HARD TO START WHEN COLD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mardoqueo galindo, Oct 21, 2012.
  1. Nov 7, 2012 at 9:08 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Okay I agree with you there, but I still don't agree with the practice of just cranking an engine over. It may or may not be OPs issue, I'm sure it would still help though, I wouldn't doubt that over a day or two that pressure will probably bleed off back through the pump. Could be a fuel filter too. With only 40k miles on an 08, its probably sat enough to condensate on an empty tank and get some water in the lines. Fuel quality could be poor too. If he's running mid grade, its probably the least used fuel of any gas station, which IMO increases the chance for bad gas.
  2. Nov 7, 2012 at 9:11 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I like how you think!
    Nice.
    A little input from me...ever cleaned your maf?
  3. Nov 7, 2012 at 9:21 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    No arguing there :) It could be a few things but I think in this situation his Cold cranking amps are weak...it tends to happen during the winter months...if you live in a cold climate CCA are important when shopping for a battery but I'm by no means a battery expert
  4. Nov 7, 2012 at 9:39 PM
    brian
    Elizabeth City, NC
    He is in SoCal tho... lol. Cant be much colder than here and I haven't seen lower than 50 yet.
  5. Nov 7, 2012 at 10:54 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Check to make sure the spark plugs are the proper ones for your vehicle. I had a very similar problem (nearly impossible cold starts, ran/started fine afterwards) after having a vehicle repaired (serviced at the same time) in Los Angeles. The next morning, nearly 500-miles away (colder weather), the darn thing just did not want to start. Ran the battery dead (had to have a jump), but it finally sputtered to life. Ran just fine the rest of the day. This repeated over the next several days.
    At the end of my trip, a friend (same vehicle), helping jump my vehicle yet again, suggested I try his spark plugs after noticing mine were wet with fuel. I was skeptical, but willing to try anything. Put his plugs in, turned the key, and was shocked when the vehicle started instantly. We quickly noticed the spark plugs were not the same.
    Anyway, immediately took the vehicle to a local dealer. He said the plugs installed in LA were not the ones specified. According to him, spark plugs have a temperature/heat range and starting performance will decrease dramatically if the proper ones are not installed. Since the problem disappeared completely afterwards, I have no reason to doubt that.
  6. Nov 7, 2012 at 11:43 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I should have also added, bust out the multimeter and check the battery voltage before you go to start it next time. If low, check for parasitic draw. Charge and then load test the battery and then proceed to voltage drop tests on starter.
  7. Nov 8, 2012 at 3:49 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Do agree with those thinking it's the battery. Sounds like not enough (CCA) cold cranking amps to start the engine efficiently. Take off your terminals and wire brush it super clean and tighten it to a point that you should not be able to wiggle the terminals by hand. If you have access to a battery charger, charge it overnight and try restarting in the morning and see if the problem is eliminated.
  8. Jan 3, 2013 at 4:54 AM
    Mep
    Mep 10 in. Member
    SW Ontario, Canada
    2012 DCSB SR5 w/ MT
    ExTang Solid-Fold Tonneau Cover, Weston 3" Step Rails, OE Skid Plate
    I have the same problem and my tacoma is brand new. When the temperature drops below 0 deg. C, it won't start on the first attempt. So far I've been just chalking it up to the computer still learning to manage the engine. I had the dealer look into it at my first oil change but they couldn't recreate the conditions.
  9. Jan 3, 2013 at 4:57 AM
    Large
    Large Red
    My 11 did this yesterday evening. It was about 40 degrees outside, has trouble starting on cold afternoons / mornings other times too. I'm not even at 20k so I'll wait to bug the dealer.
  10. Jan 3, 2013 at 4:59 AM
    Large
    Large Red
    Just saw this was a semi-old post. No help here, starter sounds fine when turning over, doesn't hesitate, has proper voltage, it just doesn't turn on after the first try. Might be the gas? No idea.
  11. Jan 3, 2013 at 5:06 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Absolutely Correct!
    The leaking faulty check valve could be allowing the pressure to bleed back to the tank. Or even a leaky injector. Or a small leak in the system. ....
  12. Jan 3, 2013 at 6:13 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Interesting, my old 97 Tacoma may not be started for maybe a month or more, 5AM snowing like crazy +5 degrees open the door start the truck be on my way no problem. There should be no need to "prime" the system the pump runs while it's cranking, the pump is below the fuel and should have instant pressure.
