Hard shifting after premium gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thillman, Mar 15, 2017.
  1. Mar 15, 2017 at 6:58 PM
    Thillman
    Thillman [OP] Well-Known Member
    '12 Tacoma TRD Off-Road
    Okay, I have a 2012 prerunner trd off road with 31,000 miles with a fresh oil change and air filter but has not yet had its spark plugs changed.
    I've noticed a very faint rough idle at lights that will occasionally "lurch" or bump/jerk lightly forward at lights. It's had a slightly hard shift from first to second gear that is pronounced and much harder than the very smooth and seamless shifting in the higher gears past 50mph.
    The last few days as it's been getting warmer I've noticed the shifting to be growing harder from first to second and additionally a hard shift from park into reverse and reverse into drive. Today it almost resembled a deep pop.
    This morning I had just checked the mpg at the pump and decided to see if I could find an improvement in mileage with shell premium 93 gas. it was this afternoon the shifting appeared to get harder.
    I've searched and searched and read a lot on here but still feel the need to directly ask based on what I've read people say in the forums about
    a.) The issue of 2010-15 trucks coming out of the factory 1-3 quarts short on transmission fluid, and noticing shifting problems with no way to check the level due to the sealed unit.
    B.) the understanding that the newer trucks learn your driving habits and will adjust accordingly.
    Is it possible the timing is off with the higher octane causing this? How prevalent is the low trans fluid issue.
    I'm fairly certain the guy who owned it before me pulled a lot of trailers which concerns me.
    I spoke with Toyota and as expected they gave me the lifetime fluid spiel and sealed unit spiel telling me the computer may need to be updated and that they just won't check the trans fluid level or even flush and change it if I wanted to.
    The previous owners were on top of their Toyota maintenance schedule according to carfax so I would assume if the ECU needed updating they would have done it already.
    Does anybody have any thoughts on this? Could it be spark plug related?
    The vehicle also has a short, slight vibration around 20 mph when I floor it.
    I'd like to get it in as soon as possible for diagnostic.
  2. Mar 15, 2017 at 7:14 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    These dont need premium gas and in fact it hurts performance. Higher octane delays ignition so high compression engines dont get pre-ignition. Since our engines are not high compression the premium gas is delaying ignition and throwing the timing off. Never use premium fuel in this truck. It may not be the hard shift cause but it certainly isnt helping it.
    orezona and wagerhope like this.
  3. Mar 15, 2017 at 7:57 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    There is no relation between your shifting issues and premium gas. It's like you got a flat tire because you put ketchup on your steak.
  4. Mar 16, 2017 at 6:13 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I wouldn't take a bicycle to aamco, they are the worst place to go.
    outlawtacoma likes this.
  5. Mar 16, 2017 at 6:16 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Double A M C Whoa!
  6. Mar 16, 2017 at 6:20 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    It does not hurt performance. The FJ and 4 Runner with the 1GR engine recommend premium gas as well. It does not throw off the timing either, there are high and low octane timing tables, controlled by a knock retardation system, this way it works with multiple fuels. Higher octane prevents pre-ignition, so more timing advance can be commanded by the PCM. If you have a scanguage/Ultragauge or some other data logger, you can view timing advance and knock retard.
  7. Mar 16, 2017 at 6:32 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Replace the plugs. See if that helps. Also maybe take the truck in and have them read any precodes in the computer.
    These trucks consistently have rough shift problems as well as fuel injector issues leading to rough idles and hard starts.
    Transfluid is NOT lifetime EVER. And NO ONE should EVER say that when it comes to a TRUCK. Hauling and towing habits as well as wheeling heavily determine how often one should change/flush/check the transfluid.
    If you know a lot of towing has been done with it I would do a trans flush at 50-60k. Just me.
    Also make Toyota check the transfluid level.
    Capt Jrod likes this.
  8. Mar 16, 2017 at 6:58 AM
    uwu
    uwu Well-Known Member
    lol
  9. Mar 16, 2017 at 6:59 AM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Clean your mass airflow sensor,clean your throttle body,install new plugs
    knayrb and Specalt like this.
  10. Mar 16, 2017 at 7:04 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    They do that lurch sometimes, keep your foot on the brake. My 07 was horrible about it, however my 13 doesn't do it as much.
    If you think it's your transmission you can check the fluid level yourself there are write-ups on here.
    But one thing is for sure it's not the gas octane .
  11. Mar 16, 2017 at 7:25 AM
    KCTaco77
    KCTaco77 Well-Known Member
    Kansas City
    2011 Tacoma 4X4
    3" Lift, AMP Running Boards and tailgate step, ANZO head and tail lights.
    Premium Gasoline will not hurt your truck! Toyota used 91 octane for their research numbers which is premium unleaded gasoline. In the online Toyota Tacoma Owners Manual, the selected octane rating is 87 or higher - lower gasoline with an octane rating lower than 87 may result in engine knocking and possible engine damage.
    http://www.ttguide.net/fuel_information-159.html
    Krazie Sj, cliffyk and TacomaMike37 like this.
  12. Mar 16, 2017 at 7:59 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Pretty much 75% of this post isn't true. Premium doesn't hurt performance, nor does it throw off timing.
    reidkm, knayrb, farnorth01 and 2 others like this.
  13. Mar 16, 2017 at 8:45 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
  14. Mar 16, 2017 at 8:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    There is no fuel type to transmission co-relation. There is also no benefit in running a higher octane that called for. It just lightens your wallet.
    I'd find a good independent shop that is familiar with the procedure to check fluid levels, and start there.
    You are to be complimented for a well written post expressing both your concerns and what has / has not been done so far.
    Let's see if @gearcruncher might have some helpful info on your described symptoms.
    wilcam47 likes this.
  15. Mar 16, 2017 at 9:11 AM
    Crosis
    Dunedin Fl
    i stand by my post.
  16. Mar 16, 2017 at 9:14 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is the dipstick capped? could just be low on trans fluid...My Nissan was also capped but if you break the seal that held it on there was a dipstick you pulled out...IIRC...
  17. Mar 16, 2017 at 9:53 AM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    There isn't a dipstick for the transmission at all on the 4.0
  18. Mar 16, 2017 at 10:04 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    I'm guessing you recently started running the AC?
  19. Mar 16, 2017 at 11:47 AM
    Thillman
    I appreciate the advice. I'm a bit of a novice to flushing the trans fluid, hopefully will have a some new plugs this weekend, that I can handle.
    I'll search the forums for how tos on cleaning he MAF sensor, throttle body
    I just couldn't find anything definitive on here about the hard 1st to 2nd shift issues, I would like to catch it early if it just needs fluid, once I read a post about fluid being low from factory I decided to start asking my own questions.
    I also wanted to be as thorough as possible with what I had hanged in the last three days.
    Guess it's a bad time to say that I tried lowering the tailgate and removing the secondary air filter for better mpgs? Lol
    I'm just kidding.
    I can't wait to shake these new purchase jitters.
    Will be headed to the coast in two weeks hopefully that will help break her in for me mentally. But I'd like to have everything in top shape before I take the 3.5 hours hour drive.
    Anybody on here in the Austin area that can recommend some good trusted shops?
  20. Mar 16, 2017 at 1:10 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
