hard time shifting when cold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacotamer, Feb 5, 2014.
  1. Feb 5, 2014 at 3:16 PM
    Tacotamer
    Tacotamer [OP] Member
    08 tacoma 4 cyl.
    i have a 2008 base model 5 speed and when it is cold i have a really hard time getting it into gear 1st and 2nd mostly but when the truck warms up it is fine. is this normal? or is something wrong
  2. Feb 5, 2014 at 3:31 PM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    where do you live? How cold is cold?
  3. Feb 5, 2014 at 3:34 PM
    jro1
    jro1 Well-Known Member
    jesse
    Red Deer AB, Canada
    2011 Tacoma TRD sport
    Driver
    I'm in central Alberta Canada, mine does the same thing with my 6 spd, it's even worse when I don't plug in the block heater and it's been -30 c for the last week, So it does help if you have a block heater! Once the vehicle has warmed up for 10-15 minutes it drives and shifts fine. Another thing i'm looking into is getting a coolant heater, 1200W heater that installs inline with your coolant hoses. your truck will even blow warm air after you start it:)
  4. Feb 5, 2014 at 3:43 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Normal. 75w-90 gear oil is quite thick when it's cold and the synchros can't bite as well. Plus when you figure in the typical stubbornness of 1st and 2nd on the five speed, it's a royal pain.
    The trick is to shift very slowly or double-clutch for a little bit. Synthetic oil like MT-90 helps a little bit because it doesn't thicken up as much as dino oil does.
  5. Feb 5, 2014 at 3:46 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Normal with very cold temps.
  6. Feb 5, 2014 at 5:12 PM
    Tacotamer
    08 tacoma 4 cyl.
    thanks for the response guys i appreciate it! I'm in SLC, Utah so its about mid 20's at night
  7. Feb 5, 2014 at 5:22 PM
    savedone
    Gerald
    Texas
    Mid 20's should not make it hard to get into gear. I thought you were talking below zero temps. You might want to check your transmission oil to make sure it is not low and it is the right kind.
  8. Feb 5, 2014 at 5:36 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Yep, synthetic makes every shift much smoother in the cold. Put synthetic in the entire driveline. Motor also.
  9. Feb 5, 2014 at 5:44 PM
    Albertataco89
    Albertataco89 Well-Known Member
    Joey
    Alberta
    09BlackLiftedSR5
    Arb winch bumper, M8000 warn winch, 6 inch BDS lift, mayhem wheels, kenwood all around
    I live in Fort McMurray Alberta, it's been -30 here lately aswell and with my 6 speed it is the same it just takes time for the gear oil to warm up. With my remote start it doesn't work sometimes because my clutch doesn't fully disengage cause the fluid is too cold it's kind of a pain in the ass!!
  10. Feb 5, 2014 at 7:35 PM
    Tacotamer
    08 tacoma 4 cyl.
    ok thanks guys, ill check what they put in there, i just had it changed
  11. Feb 5, 2014 at 7:48 PM
    degu2000
    degu2000 Well-Known Member
    I had this same issue with my GTO. I live in North Dakota and it's commonly -20 overnight for a couple months in a row. When it got real cold outside I could sometimes not even get my transmission into first gear, and second was also difficult. I changed the fluid out a couple of times to try and fix the issue and I found that Redline fluid worked the best to counteract this issue. It was still there when it was cold, but was a hell of a lot better.
    Keep in mind this was in a T56 which is notoriously a stiff transmission regardless of weather.
  12. Feb 6, 2014 at 6:18 AM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Yup, I usually warm my rig up before taking off but there is a noticeable difference in shifting when I don't.
  13. Feb 6, 2014 at 7:10 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    Perfectly normal. If it bothers you just let it idle for a few minutes and that'll get the gear oil warmed up a little bit. Every manual transmission I've ever owned has done this to some extent in sub freezing temps.
  14. Feb 18, 2014 at 5:17 PM
    Tacotamer
    08 tacoma 4 cyl.
    so i found out what grease monkey put in my trans. they used 80w90 they also put that in my rear diff., transfer case, and front diff. is this right or do i need to change all this again? also is this the reason for tough shifting in the cold
  15. Feb 18, 2014 at 6:06 PM
    Tacotamer
    08 tacoma 4 cyl.
    and they put 5w30 in for engine oil and im reading my manual and all these are off by a little bit the man. trans fluid says 75w 90 and engine oil 0w 20 is this going to hurt anything? do i need to chang it right away? sorry i dont know too much about oil viscosity
  16. Feb 18, 2014 at 6:16 PM
    iroh
    michigander
    tonneau
    That GL5 oil will be harder to shift no matter what the season. It makes the synchros too slippery. Plus that 80w-90 is dino oil that's even thicker than the factory stuff. It turns to molasses when it's sub-zero to the point it's a pain to get it out of the bottle. I'd change it out if it was up to me.
    It should be fine everywhere else though if you don't mind the gas mileage. Might make the shifting into 4x4 a little sluggish. Transfer case has a synchronizer in there too
    This winter has been so cold anyways that I am so very tempted to drain the MT-90 and pump in some MT-85
  17. Feb 19, 2014 at 5:34 AM
    Tacotamer
    08 tacoma 4 cyl.
    ok thanks i appreciate it