  13. Jan 3, 2013 at 7:32 AM
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    fuel lines are pressurized so no need for waiting, if you have to wait then the fuel pump is on the way out
    if you have checked the battery and its charged and the battery cables are good and clean then find the other ends of the cables (alternator, starter and grounds) and clean them as well
    after that its time to check for codes and see if any sensors are going
  14. Jan 3, 2013 at 7:43 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    IMO, it must be something other than temperatures making your truck start slower at 40degrees, because lets face it, 40 isn't cold:cool:
    I have noticed my truck will hesitate and start rough at around 0degreesF, and this morning I am glad I don't need to use it.....its -17degreesF.
    I have no doubt that my pickup would start at -17F, the noise it makes for the first 4 seconds isn't the greatest. I try not to start mine when the temps drop below 0F without using the block heater.
    I would say battery issue in your case.
    Oh, one more thing. When the temps go from freezing to above daily, this freeze/melt can occur in your gas tank, adding more water than desired to your fuel. This can also make your truck hard to start, hence why people use DEET. It helps to unfreeze frozen gas lines, commonly used up here. During winter, I always try and keep at least 3/4 of a tank of gas in the truck. This greatly reduces the amount of moisture buildup you get on the sides of an emptier gas tank. I learned this lesson the hard way.
  15. Jan 3, 2013 at 7:46 AM
    #35
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    i bet its the battery, but just take it to autozone and have them test it. if its the original one, i'm betting its on its way out. oem doesn't really last more than 3 years, which is average, but you do get the ones that last 5 or more years, but few and far in between. checking to see if the battery has 12 volts is NOT a way of checking the battery. you need to load test it. eliminate the small easy problems first, then start checking to see if its a bigger problem.
  16. Jan 3, 2013 at 3:14 PM
    #36
    rolltyd
    rolltyd Well-Known Member
    Jay
    Overland Park, Kansas
    2013 Off Road 4x4 Hankook Dynapro ATM
    It has happened to me twice in the last week. After work both times. Turns at normal speed but does not fire up. I tried the wait 10 seconds and turn key but it did not help me. On 4th try it finally started. ???
  17. Jan 4, 2013 at 7:23 AM
    #37
    Mep
    Mep 10 in. Member
    SW Ontario, Canada
    2012 DCSB SR5 w/ MT
    It's not the battery - my Tacoma has less than 8000 km. Whatever it is, sounds like a manufacturing defect. Possibly a bad batch of fuel line check valves.
    There's no need to take your truck in the have it load tested - you can do it your self: If an engine cranks over at a reasonable speed, your battery is fine. Every thing else (ignition, fuel pump, computer, etc.) takes such a small amount of energy to run compared to that starter motor.
  18. Jan 4, 2013 at 8:18 AM
    #38
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    I have had this issue a few times. I swear I could smell fuel in the air once the truck finally starts. Has anyone else noticed this?
  19. Jan 4, 2013 at 10:02 AM
    #39
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I personally think Toyota has screwed something up in recent years. It's a bug not limited to the Tacoma. Remember the days when the Toyota would be the car you could count on always starting in the cold? For instance, my buddy's Avalon survived two Michigan winters on a battery with a dead cell. That bugger made just 10.8 volts if it was fully charged and warm. Somehow it could crank over that 200k+ mile 1MZ-FE more reliably on snowy days than my brand new Honda. Of course, it didn't help that Honda put a 220CCA battery in my car.
    The Corolla with the current 2ZR-FE engine has been having quite a few hard start issues like this. I've personally experienced this, although with that car it's even more fun because it continues to crank the engine after letting go of the key.
    My Civic used to have bad problems starting in the cold. It never wanted to fire up below 10F (and that's not counting the ignitor failure I had years later). Two changes rectified it: synthetic oil let it crank faster, and new plugs at the start of every winter gapped at or just below the smaller gap spec. How's the factory gap on the Toyota plugs nowadays?
    An old trick to try for winter starting was if the first 2 tries fail, on the third try crank the engine with the accelerator depressed. By not firing up the first couple times the engine is flooded and when pushing the accelerator the engine can draw much more air to counter all that extra fuel. Of course, if it does start, take your foot off the gas, revving a cold engine is a no no!
  20. Jan 4, 2013 at 10:50 AM
    #40
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    K&N filter ?
    if it is oiled....
    always clean or check the MAF first, troubleshoot the rest later
