Hard to accelerate with wheel fully turned from park after switching to 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sage07, Jan 25, 2011.
  1. Jan 25, 2011 at 1:43 PM
    Sage07
    Sage07 [OP] Member
    Sage
    BOSTON MASS
    I have an 2007 Tacoma Sport. If I switch to 4x4 mode from park, and then try to accelerate with the steering wheel fully turned, it seems like the wheels do not want to move at all even if you press down the acceleration. Car also makes some strange noise (Chattering?/clunking sound) I've read somewhere on here it that it may be related the rear diff. LSD oil. Will changing the rear diff oil helps? I have no idea when it was last changed.
    Switching to 2 wheel drive eliminate this issues. Please help. Thanks.
  2. Jan 25, 2011 at 1:46 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    ....4 lo?
  3. Jan 25, 2011 at 1:47 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    you're on dry ground aren't you
  4. Jan 25, 2011 at 1:47 PM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I hope your not doing this on dry pavement.
  5. Jan 25, 2011 at 1:48 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    are you doing this on pavement? if so, you're putting a ton of stress on your driveline components. your turning radius is greatly increased when in 4-hi or -lo and you shouldn't be in either of those unless you're in low-traction situations.
  6. Jan 25, 2011 at 1:48 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    front end binding because you're in 4wd with the front wheels turned from a stop.
  7. Jan 25, 2011 at 1:48 PM
    Nick54
    Nick
    Mentor Ohio
    Hey Doc, great minds tend to think alike
  8. Jan 25, 2011 at 1:49 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    turning radius is decreased... but I'm sure that is what you meant:)
  9. Jan 25, 2011 at 1:49 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    yep. cant turn in 4wheel unless your moving. and its not really supposed to be a sharp turn anyways
  10. Jan 25, 2011 at 1:51 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    yeah, i think we're saying the same thing, but i'm pretty sure an increased radius means it takes more space to make the same turn, no? i might be confused.
  11. Jan 25, 2011 at 1:51 PM
    CopDoctor
    08 335i
    depends on who you ask. by "decrease" if you mean a smaller radius (meaning smaller cirlcle) then no. if by "decrease" you mean "gets worse" then yes. technically the radius increases meaning you have a bigger cirlcle to make.
  12. Jan 25, 2011 at 1:53 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Mine made the same noise after I changed the front diff, I was in a dirt lot and wanted to make sure I moved the oil around a little before reinstalling my skid. I was not in a hard turn or going over 5mph but it did make a noise. After topping off the fluid it no longer makes noise. ( I was only able to get about a cup more oil in )
  13. Jan 25, 2011 at 1:56 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    OP bottom line is:
    Turning sharply in 4X4 = bad acc. & weird bounce from the front end
    Turning sharply in 4X4 on dry pavement = effed up truck
  14. Jan 25, 2011 at 1:58 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Sorry to be blunt but things like this bug me.
    Go read your manual before you even look at your truck again. You're going to break it if you don't. You're not driving a car anymore, and just because you have 4WD, you are not invincible to the elements. Go learn how to drive your truck.
  15. Jan 25, 2011 at 2:01 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    not to be an ass, but....
    this guy just annihilated his drivetrain... LMAO! this thread needs this more than ever...
    people should read the manual especially if there is a feature that you've never used before... btw, doesn't say on that card in the visor not to use on dry pavement? (I'm going to go look)
  16. Jan 25, 2011 at 2:01 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Man for your first post you sure did open a can of worms.
    I'm assuming this is your first 4x4. Don't use the 4x4 on dry pavement; don't even use it on wet pavement. It puts to much stress on all the components because there's no give in the ground.
    We also need more info on your truck.
  17. Jan 25, 2011 at 2:04 PM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    sorry to hear about your truck. :(
  18. Jan 25, 2011 at 2:04 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    Oh and welcome to TW from Arizona.
  19. Jan 25, 2011 at 2:06 PM
    v1ndictiv3
    v1ndictiv3 Well-Known Member
    Bay Area, California
    '98 PreRunner Xtra Cab 2.7L
    Mostly stock: AFE Pro Dry S Filter, Bedrug, Leer Shell, 265/75/15 Goodyear Wrangler RT, Husky Liners, Wet Okole seat covers... Powertrax No-Slip in the near future =)
  20. Jan 25, 2011 at 2:09 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    ^ This.
    If you want to turn sharp on dry pavement with all wheels powered, buy a Subarau. You're binding your truck's transfer case driving like that.
    AWD = differential in the transfer case to sending unequal power to the axles.
    4wd = geared transfer case sending power equally to both axles.
    One's good on road, the other is good off road.
