Has anyone cleaned their AC Coil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trabo, Nov 14, 2017.
  1. Nov 15, 2017 at 4:15 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I turn the a/c on high cool and shoot 2 blasts 5 seconds long directly in the fan under the cabin filter. Let it circulate through your a/c for a minute or 2 then shut the a/c off and with the fan on high shoot 2 more 5 second blasts directly in the fan under the cabin filter. Let it circulate for a minute or 2. All done... I do this in the spring and fall. You may have to treat it again after about a week. I have to do mine 2 different times.
  2. Nov 15, 2017 at 4:21 PM
    su.b.rat
    su.b.rat broken truck
    got it, thanks. easily accessible in the glove box... will do in Spring. thank you again.
    CusterFan[QUOTED] likes this.
  3. Nov 15, 2017 at 4:23 PM
    CusterFan
    One good thing about winter here in Illinois....you get away from the stank in the a/c because you don't run it. :)
  4. Nov 15, 2017 at 4:47 PM
    su.b.rat
    lucky for me i only run the AC occasionally even in Summer, so the stank issues haven't affected any of my last few vehicles.
  5. Nov 15, 2017 at 6:14 PM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    I've been wanting to look into this as well. There is a product (foaming) you can shoot up into the condensate drain, plug the drain, let it sit a while, then drain it out. Not sure if anyone here has tried that or just how effective it is?
    Just got back from 10 days in the AZ dirt and dust, and the new truck smells like the old one as soon as the AC kicks on.....dusty AZ road smell. New car smell all but gone.
    The Gen1 never recovered from that smell. And was the same. Hardly noticeable (if at all) until you switch on the AC. Then it's about enough to drive you out of the truck. I need to find a relatively easy fix I can perform when coming back from trips so I don't have to put up with the smell on a daily driver. Really unfortunate there wasn't some way to easily get to the evap coil.
  6. Nov 15, 2017 at 7:27 PM
    CusterFan
    I could not get the clear tube past the firewall thru the drain tube. No go for me.
  7. Nov 22, 2017 at 7:40 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Has anyone else noticed that Toyota offers two different cabin air filters for this truck? The first one is the standard filter, but the second is called "deodorant filter". I wonder if that might help.
    88508-01010 Cabin Air Filter
    Tacoma; Standard Filter
    88508-04010 Cabin Air Filter
    Tacoma; Deodorant Filter
  8. Nov 22, 2017 at 8:07 AM
    CusterFan
    https://www.amazon.com/CF10374-Fresh-Breeze-Filter-Hammer/dp/B001CEJH0W
    I figure it is about the same thing as these Fram's I have been using. Hey if you buy one of the Toyota name brand cabin filters (deodorant)... let us know what you think about it. I'm getting closer to getting rid of my truck for this very reason.
  9. Nov 22, 2017 at 8:57 AM
    Comb
    Comb Known Member
    I'm considering it. Oddly enough, the deodorant filter ($21) is cheaper than the standard filter ($25).
  10. Nov 22, 2017 at 9:46 AM
    CusterFan
    Yeah and the standard filter is cheaply made. Went for my last free oil change/service a couple weeks ago and they changed my cabin filter. Glad I told him to keep my 6 month old Fram.
  11. Nov 22, 2017 at 10:37 AM
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    I thought so too where I am, but when you turn on the defroster it runs the AC compressor. Watch your drain tube it'll be dripping like mad.
    I have to set mine on outside air most days when I get to the truck.
    su.b.rat[QUOTED] likes this.
  12. Nov 22, 2017 at 11:30 AM
    su.b.rat
    yeah i watch that too, cus i keep vehicles till they fall apart, so a little planning keeps much of the funk out.
  13. Oct 22, 2018 at 7:47 PM
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
    What is the procedure to get a view of the AC coil? Thanks
  14. Oct 23, 2018 at 3:27 AM
    CusterFan
    You mean the "evap core?" That I can tell you the dash needs to be removed.
  15. Oct 23, 2018 at 6:07 PM
    #35
    Hemlocktherm78
    ok. prob service manual ?
  16. Oct 23, 2018 at 6:11 PM
    #36
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    :rasta:
    To the rescue
    thedzeffect likes this.
  17. Oct 23, 2018 at 7:34 PM
    #37
    CusterFan
    :notsure:
  18. Oct 31, 2018 at 8:21 PM
    #38
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    If you get a squirt bottle and fill it with rubbing alcohol and spray into the air intake I bet that would help with the stank. And would cost $2 at most if you already have an empty spray bottle
  19. Nov 1, 2018 at 4:31 AM
    #39
    CusterFan
    Just remember to remove the cabin filter first.
