Has anyone cleaned their AC Coil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trabo, Nov 14, 2017.
  1. Nov 14, 2017 at 5:13 PM
    trabo
    trabo [OP] Well-Known Member
    Los Angeles
    2017 Silver DCLB OR
    The Toyota decision to default to recirculating AC has lead to many a stinking AC system.
    As some of you know, replacing the cabin air filter does NOT fix this issue.
    My system has stunk since day one thanks to stupid test drivers who never blew fresh air through the system before the truck was turned off.
    I’ve made four requests to dealerships to clean my system and they’ve continually rebuffed me.
    I read in the service manual and it seems like a bit of a process to get to the AC coil to clean the bacteria off of it.
    Have any of you done it? I was hoping to get some feedback before I dived in.
    Thanks all.
  2. Nov 14, 2017 at 5:18 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Spray Lysol into the intake for the air conditioning while it's running. Also make sure your drain isn't stopped up.
    Flash1034 and trabo[OP] like this.
  3. Nov 14, 2017 at 5:35 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
  4. Nov 14, 2017 at 5:47 PM
    eurowner
    eurowner Duke Sky
    Scoty
  5. Nov 14, 2017 at 8:05 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    trabo[OP] likes this.
  6. Nov 14, 2017 at 8:13 PM
    CusterFan
    Mine has had the manure smell since I bought it new also. Told my service advisor and he said to bring it in and they would need to take the dash out to clean the a/c condenser. I'm not going to do this because I know I'll get my truck back with the hard plastic interior all gouged and scratched up. Who is to say that the problem won't return anyhow? I have been using Frigi Fresh twice a year and I'm planning on trading this truck off next summer to another poor unsuspecting soul.
    hiPSI, BillsSR5 and trabo[QUOTED][OP] like this.
  7. Nov 14, 2017 at 8:15 PM
    greg8765
    greg8765 Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    haven't had any issues with mine... yet. my 2014 corolla and the wife's 2015 highlander had the same problem after their first summers. i tried everything... nothing was a permanent fix. i hate the damn a/c systems in toyotas with a passion.
    anyone know if there's a way to reprogram it so the recirculating a/c isn't the default?
  8. Nov 14, 2017 at 8:26 PM
    trabo
    Los Angeles
    2017 Silver DCLB OR
    I’ve been told we can change it with the Carista app and module.
    As for maintenance, the key in my opinion is turning off AC and pumping outside air on high through the system for multiple minutes. If I was using recirc, I will also switch the recirc button on and off multiple times.
    That said, it takes cleaning the coil to truly get this solved after there is mold/bacteria in there.
  9. Nov 14, 2017 at 8:30 PM
    trabo
    Los Angeles
    2017 Silver DCLB OR
  10. Nov 14, 2017 at 8:39 PM
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    Dealer cleaned mine. Smell returned within 2 months.
    My buddy's tundra has the same stank odor
    CusterFan and trabo[OP] like this.
  11. Nov 15, 2017 at 1:14 AM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    I used Klima Cleaner. It didn't help.
    trabo[OP] and CusterFan like this.
  12. Nov 15, 2017 at 4:53 AM
    CusterFan
    I turn the a/c on high cool and shoot 2 blasts 5 seconds long directly in the fan under the cabin filter. Let it circulate through your a/c for a minute or 2 then shut the a/c off and with the fan on high shoot 2 more 5 second blasts directly in the fan under the cabin filter. Let it circulate for a minute or 2. All done... I do this in the spring and fall. You may have to treat it again after about a week. I have to do mine 2 different times.
    If you are worried about bacteria continuing to grow, it likely will. Your concerns is why I'm planning on trading my truck. Damn shame I have a new truck with this issue.
    trabo[QUOTED][OP] likes this.
  13. Nov 15, 2017 at 5:10 AM
    CusterFan
    I don't think that is the problem because I make damn sure when I turn the a/c on that the recirculating light is turned off and my truck still stinks to high heavens. I have never owned a car/truck in my 55 years that has this issue. Sometimes I wish I would of kept my 2015 Colorado.
    I'm not going to bother making sure the re-circulation button is off this next spring. It does not seem to matter with my truck.
  14. Nov 15, 2017 at 8:52 AM
    TacoLpastor
    TacoLpastor Well-Known Member
    NC
    2016 DCLB OR 4X4
    I leave mine on recirculate and don't have any smells. I'm thinking you have a leaky condenser or something.
    TFly likes this.
  15. Nov 15, 2017 at 9:27 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    We'll look for him/her in the New Member thread. :rolleyes:
  16. Nov 15, 2017 at 11:08 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    My '99 4Runner doesn't have paper filters and it doesn't stink. No issues.:annoyed:
  17. Nov 15, 2017 at 11:17 AM
    Chatt69chgr
    Chatt69chgr Well-Known Member
    2017 Quicksand Tacoma TRD 4X4 OFFROAD
    None
    Had the same problem in my 2005 Dodge Ram. Virtually impossible to clean the coil. I used Lysol like was already mentioned every couple of months and this helped. I also do not like the fact that the stupid AC system defaults to recirculate when turned on. Anybody have an idea why Toyota did this?
    Does anyone know if they can reprogram this via the Techstream software at the dealer so the ac system won't default to recirculate?
    trabo[OP] and Flash1034 like this.
  18. Nov 15, 2017 at 11:21 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I would say use the LYSOL treatment in the intake vent at every OCI
  19. Nov 15, 2017 at 11:31 AM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Others have recommended some other products which are probably good as well, but I've always just used simple OZIUM, just spray it through your A/C intake vents and let it recirculate for a few minutes. We use it all the time in the car business even helps get the stench out of smoker's cars.
    Between multiple wet dogs going to dog beach and lots of wet towels/wetsuits from surfing my trucks get SMELLY. After a vacuum/wipe down and Ozium treatment always smells super fresh.
  20. Nov 15, 2017 at 11:46 AM
    su.b.rat
    su.b.rat broken truck
    can someone snap a pic of where the intake vents are? where to spray a disinfectant?
    boynoyce likes this.
