Harmful towing?
Discussion in 'Towing' started by 63 beetle, Aug 25, 2014.
  1. Aug 25, 2014 at 8:22 AM
    63 beetle
    63 beetle [OP] Member
    Mark
    Houston
    I'm looking at a 6 cylinder,double cab,short bed, off-road package with the towing package. If I tow my Scout on a Featherlite trailer with a total weight of about 5500# once a year from Houston to Ouray,Colorado will I shorten the engine/transmission lifetime that much?
  2. Aug 25, 2014 at 8:27 AM
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    You should be just fine. I tow a couple snowmobiles all winter with my Taco and at 52K miles it has zero problems. I doubt a once a year trip will do much damage
  3. Aug 25, 2014 at 8:29 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    The 4.0L V6 (Standard on the X-runner, and double cab trucks, and available in Pre-runner and 4x4 Access-cab trucks)
    236 hp @ 5,200 rpm
    266 lb.-ft. @ 4,000 rpm
    Max. Towing capacity 6,500 lbs. (*except X-runner 3,500 lbs.)
    Max. Tongue weight 650 lbs. (*except X-runner 350 lbs.)
    You would be under your tow capacity so you would be fine!
  4. Aug 25, 2014 at 9:11 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
  5. Aug 25, 2014 at 9:29 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If you are buying a new truck, observe the break-in procedure in the owner's manual (i.e. no towing for the first 1000 mi). Otherwise you are good.
    Change the rear diff oil before 3 yr/ 30k.
  6. Aug 25, 2014 at 9:37 AM
    63 beetle
    Mark
    Houston
    Thanks for the answers. My brother just thinks that he knows everything!
  7. Aug 25, 2014 at 9:53 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Any photos of your Scout? One of these days I'd love to pick up a later Scout II with the 345 and a 4-speed. I see a lot of them out there that they swapped Chevy engines into, though, and that makes me cringe.
