Hankook vs. Geolander AT tires
Discussion in 'Wheels & Tires' started by dbarn, May 5, 2010.
  1. May 5, 2010 at 4:54 AM
    dbarn
    dbarn [OP] Well-Known Member
    Texas
    Tacoma 4X4 V6
    Getting really close to purchasing some AT tires. Looking at a set of 265/75/16. It will be between one of these two, this much has been decided. Of the two, which one has the best street ride and which one wears more slowly? Which one offers the most bang for the buck? Please chime in if you owned either for any length of time. Thanks.
  2. May 5, 2010 at 9:21 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I've had the hankooks for 10000 miles. Littl to no road noise, and no sign of wear.
  3. May 5, 2010 at 9:36 AM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    Had Yokohama Geolander A/T-S on my last rig (F150 supercrew). Excellent tire. Nice and quiet on the road. Living in the Northwest it handles rain, black ice, light snow and light mud very well. Had them for about 3 years with a little over 10,000 miles. Wear appeared to be minimal. Price was also good. The Tire Rack rated these tires in the upper end of all terrain tires. Bought mine through Discount Tire (they price matched the Tire Rack).
    Good luck on your decision. Ken
  4. May 5, 2010 at 9:45 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    3K on the Hankooks. As mentioned above, very quiet, very smooth, minimal weight to balance and you can still see where the "nipples" on the tread blocks were after 3K miles. Had my Prerunner in snow deep enuf to leave a track from the diff dragging 2 weeks ago. Just a hint of wheel spin w/o the diff lock. No spin w/diff lock.......
  5. May 5, 2010 at 10:42 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    Thanks guys, this is going to be a tough decision. Please keep the responses coming. They both appear to be a good value and have heard very little negative if any regarding either.
  6. May 5, 2010 at 10:47 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    +4 for Hankook ATM
  7. May 5, 2010 at 11:58 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    The Hankooks are known for their light weight. For hauling and such are they load rated equivalent to the Geolander?
  8. May 7, 2010 at 11:18 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    Bump. Any more thoughts advantages over the other?
  9. May 7, 2010 at 11:27 AM
    maconhurler
    maconhurler Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    Ive had the Geo ATS for probably 40000 (rough estimate) and they still have significant tread remaining. They look great and ride great. Had the BFG TA before and the Geo are much quieter and smoother a ride. I cannot comment on the Hankook but the Geo has been an excellent tire for me and the price is excellent, I think I paid roughly 500 for all 4. Had them in the snow here in Virginia this year and they performed well. I have never hydroplaned with these tires either.
  10. May 7, 2010 at 11:41 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I've been running the 265/75R-16 load range E Geolandar AT-S and couldn't be happier. The road noise is minimal, and wear is excellent. I've put 36k miles on the tires so far and have very little wear to show for it. The tires also perform awesome off road. They have been put through some of the harshest dirt highways I could throw at them and hold up well. I'll snap a picture this evening if I get a chance.
  11. May 7, 2010 at 12:09 PM
    GSRON
    Ron
    Northern CA
    2019 TRD OR Cement
    I have the P265/75-16s and they have a max load/pressure of 44psi. 32psi is more than enuf to hold up the back of my access cab Prerunner. In fact it's a bit too much as there's a bit too much chalk left at the edges of the tire for perfect wear. The fronts are perfect at 36psi.....
    I considered the Geo's when I was shopping fo tires this winter there were several things that pushed me to the Hankooks...
    1. 1/2 worn out Geos have no tread blocks left in the middle. Just a solid rib of rubber to sit on top the snow, ice and dirt and spin.
    2. 2 friends who have Geo A/Ts. Both complained about tread wear and traction.
    3. Had a customer come in with 2 seperated Geos (tread was "bubbled" in places) on his truck. My shop is an installer for Tire rack.
    4. Only complaints I could find on the Hankooks were from people running "P" or "C" rated tires on 3/4 ton trucks.....
  12. May 8, 2010 at 10:40 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Blackstone, MA
    '09 Sport DCLB Met Grey
    Toyota bed mat (1st mod), Toyota all season floor mats, Rear spring TSB, Map light mod, Fog light mod, Putco yellow fog bulbs, Weather Tech window vents, Extra d-rings, Mounted mag light, TRD CAI with AFE pro dry filter, '05 front mud flaps (winter only), 2 set's of wheels/tires, 285/75/16 Hankook MT's, Black Painted 1st Gen TRD wheels (wheeling set) Black powder coated FJ Cruiser with 265/70/17 BFGoodrich KO2's (everyday), painted center of grill & bumper black, Devil horns, OME with 885's + spacers front, OME shocks w/OMD designed rear springs, Front diff drop, Rear trailer plug relocate, ATO IFS skid, Relentless Trans & Transfer skids, BAMF bolt on rock sliders, Relentless tailgate reinforcement, Uniden 75 CB radio, BAMF antenna bracket, TRD exhaust, high lift jack w/ATO mounts. And of course ProEFX Towing Mirrors!
    I recently bought the Hancooks because of the good reviews I saw online. Also after checking out there web site I saw that they have full depth sipes and stone ejectors. They also have a more aggressive look than the Yoko's but are VERY quite. Last two things were the 50K mileage rating and I got them for only $125 per tire :). I couldn't be happier...
  13. May 8, 2010 at 11:04 PM
    th3bigk0
    th3bigk0 GETTN IT
    Dylan
    Lamecaster
    13 TRD Double Cab
    Fox 2.5 RR C/O's,Camburg UCA,Camburg Spindles,KING 2.5,OME Dakar Leafs,285 KM2,XD HOSS 16'',BHLM,HID's,CB,Hornblasters Shocker 540 train horn,KICKER 12 ported....
    I run hankooks and I probably will stick with this tire for a while.they do great off road and on road.with no road noise,and I'm running 33x12.50s
  14. May 9, 2010 at 7:43 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    I am going with the Hankooks and will order them this week. Thanks for all of the comments!
  15. May 9, 2010 at 11:14 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I have the Hankooks and I love them. I've used them on dry and wet pavement, in the middle of a rainstorm, and on dirt and gravel and they hold their own. A friend of mine has the Geos on his Taco and he likes them a lot but I think the Hankooks are much more of an AT tire.
  16. May 9, 2010 at 11:24 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2...Cmack has the Geos and they did great off road
    These are my Hankooks
  17. May 10, 2010 at 5:32 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    OK guys, need your help. Discount Tire is out of the 10 ply. They do have the P metric Hankook which is a 4 ply. They are saying the 10 ply is for a 3/4 ton. Which one do I want??
  18. May 10, 2010 at 6:11 AM
    TexasTacoma37
    I have the P metric. I calculated it once and they are good to go up past the payload capacity of the truck. LT is overkill unless you are doing a lot of heavy towing.
  19. May 10, 2010 at 6:54 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    Thank you.
  20. May 10, 2010 at 8:35 AM
    gobias
    02 Dbl TRD
    I have the P rated version. They work fine and have the same load capacity as the OEM tires. I'd only suggest LT if you were towing or doing a lot of off-roading.
