Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Nov 14, 2017 at 8:46 AM
    #2001
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Just go to the website and look. They have coupon on there.
  2. Nov 14, 2017 at 8:52 AM
    #2002
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Saweeeet!
  3. Nov 14, 2017 at 11:24 AM
    #2003
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Well I just bought the HF "Doyle" branded cable cutter--$15.99 w/a 20% off coupon ("Doyle" is not [yet] on the exclusion list).
    They do not seem any different than my old $6 "Pittsburgh" cutter, when I get home I'll run a file across 'em and see what the steel feels like. With the coupon they were a couple bucks less than the Wiss brand at Home Depot. Time will tell...
    Bulldogs129 likes this.
  4. Nov 15, 2017 at 7:11 AM
    #2004
    cliffyk
    Cliff
    Saint Augustine, FL
    I compared the old ("PIttsburgh") and new ("Doyle") HF cable cutters side-by-side last evening. The new tool's overall fit and finish is much improved, the forgings are much cleaner and the ground surfaces have much smoother finish. The steel is a bit harder per a quick file test. I would say they are on par with the name brand offerings--for $2 to $12 less with HF's 20% off.
    Without the coupon I would have bought the Wiss cutters ($18) at Home Depot...
    The cutting angle of the jaws is much steeper on the new tool, the older unit having much more of a shearing action--this would make the new tool less suitable for cutting steel cable as I have been doing with the old set.
    old (HF # 61422) and new (HF # 63827):
    Oh these not 10" long, they are 9-1/2" just like the "name brand" tools...
    Toyko Joe and Rakso like this.
  5. Nov 15, 2017 at 7:48 AM
    #2005
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Careful with their 3/8 Torque Wrench nd4spdbh, I have purchased 3 and ALL 3 of them have not worked out of the box. Yet I have had great luck with my 1/2 until I recently got an upgrade.
  6. Nov 15, 2017 at 9:33 AM
    #2006
    cliffyk
    Cliff
    Saint Augustine, FL
    A great tool to have is . Not for it's intended use as it is a bit awkward to use, but as a standard against which your clicker wrenches can be checked and calibrated:
    I picked one up five years ago and after validating it's accuracy with dead weight loads (also had it checked by Mac Tools a couple years ago) have used it regularly to check and adjust my clickers. To do so I clamp a 3/4" male x 1/2" female adapter in my bench vise and set the digital unit to its "peak and hold" mode; set the wrench under test (WUT) to a value central (50%) to it's range--say 90 lb·ft for a typical 1/2" drive wrench--and then pull away 'til the wrench clicks.
    If the captured torque value is within ± 2% of the setting the wrench is calibrated as well as it can be (most all clickers, even name brand, are rated at ± 4% of setting). If not then tweak the wrench's adjusting screw until it is. With that done check the wrench at 20% and 80% of its range; those values should meet the ± 4% spec. If not then once again tweak the adjusting screw and recheck the central, and high and low setting to reach a happy medium within the ± 4% accuracy that should be expected.
    When torquing something critical, or if I have not used the torque wrench for a while I will often get out the digital toll and verify the wrench before going forward.
    Here is a write-up of the device I did in early 2012. The same tool and some variants are available, in several brand names, from a number of vendors--just google "digital torque adapter"...
    Harry and RickTRDSport like this.
  7. Nov 15, 2017 at 10:40 AM
    #2007
    TacomaZL
    Illinois
    I clicked on your link CliffyK and saw you posted something about a torque limiting spark plug socket....where the hell can I get that?!?!?! That thing looks awesome!
  8. Nov 15, 2017 at 2:14 PM
    #2008
    turbomkt
    turbomkt Well-Known Member
    Santee
    '13 Sport
    CBI Offroad bumper
  9. Nov 15, 2017 at 2:18 PM
    #2009
    cliffyk
    Cliff
    Saint Augustine, FL
    eBay--this is the same brand as I have...
  10. Nov 16, 2017 at 8:06 AM
    #2010
    nd4spdbh
    SoCal
    I have thought about doing something like that!
    Question, do the HF clicker torque wrenches have the ability to be adjusted?
  11. Nov 16, 2017 at 8:40 AM
    #2011
    cliffyk
    Cliff
    Saint Augustine, FL
    Yup, yank off this rubber plug (if it's still there) and use an Allen key--use small increments and retest often during adjustment:
  12. Nov 16, 2017 at 10:36 AM
    #2012
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    After I bought my truck we started going to the gym. So one evening I was waiting for the missus and walked into Harbor Freight. I have a truck and already had a money pit. Now I needed tools for the mods. This started my obsession with my garage. I have made it into my sanctuary. Work bench, tools beer fridge even some lawn chairs and a coffee table. I spend a fair amount of time here. On Sundays I set up a TV and watch the game.
    This could be a Where’s Waldo seek and find. Can you find all the Harbor Freight tools.
    Flags from Jamaica, Ireland, Arizona and Oklahoma University. Extra points for the beer fridge.
    Where I mod… and check the mail. Oliver approved.
    The lawn chairs and “coffee table” Yup…Harbor Freight's stool.
    I have the service cart. It serves us well as a bar next to the beer fridge.
    bigfella13, TomTwo and Coolerman like this.
  13. Nov 16, 2017 at 10:53 AM
    #2013
    nd4spdbh
    SoCal
    I dont think the HF ones have that but i shall take a look when i get home! If they do im going to grab one of the digital things to calibrate my wrenches.
  14. Nov 16, 2017 at 10:58 AM
    #2014
    shieldze1025
    shieldze1025 Well-Known Member
    North Shore Oahu, HI
    2012 TRD Sport 4x4
    A sanctuary is a much needed place. Esp when you're into working on cars. We bought a house without a garage last year, I really hate not having a man cave. Decided to make the back deck a "man porch" instead, haha. I'll take it for now.
    TomTwo likes this.
  15. Nov 16, 2017 at 11:47 AM
    #2015
    cliffyk
    Cliff
    Saint Augustine, FL
    They do, that's a photo of an HF wrench. I've never seen a clicker that did not have an adjustment port...
  16. Nov 16, 2017 at 12:36 PM
    #2016
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Don't we have a shop/garage thread? Looks like a great topic to start a thread on if we don't.
  17. Nov 16, 2017 at 12:45 PM
    #2017
    Sand Shark
    Erich
    Phoenix, AZ
    We do have a thread. The missus said that we pretty much have a Harbor Freight store in the garage, so I posted here.
    https://www.tacomaworld.com/threads/show-off-your-garage-or-workshop.201114/
    It also could go in the beer thread. The beer fridge is full of Longboard Big Wave, Lagunitas Brown Shugga' & Lil Sumthun', Dos Equis Amber and Yuengling. :thumbsup:
  18. Nov 16, 2017 at 12:50 PM
    #2018
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Wood carving set. Good starter for my kid. [​IMG]
    bigfella13 likes this.
  19. Nov 16, 2017 at 1:03 PM
    #2019
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Can you use multiple coupons on the same transaction? Not on the same thing, but buy multiple items with separate coupons.
  20. Nov 16, 2017 at 1:08 PM
    #2020
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I used a Harbor Freight allen wrench today, it performed perfectly.
    Toyko Joe and cliffyk like this.
