Ham Radio Install 2012 TRD AC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmich2001, Dec 27, 2013.
  1. Dec 27, 2013 at 2:15 PM
    jmich2001
    jmich2001 [OP] Well-Known Member
    Toms River, NJ
    12 Access Cab TRD OR
    Yellow Fog Lamps, Ham Radio
    Wanted to share some photos of the wouxon 920 and comet SBB5 antenna install.
    The coax is marine-grade RG8X with Shakespeare solder-
    less PL-259's that were a snap to put on and tested perfect on Diamond SWR meter on both bands. Used existing grommet under passenger seat. I will place remainder of coax in split-loom all the way to the grommet soon. Radio is powered by 12GA directly to fused battery terminals and main chassis ground.
    Toyota bed rail system is screwed to body panel but I added the ground strap as good measure. Frame is Fluid Filmed.
    KC2ZEZ Technician class
  2. Dec 27, 2013 at 2:16 PM
    Large
    Large Red
    I wouldn't think that bolt in the back would suffice as a grounding point but if it works, what do I know. :) Good job.
  3. Dec 27, 2013 at 3:06 PM
    jmich2001
    Toms River, NJ
    Grommet under passenger seat.
  4. Dec 27, 2013 at 4:46 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The bed rails are well grounded they are not screwed into the plastic and the bolts at the tail gate are excellent grounds also that's where my tri band antenna is mounted on an aluminum angle. Do not fret too much about ground planes it will keep you up at night, bottom line vehicles are terrible ground planes no matter what you ground or how many ground wires you run, as long as you have a good return patch to the radio via the coax shield you’re smiling.
  5. Dec 27, 2013 at 7:43 PM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    nice!! KD0JXB 73
  6. Dec 27, 2013 at 7:47 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Looks good! 73s
    KK6CHD
  7. Dec 28, 2013 at 5:12 AM
    east
    east Well-Known Member
    S.E. N.C.
    Stock 4x4
    Nice install and thanks for the post and pictures. I need to get motivated and install my equipment in my truck. Are you going to do an hf radio as well ? I have an Icom IC 7000 that I want to install in my truck. K0bg.com is a good resource for info on mobile radio installs.
    Thanks, Eric
  8. Dec 28, 2013 at 8:35 AM
    rtn1911
    rtn1911 Well-Known Member
    Richard
    CA
    2013 MGM 4x4
    Looks good!
    My rig is a Kenwood 50W dual bander with a Larsen NMO 1/2 wave antenna. I bonded - grounded -- the bed rails to each other, and have my antenna on the left rear corner. Similar mount that I made with 3" x 1/4" angle aluminum, also ground to the rails. Direct wired to battery at both POS and NEG. I've had excellent performance with no reports of noise or picket fencing, etc.
    73, K6RTN
  9. Dec 28, 2013 at 8:36 AM
    rtn1911
    Richard
    CA
    2013 MGM 4x4
    Agreed!
  10. Dec 28, 2013 at 9:30 AM
    jmich2001
    Toms River, NJ
    No HF.
  11. Jan 4, 2014 at 8:11 PM
    JKD
    JKD Well-Known Member
    How is the radio chassis secured?
    I still haven't finished installing my tm-v7a... but I am putting the chassis under the console where the ac inverter would be if my truck had one.
  12. Jan 29, 2014 at 9:34 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Radio looks good, I just installed my FT-7900 last week.
    73
  13. Jan 29, 2014 at 1:14 PM
    jmich2001
    Toms River, NJ
    The chassis is secured with the hook part of velcro to the carpet to keep it from sliding around.
