HARD TO START WHEN COLD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mardoqueo galindo, Oct 21, 2012.
  1. Jan 5, 2013 at 7:06 AM
    #41
    Mep
    Mep 10 in. Member
    SW Ontario, Canada
    2012 DCSB SR5 w/ MT
    ExTang Solid-Fold Tonneau Cover, Weston 3" Step Rails, OE Skid Plate
    I've noticed this too. It tells me that the mixture while starting is too rich (not enough air or too much fuel), or the ignition is not enabled. It's most likely the latter. The computer is probably waiting for a signal from the tac or the oil pressure transmitter to say that the engine is being cranked before giving the signal to fire a spark. A stupid design if it is.
    If the dealer doesn't resolve this for me, I'll make them investigate it every single time I take it in for an oil change until my warranty expires in 4 years.
  2. Jan 5, 2013 at 7:09 AM
    #42
    WThomas1250
    WThomas1250 Well-Known Member
    My '98 does this as well. It always starts on the second try; seems to only happen when it's under 30 degrees outside. Of course, my battery is from 09 so that's probably the problem.
  3. Jan 5, 2013 at 7:49 AM
    #43
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    Thanks. Those were the same thoughts I had. I'm going to get a thermometer for the garage and take notes when it happens again. Maybe even record the start in the mornings with my phone.
  4. Jan 5, 2013 at 8:55 AM
    #44
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Well, it's kind of necessary for the ECU to know where the crankshaft is to know when to fire which plug and when.
    I found that out the hard way years ago. 200 miles from home, the remnants of Hurricane Ike blew through Michigan, and after driving in rain so heavy I didn't know it was even possible to have that much water fall from the sky, that sensor died in my Civic (it was part of the distributor in that car). No spark because it didn't know when to make spark. It was a weird experience - I was driving down the road in 5th gear, the car just starts slowing down and I looked down and the tach read 0 when still in gear at speed. Scared me half to death. I initially thought I snapped the timing belt.
  5. Jan 6, 2013 at 8:04 AM
    #45
    Large
    Large Red
    40 is cold in Houston. Lol, and it doesn't hesitate to start when it's oh let's say 55+ degrees outside.
  6. Jan 6, 2013 at 3:40 PM
    #46
    Jackass
    Jackass Well-Known Member
    Jack
    Memphis, TN
    2013 Super White DC 4x4 TRD OR
    New truck with 2000 miles and had to crank twice this morning and just now. Temp is 40f. Wtf....
  7. Jan 6, 2013 at 5:11 PM
    #47
    Beers
    Colorado
    12 TRD OR
    The times I have seen this the temperature was showing less than 40f on the mirror at engine start. I have yet to see the problem occur when the temperature is above 40f.
  8. Jan 6, 2013 at 5:20 PM
    #48
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Fired mine up at -8 degrees this morning, did not use block heater. Truck fired up 1st try, but it sure wasn't happy about it:cool:
  9. Jan 6, 2013 at 5:30 PM
    #49
    ravenmad
    ravenmad Member
    Florida
    2015 DC 4x4 Taco
    5100's Soon... Pockets full of cobwebs atm.
    So in my push button start car how am I going to slow down and wait for then pump to prime? Current high pressure fuel systems have multiple check valves to prevent back flow and reduce priming times to nil.
  10. Jan 6, 2013 at 7:50 PM
    #50
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    same...new truck with 1500 miles...Twice its sputtered on startup when the temps been 30-26f sitting overnight...I even turn the igntion to on and wait 5 secs or so the computer can wake up and it still does it...
  11. Jan 6, 2013 at 8:07 PM
    #51
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Damn thats cold where you at? I've had 5-7 degrees every morning for the last week or two.
    And the truck is starting just fine.
