Has any of you guys have your airbag lights turn on??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rberumen2, Nov 28, 2010.
  1. Nov 28, 2010 at 5:48 PM
    rberumen2
    rberumen2 [OP] Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    My airbag light went on and was wondering if you guys have had the same problem and howd you fix it??
  2. Nov 28, 2010 at 5:50 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    first off,you need to know what code is stored
  3. Nov 28, 2010 at 8:39 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    If your under 60k miles you might still be under warranty for that.
  4. Nov 28, 2010 at 10:03 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    clock spring?.......something like that.......
  5. Nov 28, 2010 at 10:31 PM
    billyjoe
    billyjoe Taco Fever - I've got it bad!
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Extang Trifecta Tonneau
    A faulty Clock-spring is a common cause of lighting the Airbag indicator. Toyota calls a clockspring a "Spiral Cable". You can perform a simple continuity check on your existing clockspring to determine if it's faulty.
    A quick check is to test your Horn, Cruise Control & Steering-Wheel Audio Controls (also check back-lighting of buttons). These are the circuits (other than your airbag) that are carried by the clockspring. If any of these are not working, you likely need a new clockspring.
    Note: There are two versions of the clockspring. If you have steering-wheel audio controls, you'll have/need the more expensive one.
    84306-04080 $266.91
    84306-0E010 $292.00
    These part #'s get used on many different models of Toyotas. You can usually find a used one on eBay for around $100.
    Hope that helps...:)
    BTW, if you do end up replacing your clockspring, make sure to center it before installing it (5 turns CW, then 2.5 CCW).
  6. Nov 29, 2010 at 3:48 AM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    I was able to get mine replaced under warranty. IIRC, I think it falls under the SRS, which is covered for 60k.
