Halo Projector Headlights Need Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KevinJClark, Sep 24, 2012.
  1. Sep 24, 2012 at 8:45 PM
    KevinJClark
    KevinJClark [OP] Member
    Kevin
    Citrus County, Fl.
    Tacoma Double Cab Lifted
    6 inch ProComp Suspension Lift Leather Seats 35x12.50 Nitto Trail Grapplers Dual Flomaster Exhaust L.E.D Tail Lights L.E.D's installed inside cab UnderCover Bed Cover
    I bought the black halo projector headlights for my 2007 tacoma and they will be here tomorrow. I have all the wiring preped for the l.e.d parts of the headlights but my real question is can i run the silver star blubs that were in my stock headlights in the new ones?!
  2. Sep 24, 2012 at 8:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No.
    Your stock lamps are 9003/H4, most eGay projectors use four H1 lamps.
  3. Sep 24, 2012 at 8:54 PM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    What Rich said!!
  4. Sep 24, 2012 at 8:55 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Snap Rich, you're quick tonight
  5. Sep 24, 2012 at 8:58 PM
    KevinJClark
    Kevin
    Citrus County, Fl.
    thanks guys. will there be a bulb in these headlights and if so is there a certain way i connect them...or am i going to have to spend some more money like I'm guessing..
  6. Sep 24, 2012 at 9:00 PM
    Rascal737
    Oliver
    Abbotsford, BC
  7. Sep 24, 2012 at 9:00 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    They normally ship with lamps.
    The wiring is a bit different, but they should have the adapters to connect to your harness without cutting and splicing.
    Rascal and Moose had sets that they ultimately did projector retrofits because these things suck so badly, even with HID burners.
  8. Sep 24, 2012 at 9:01 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I don't know what you bought but my honest and non-sarcastic advice would be to return it and get in on the group buy that theretrofitsource (TRS) is putting on right now. Best product, best cutoff and best customer service in the aftermarket lighting business that I know of :D good luck with whatever you do.
  9. Sep 24, 2012 at 9:11 PM
    KevinJClark
    Kevin
    Citrus County, Fl.
    Like I said before thanks guys for all the help! They'll be here tomorrow I'll take a look at em and if it all dosnt work out, thats what the return policy is for haha. thanks again!
  10. Sep 24, 2012 at 10:43 PM
    ScottyP2448
    ScottyP2448 Well-Known Member
    Scott
    Alabama
    07 Taco 33s.Rockstars. 3 Inch Toytech Ultimat
    17 Inch Wheels, 33 Inch Mickey Thompsons
    There are already bulbs in them. My eGay lights were simple plug and play after wiring up the halos and LEDs
