Hard to start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeffsieg, Feb 2, 2009.
  1. Feb 2, 2009 at 5:40 AM
    jeffsieg
    jeffsieg [OP] New Member
    Cincinnati
    Tacoma Prerunner
    Hello,
    I have 2009 Prerunner w/5000 mi. On 2 different occasions I've had problems starting my truck. The engine is cold, I turn the ignition key to start and the engine turns over strong, no hesitation but engine won't run. I usally have to make 2 attempts at 3 second intervals and on the 3rd try the engine starts and sounds normal. No ruff idleing. No "Check engine" light, Nice and smooth. It's almost like the ignition system was switched off, then back on. Has any one else experienced this problem?
  2. Feb 2, 2009 at 5:47 AM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    Are you holding the key long enough? I find that I have to allow mine to turn over a couple extra times vs other trucks I have owned. I am used to it now and seems to be normal for my case.
  3. Feb 2, 2009 at 5:53 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Two things I can think of.
    The engine won't fire until there's oil pressure. If it's really cold it might be taking longer than what you're used to to develop enough pressure to run. How long were you cranking?
    If you shut down the truck when it's at high idle it can cause the engine to be flooded making it difficult to start. I've had this happen in cold weather when I've only moved the truck a few feet to get at the snowblower.
  4. Feb 2, 2009 at 5:58 AM
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    had it happen once or twice but assumed it to be the oil pressure
  5. Feb 2, 2009 at 6:26 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    im not sure on your question... But welcome to TacomaWorld!
  6. Feb 2, 2009 at 6:37 AM
    creeksdrummer
    creeksdrummer Member
    Connecticut
    2014 TRD Off Road
    Mine did the same thing. There is a TSB about this. I took it in and they reprogrammed the computer. It's been fine ever since. I think the TSB is called "no start condition".
  7. Feb 2, 2009 at 7:56 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    I don't know that the '09's are covered in that.
  8. Feb 2, 2009 at 3:20 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i had it happen but i think it was just me not letting the starter turn over long enough. So i gave it a sec and than tried again and it was fine.
