Hand Truck Dolly Rack....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Aug 15, 2009.
  1. Aug 15, 2009 at 9:11 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    OK, so I'm looking for something that can carry my hand truck via the hitch receiver without it taking up bed space. I think there are likely bike racks that could do this....but I am surprised to see no hitch mounted hand truck dolly carriers. I've looked everywhere on the internet. Am I wrong? Has anyone seen one of these?
  2. Aug 15, 2009 at 9:14 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Never seen one, but you could make it pretty easily if you have access to a welder. Box to slide into the receiver with a bracket below to hold the foot of the hand truck, then a simple frame to strap the top end to. I have seen a similar rack on big trucks welded to the front bumper, Coca Cola used to do it.
  3. Sep 1, 2009 at 6:25 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    With all the loading and unloading taking my two girls to college, home, and back again, I decided to get a lightweight resin hand truck dolly (Harper, 600 lbs capacity) to free up space in the truck bed. I bought a $40 truck bed extender support (Harbor Freight) and turned it upside down. Put pads in the top support bracket and used a Hitch-Vise and Master Lock hitch pin to secure it. It's solid as hell and doesn't sway or move at all. The Hitch Vise works extremely well at taking all movement out of the device. Nothing on this device touches the truck or bumber. I will likely use a short bungee cord to secure the handle to the bracket but I haven't yet decided how to support the axle against the support arm, although a short bungee would work here as well (blue tape is to mark where I am going to put a small pad to keep the axle from rattling and scratching the support arm). I will use a Masterlock combination cable lock to provide some security against easy theft of the hand truck. Oh, I had to drill 5/8" holes in the support arm that goes into the receiver to have hitch pin holes line up with the Tacoma's receiver.
  4. Sep 1, 2009 at 8:49 AM
    monrad
    monrad Coprolite
    B'wood, SC
    09 DC short box TRD Sport, TM
    Avid light bar+RBG, Lightforce 140s, fog mod, FSM badges, Bobcatoshi grille + Stampede, JDM DRLs, TRD cat-back, rear spring TSB, AccessLE
    Great idea! Very clever to shove the support arm into the receiver. Wish I'd had one of these when I was dragging my girls' stuff to/from university twice a year for eight years. I can see advantages, like dual-purpose use of the load extender and cost, of using this rig over a hitch-mounted cargo platform.
    What's the padded channel in the last pic? For the dolly axle?
  5. Sep 1, 2009 at 9:01 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Wow, maybe you should look into a patent for that!!
    Nice Job!! Well Done!!
    :thumbsup:
  6. Sep 1, 2009 at 9:05 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I lowered it a bit so the tires rest against the plastic top of the bumper, tied it down with bungee cords and threaded Masterlock combi cable lock through the backup chain holes on either side of the receiver. I am going to put self-adhesive reflective tape on it as well. This thing is now rock solid but very easy to get dolly off and remove entire unit to access the truck bed. (The prior picture was of the padded support bracket at the top which the dolly handle rests on.)
  7. Sep 1, 2009 at 10:00 AM
    monrad
    monrad Coprolite
    B'wood, SC
    Ahh, so the piece of channel is part of the Harbor Freight package? Looks like I'll be heading to HF this pm.
    Only thing I'd consider is something to keep the dolly wheels from scuffing the plastic bumper. On the other hand, I guess it is a truck...
    BTW, nice Parkway plate. :)
  8. Sep 1, 2009 at 10:07 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yes, the bracket comes with it - it's welded to the top of the support arm (not very visible in the HF pic). Let me post a picture of what I bought before you run to HF. The box had HF's name on it, but I bought it from someway on Ebay. I added some self-adhesive pads to the inside channel of the bracket - which you can see in the picture - to pad it.
    Yep, found it on Harbor Freights web site....same price I paid. If you study the product pic on HF's web site and then look at my setup, you will see what I did......you don't use the cross bar at the top, just the two other pieces that fit together.....now, you can always use the product for the purpose it was intended as well :)
    http://www.harborfreight.com/cpi/ct...cpc&zmam=33951326&zmas=12&zmac=112&zmap=39168
  9. Sep 1, 2009 at 10:15 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Don't worry about the tires rubbing against the bumper. First, the tires are touching only the plastic top to the lower part of the step bumper. Second, the bungee cords keep this thing pulled very tight....I don't think the tires will even move at all, so no rubbing. If you don't like it this way, you can just raise the support arm (see my first pics before I lowered it). I figured basic physics would simply make the support arm all that much stronger if it was shorter. That was really the only reason I lowered it.
  10. Sep 1, 2009 at 10:39 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Any problem with cops and the obstructed license plate? In some states that's a ticket. Not flaming, just curious.
  11. Sep 1, 2009 at 10:45 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yeah, I thought of that...I'll have to check in NC, but I figured it was one I should be able to talk my way out of......if there was ever a reason for leniency. :):):)
  12. Sep 1, 2009 at 11:36 AM
    monrad
    monrad Coprolite
    B'wood, SC
    Yeah, just have your daughter start crying. Works every time.
    I see that the various pieces of tubing telescope together. All makes sense now.
  13. Sep 1, 2009 at 11:49 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    Nice job Phil,love seeing that kind of ingenuity.......One question:
    How the HELL do you keep your garage so clean?
    :D
  14. Sep 1, 2009 at 11:56 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    (1), it's my room, so I keep the women out of it - not hard to do, (2) The built in cabinets work wonders for hiding all the mess!!!!
  15. Sep 3, 2009 at 5:34 PM
    squad314
    Marc
    I try....Lord knows that I try but I'm drowning in a sea of bikes,scooters,lacrosse and hockey sticks,skipping ropes and tiny pieces of driveway chalk.:eek:
  16. Sep 3, 2009 at 5:41 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Oh I hear you Squad.....we are empty nesters now so it's a bit easier.....I got rid of most of the junk they accumulated but never touched. The floor was painted (not well) by the prior owner. I plan to have it sanded and redone with epoxy....the prior owner coudn't screw in a light bulb if you gave him instructions. All he did was suck off his wife's family inheritance and golf. I've been fixing and cleaning up after him for 3 years. Almost done. Having a clean garage can be had with only two things: cabinets to hide the crap, and a painted floor. :D
  17. Feb 1, 2012 at 7:09 PM
    Toyotaguyfrom1000
    Toyotaguyfrom1000 New Member
