail came again it'd protect the roof-a good thing. Check below:
    http://www.tacomaworld.com/forum/2n...amage-added-more-pictures.html?highlight=hail
  2. May 2, 2014 at 8:29 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    What OCNutty said is correct. I just had $8000 in damage due to hail. The hood was replaced. For the roof they take the rubber molding off of the roof. Underneath the molding you will find the welds that hold the roof on which they grind off. After the welds are ground off they cut the roof off of the truck. When they replace the roof it is not welded on it is glued on. They showed me the glue that is used and the testing that it has gone through. it actually is stronger then the welds. All the rest of the dents in the truck are taken out with pdr. On my truck no bondo was used. The check was made out to me and the collision repair company. Good luck on your decision
  3. May 2, 2014 at 9:37 AM
    TCprerunner
    TCprerunner Well-Known Member
    I never said that it could be done on anything. I said he was over estimating how often filler was used for hail repairs.. I don't see why we are arguing this though? The only point I was trying to make is that he needed to go to another shop if they wanted to use filler on all the dents... There are many other options..
  4. May 2, 2014 at 10:14 AM
    mmarino
    mmarino Well-Known Member
    Northwest
    13 TRD OR
    OME Suspension with Dakars, NWTI bumpers, BAMF Sliders, Color matched grill, Centruy cap, Relentless Hi-Lift Bracket, HID headlights & foglights, PIAA fogs, 42" Rampage radius LED bar, Wet okole seat covers, Console & glove box organizers, AFE pro dry filter
    A friend of mine had his FJ hood and roof destroyed by a nasty hail storm. His insurance paid for PDR and his truck looks brand new.
  5. May 2, 2014 at 10:59 AM
    CpuPirate
    CpuPirate [OP] Active Member
    Wilson, NC
    2014 MGM DBSB TRD/OR
    Thanks for the responses guys, I think I will get an estimate at the dealer as well as from the ins company, I don't mind replacing the roof as I want to get some other things painted anyway ( bumper and grille) and I would just pay the extra when they do it, im just not a fan of body filler.
  6. May 2, 2014 at 11:21 AM
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    panoramic sunroof? Will remove most of the damaged area.
  7. May 2, 2014 at 12:22 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hail sucks. I live in Dallas and every spring we're having to dodge a storm. Golf-ball sized hail and larger will destroy a car.
  8. May 2, 2014 at 12:25 PM
    TCprerunner
    Yeah we got hammered here in Denton.. Totaled a few of my friends cars/trucks I got lucky and only had like 3k in damage waiting to pay off the truck to claim it though
  9. May 2, 2014 at 12:40 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Don't fret OP earlier this week a shopping cart traveling downhill smashed my door...that thing got some speed, getting it pdr-ed saturday :(
    Mother nature<idiot shoppers
  10. May 2, 2014 at 12:46 PM
    CpuPirate
    Wilson, NC
    Sucks Tash, post some pics before and after I want to see the work
  11. May 2, 2014 at 12:48 PM
    ThomasMore66
    I'm in Flower Mound. You guys did get pounded. Denton is the closest town to me in a straight line. I don't know how you got it so bad, and we missed that last one. If my paycheck didn't stop here, I'd be in Colorado. Kinda keen to keep the paycheck...
  12. May 2, 2014 at 3:24 PM
    TCprerunner
    Me and my wife's work got hammered. Our house on the other side of town still had golf ball size hail bit not the base balls we got at work.. I parked beside a simi and it blocked most of them thank god . that said I love it here... We get every type of weather possible. Only thing that sucks are the draughts
  13. May 2, 2014 at 6:02 PM
    SlickDuck
    SlickDuck Well-Known Member
    Greg
    Southern WV
    09 DC MGM TRD Offroad
    I had a great deal of hail damage on the hood and roof my first gen several years ago. My insurance company wrote me a check for repairs, but so many vehicles were damaged that day that the wait to get in a shop was several weeks. As the days passed waiting for my appointment, summer temps began to rise in the afternoon. For several days I could hear the dents pop out every time I drove out to lunch, especially if I hit a bump. Before my appointment rolled around I only had one dent left, and some extra cash.
  14. May 3, 2014 at 5:13 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I didn't know that. What's the reason?
  15. May 3, 2014 at 5:33 AM
    #35
    xbxb
    Jim
    O.P. Kansas
    PDR works better and if there is significant damage it's cheaper in the long run to take the roof off. I'd rather have a new roof anyway.
  16. May 3, 2014 at 5:37 AM
    #36
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
  17. May 5, 2014 at 9:25 PM
    #37
    TashcomerTexas
    Got it done saturday forgot to post pic. Here ya go
    Thanks to Concourse auto salon in San Antonio, Tx looks good as new
  18. May 6, 2014 at 12:11 PM
    #38
    CpuPirate
    Wilson, NC
    That looks great Tash, glad it came out alright, my ins adjuster recommended a few PDR shops here in town so im going to get some estimates.
  19. May 6, 2014 at 12:35 PM
    #39
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Agreed, they could always pop a deep dent with a stud welder and skim it, that wouldn't scare me at all. Its not like when you were a kid and gobbed the stuff in a hole to fill it up.
    PDR... had it done 1/2 dozen times, these guys are amazing.. again, no reason to be afraid of this.
