Ham fisted mechanics and skid plates
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aaen, Jan 14, 2020.
  1. Jan 14, 2020 at 12:46 PM
    aaen
    aaen [OP] Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    So last time i had my truck in for a service at a lube shop, yeah I know, I was in a hurry and it was cold out so I wasn't;t doing my own.
    The mechanics removed the skid plate to drain the oil as they didn't have an oil sucker to go through the dip stick like most modern shops. Not a big deal, shit happens. However when they put it back on they cross threaded a bunch of the bolts/nuts and i have since lost one bolt and another is probably due to come out here soon, a third its threaded into the nut, but I am pretty sure the nut has broken free of the frame or however they are held on as I can push the bolt up and it moves but wont't come out.
    Anyways, anyone have this issue before? If so how are you fixing it? Retapping? Any threads on this on here? I didn't see any in my search, but my google fu is lacking these days.
    Thanks
    bigmw likes this.
  2. Jan 14, 2020 at 12:51 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I forget how they're mounted, but I'd probably drill em out and JB weld a rivenut in there.
    ETA: compress the rivenut as well.
  3. Jan 14, 2020 at 12:52 PM
    aaen
    Northern Alberta
    Good think is my bolt is nor broken in there just no threads in a few of them. I will need to start digging into the service manuals and see what i can find. Seems to be a big problem with a lot of other peeps on here as well.
  4. Jan 14, 2020 at 12:54 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I believe the stock ones are rivenuts.
  5. Jan 14, 2020 at 1:15 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I would try to retap them if you have the tools.
    Superdave1.0 likes this.
  6. Jan 14, 2020 at 1:47 PM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    Only the TRD pro skid plate has a removable panel for the filter. My sport skidplate had to come off for oil changes. Not a very smart design
    The nuts for the skid plates are just tack welded so it's pretty common for them to break. Drill the bolts out and replace nuts with rivnuts is probably easiest route
    Gunshot-6A, Junkhead and Skydvrr like this.
  7. Jan 14, 2020 at 2:08 PM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    Get a pro skid plate. It uses different mounting holes.
    GreyBaldTaco likes this.
  8. Jan 14, 2020 at 4:02 PM
    TRDCal
    Canada
    2018 DCSB Sport MT
    Oh I see...I dont know how you could f*** it up that bad either, theres hooks on the fwd side the hold half the weight while you thread the bolts in! It's a wonder how these people even figure out how to put pants on in the morning
  9. Jan 14, 2020 at 4:15 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Hopefully they didn’t strip out your oil pan bolt.
    nartmot, Skydvrr and shakerhood like this.
  10. Jan 14, 2020 at 4:55 PM
    MaHoTex
    MaHoTex Well-Known Member
    2019 Silver Tacoma TRD Sport
    From what I understand, this isn't an option if you have a front air dam and wish to keep it.
  11. Jan 14, 2020 at 5:56 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Ive seen a picture around here of someone that made it work.
  12. Jan 14, 2020 at 6:05 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Don’t take this the wrong way but what crappy skid do you have that uses whimpy bolts? My skid is held in place with large grade 8 bolts...
    Most aftermarket skids come with a removable panel. Your sport doesn’t have a skid plate, it’s a splash guard.
    GreyBaldTaco and Hobbs like this.
  13. Jan 14, 2020 at 6:06 PM
    Bishop84
    Bishop84 Well-Known Member
    You don't suck the oil out the top of Tacoma, there is no benefit, the filter is underneath.
    The suck method is for german cars and DIY'ers, not a Toyota shop.
    TireFire and JoeCOVA like this.
  14. Jan 14, 2020 at 6:10 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Why aren't you calling the shop and have them fix it or pay for the fix?
    Boghog1 and GreyBaldTaco like this.
  15. Jan 14, 2020 at 6:13 PM
    TRDCal
    Canada
    2018 DCSB Sport MT
    Yah we got this all sorted out there Joe
    JoeCOVA[QUOTED] likes this.
  16. Jan 14, 2020 at 6:14 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I prefer to think of myself as a sausage fingered mechanic, not a ham fisted mechanic.
    Cut off the bolt that is spinning. Remove the nuts that can't be salvaged by a tap and install rivnuts. Pick up some factory bolts to replace the damaged one. Nothing worse than 2 or 3 different socket sizes need to to remove one small piece. Use neversieze on the hardware when installing and stop going to quick lubes. They aren't mechanics, the ones I know that worked at places like that barely qualified as 8th grader's! ( last grade in school not age )
    elmontemike likes this.
  17. Jan 14, 2020 at 6:53 PM
    MaHoTex
    If I could do that I would change it tomorrow.
  18. Jan 14, 2020 at 7:07 PM
    Iwilltaco
    Under development
    It was in a discussion about removing the chin spoiler or not. If I come across it I’ll post it. Basically just notched out the plastic where the skid had to come through.
  19. Jan 14, 2020 at 7:09 PM
    Iwilltaco
    Under development
  20. Jan 14, 2020 at 7:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    First of all, the "skid" you talk about covers the oil filter housing, not the engine. Vacuum extractor or not, the mechanic still needs to remove the skid to replace the filter.
    The skid attaches to two removable braces. Each brace is bolted to the frame with 3-4 bolts. It's a simple matter to replace them. P/Ns are 5140304020 and 5140404020. The braces are removed for installing aftermarket skids from Relentless, All-Pro, RCI, etc. They're carryover from 2nd gens so plenty of used ones around.
    elmontemike, Mike O and Junkhead like this.
