Harder to decide on Tonneau than Truck
Discussion in 'Tonneau Covers, Caps and Shells' started by aucat77, May 2, 2013.
  1. May 4, 2013 at 7:00 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    That was the one that I was thinking of getting. I have a bike, fork mount attached to the back rail by the window. Do you happen to have pictures of how the flex sits on the bed rails?
  2. May 5, 2013 at 4:38 AM
    Fms
    Fms Member
    You cannot use the side rails because the flex rails mount directly to them. I think the front rail may not be accessible because of the last fold. All the tri folds that I have seen will prevent you from using the front rail because of the last section of the tonneau. You can remove the tonneau in less than 5 minutes. There are only two hand tighten nuts that hold it to the truck. The front rail will be fully accessible when the tonneau is removed. There is a you tube video showing all of this. Just do a search.
  3. May 7, 2013 at 1:25 PM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Just the standard Undercover Cover. But as of now its in my storage shed because have been using the bed too much. Great cover, though!
  4. May 7, 2013 at 1:35 PM
    2013TXEDITION
    2013TXEDITION Active Member
    Wayne
    Dallas, TX
    2013 Silver TX Edition PreRunner
    Trimmed front and rear mud flaps, WeatherTech floor mats front and rear, alloy wheel locks, mattgecko sliding window security bar,
    Quick question. I noticed the tailgate on the Tacoma is about an inch lower than side rails...is that an issue with the G4?
  5. May 7, 2013 at 6:44 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
  6. May 7, 2013 at 7:39 PM
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    I'm gonna sub this because I'm decieding on a cover!
  7. May 9, 2013 at 1:04 PM
    aucat77
    aucat77 [OP] Member
    Brian
    Colorado
    2013 DCSB TRD Sport
  8. May 14, 2013 at 3:38 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    OK got my G 4 installed this past weekend yes front and tailgate are lower than side rails but with a little tinkering can be fixed the back issues not an issue as long as you have it set right on the tailgate other than that I would suggest tailgate lock which I'm going to invest in a Dynolock adding some pipe insulation to front at cab to seal better will let you know how it goes.
  9. Jun 8, 2013 at 4:14 PM
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Bilstein 5100's . Add-a-Leaf. Interior LED's. Husky floor mats. Thule rack. Various little things...
    Agree
