Hard start last night, brand new truck! WTF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RV7Garage, Jan 21, 2012.
  1. Jan 21, 2012 at 11:02 AM
    leveltwo
    leveltwo Well-Known Member
    there is a tsb for rough start i think, its common for our trucks. mine does it about ever 20th start... so i dont care...
  2. Jan 21, 2012 at 11:02 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    You must give the transponder chip inside the key a second to relay to the computer that your truck isn't being stolen. Once I started doing this, my truck has never had this problem again....
  3. Jan 21, 2012 at 11:12 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Maybe it's that "hard to ignite" 93 octane?! I'd doubt it, but if you start to think about it, well, put some 87 in there and see what happens! Not like the 93 does anything extra for you except deplete your funds sooner - IMO. In temps like 16 degrees, I doubt detonation/knock is an issue at all.
  4. Jan 21, 2012 at 11:14 AM
    leveltwo
    In stupid people terms, you put it to "on" (engage fuel pump and electronics) and then crank right?
    That seemed to stop mine some too
  5. Jan 21, 2012 at 11:15 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
  6. Jan 21, 2012 at 11:17 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Mine has done that a couple times. But IMO it's my own user error ... killing the starter too quick. Then you sort of have a flooding situation going on, which is why the 2nd crank then takes so long to catch.
  7. Jan 21, 2012 at 11:18 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    16 F is -8 C
    It's cold. That is all.
  8. Jan 21, 2012 at 11:21 AM
    toyotatacomaTRD
    That isn't necessary. All I have ever done is put the key in the ignition, pause, then start. Not one starting issue since I started doing this. I really think Toyota should do a better job educating owners.
  9. Jan 21, 2012 at 1:17 PM
    joes06tacoma
    Joe
    Central Coast, CA
    ^^This
    Don't know if it applies to the brand new trucks. Mine has done it one time. Never had it reflashed, have drive 15K since and has not reoccured. The one time it happened I turned the key straight from ACC to start without pausing. It cranked for 15 seconds with no sign of life at all. Cycled the key off, then on and paused a few seconds, turned to start and fired right up.
  10. Jan 21, 2012 at 1:50 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I got it fixed when my 07 had 166 miles on it. After they recalibrated the ecm it's started right up ever since...no need to pause or anything.
  11. Jan 21, 2012 at 1:51 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I'm kinda thinkin the 93 might have something to do with it as well. 93 is pointless in these trucks... but, on the other hand, my truck does this once every 2 months or so, so IDK.
  12. Jan 21, 2012 at 1:53 PM
    jandrews
    '09 FourDubDee TRD OR
    Let me make sure I have it straight:
    The OP is displeased that his truck started, correct?
    Incorrect. The ECU can take advantage of consistent higher-octane fuel fills.
  13. Jan 21, 2012 at 1:57 PM
    RV7Garage
    RV7Garage [OP] R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    What?? Re-read my post and you might get it. ;)
    Anywho...
    I'm going to try going with 87 octane next fill-up and see if there is any change in MPGs/behavior/performance. It sounds like there may be drain-back issues in the fuel delivery system, so from now on I will pause after clicking the key to "on" and see if the problem recurs.
    Thing is, I've been driving fuel-injected vehicles for many years (my last truck was also a Taco, 2010, 2.7l), and have never seen behavior like this. Sadly, it's nice to know I'm not the only one :mad::confused:
  14. Jan 21, 2012 at 2:07 PM
    St. Swervus
    St. Swervus Well-Known Member
    Nathan
    Mill Creek, WA
    '09 Double Cab TRD Sport
    Leer Camper. Thule Rack, NFab side rails w/step, 3' lift, Weather Tech mats, Paracord grab handles, LED interior lights, Bed Rug, Front windows tinted to match factory rears.
    There was a thread about this not too long ago. I've started turning my key to "on" then pausing for a second before starting. Fires up every time. I have a V6 as well. 25,000 on the clock.
  15. Jan 21, 2012 at 2:13 PM
    #35
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Get used to it because more and more vehicles equipped with computers to maximize fuel economy and performance will do this in the future (until manufacturers find a better way). Consistency (fuel, air filter, oil weight, etc) is one way to reduce this behavior, but you'll likely never entirely eliminate it since the computer is constantly making adjustments (to compensate for environment, air pressure, moisture, fuel quality, etc).
  16. Jan 21, 2012 at 2:15 PM
    #36
    jandrews
    No, trust me, I get it.
  17. Jan 21, 2012 at 5:26 PM
    #37
    Metalhead77
    Metalhead77 Well-Known Member
    CA central coast
    2012 DC LB sport upgrade 4x4
    Access bed cover-bed mat-Westin polished stainless steel steps-front skid plate BFG Rugged Terrain tires
    This same thing happened on my '09 v6 and has happened once on the new '12 v6. From what ive read this is normal.
    It never happened on our reg cab 4cyl 4x4. I'm thinking its just the v6 that has this issue.
