Hardwiring a 200w power inverter to aux battery
Discussion in 'Technical Chat' started by Rat_Bastard, Sep 24, 2022.
  1. Sep 24, 2022 at 10:56 AM
    Rat_Bastard
    Rat_Bastard [OP] Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    I want to hardwire a 200 watt power inverter (usb outlets) to a bluesea fuse block that is powered by my auxiliary battery. The inverter is not supposed to exceed 180 watts. Is there anything else that needs to be considered to avoid a catastrophic event? What size fuse should be used in the fuse block?
  2. Sep 24, 2022 at 11:00 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    If it were me, I'd put a 20 amp fuse in there, sized based on 10% over max rating. Depending on the length of wire run to the inverter, 12 AWG being the minimum.
  3. Sep 24, 2022 at 11:08 AM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
    Perfect. I'm using 12awg. And will use that 20 amp fuse. Thanks
  4. Sep 24, 2022 at 1:33 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Why are you using an inverter for USB outlets?
    Mark77 likes this.
  5. Sep 25, 2022 at 5:33 PM
    Rat_Bastard
    Brian
    Tucson AZ
    2016 OR
