Hardwiring Dash Cam Help
Discussion in '3rd Gen. Tacomas (2016+)' started by vtac, Feb 1, 2018.
  1. Nov 14, 2018 at 11:46 AM
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
  2. Nov 14, 2018 at 11:58 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    They make battery banks that turn on when key is off. You can plug the dash cam into that, then that battery into the fuse box with a add a fuse system.
    https://www.blackboxmycar.com/collections/dashcam-battery-pack
    if you dont feel like dropping $250+ on a battery, you can use a relay, some wire, a add a fuse and a lawn tractor battery (12 volt). Just wire from the main battery to the relay, then to the lawn tractor battery, trigger the relay with a keyed on circuit. When key is on, power will run from the main battery to the lawn tractor battery (charging it) when the key is off, the power will be cut from the main battery.
    This will allow you to have the cam running for parking mode and not worry about draining your starting battery.
    tacoscott16 likes this.
  3. Nov 14, 2018 at 12:11 PM
    tacoscott16
    scott
    2018 TRD pro
    even hardwired kit with battery drain protection?
  4. Nov 14, 2018 at 12:14 PM
    5nahalf
    Erik
    Minnesota
    Drain protection will work on it own. I would stay away from them, but thats because it get below zero where I live for weeks at a time. If you get to the point it turns off the camera due to low voltage, it might still not have enough voltage to start the truck after the cold takes its chunk of power from the battery.
    pinochle and tacoscott16 like this.
  5. Nov 14, 2018 at 12:18 PM
    tacoscott16
    scott
    2018 TRD pro
    thnk to let me know and yes where I live it get cold too.
  6. Nov 14, 2018 at 12:35 PM
    5nahalf
    Erik
    Minnesota
    granted if your battery is under 3 years old, it should be just fine. But, I like to take precautions with the cold. Being stranded in the cold with my kids and a dead battery is not a fun time for anyone.
