Has anyone had ANY issues with factory warranty after doing the OTT tune.
Discussion in 'General Tacoma Talk' started by rambandit73, Oct 20, 2023.
  1. Oct 20, 2023 at 7:52 AM
    rambandit73
    rambandit73 [OP] Well-Known Member
    2023 TRD Sport Premium 6MT
    I am very close to pulling the trigger on the OTT 7.0 for my 2023 TRD sport 6MT. What’s giving me the very slightest hesitation is the 5yr/60k power train warranty. (I’m at 9k miles so got plenty left .) In my mind the scenarios play out such as any engine issue that can be traced back to the tune and Toyota voids any warranty work. I know this has been discussed ad nauseum and that the tune is difficult to detect.. but before I pull the trigger I would like to know if anyone has had any issues at all with dealers and warranty work after tuning?
    Thx!
  2. Oct 20, 2023 at 8:11 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The tune isn’t going to break your truck.
    The guys that developed that tune know what that are doing. They will not release a tune that even borders on “unsafe”. All their tunes are rigorously tested. Again, the tune “will not” harm your truck. And any thing that could (and it likely won’t) break, wound NOT be the fault of the tune.
    @Boltripper
    @JustDSM
    I bet the two guys above would know if there ever has been an issue.
    But like I said, I’ve never heard of it.
    Junkhead, JustDSM and rambandit73[OP] like this.
  3. Oct 20, 2023 at 10:08 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Personally I wouldn't tune until after the warranty is out but that's just me, I don't like giving them any excuse to deny a warranty claim.
    If you are doing your own flashing you can put the stock tune in the truck should you ever need to take it in for a problem.
    I will say many vehicles nowdays keep logs in the PCM of any change in tuning but I'm not sure if Toyota is doing this yet.
    joba27n and SR-71A like this.
  4. Oct 20, 2023 at 10:17 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    They do but I can trigger the check sum by disconnecting my battery and/or clearing a code. Atleast on my 2021. Small potato's though and thats not a cause to void the warranty on it
    Junkhead likes this.
  5. Oct 20, 2023 at 10:34 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I mean all factory calibrations have a checksum code so anyone with a scan tool and access to the code lists (which are typically publicly available) can see if it currently has a modifed calibration in it if they wanted to.
    Some manufacturers go a step or 2 further where they keep a permanent log of anytime the calibration was modified and/or setting a permanent DTC for non OE calibration.
    Not trying to scare anyone I'm just saying they have ways of detecting if something has been modified should they want to.
    soundman98 and joba27n[QUOTED] like this.
  6. Oct 20, 2023 at 12:49 PM
    joba27n
    Nolan
    Alberta
    For sure and I should clarify that i'm not trying to say that you'll be squeaky clean and completely under the radar. On gm's your don't even need to see the calibration code, check sum or any of that to know if something has a modified software. However unless it's obvious or Toyota themselves do the digging, it'll very highly likely slide under the radar
  7. Oct 20, 2023 at 7:15 PM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
  8. Oct 20, 2023 at 7:17 PM
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    In the engine failure thread, someone blew a motor from oil hydrolocking on an incline. Apparently warranty didn’t cover it due to a tune being present even though it wasn’t the cause. Im not sure if there are other confounding things, but I don’t really feel it’s worth the possible risk.
  9. Sep 23, 2024 at 2:19 PM
    SoCalTaco23
    SoCalTaco23 Member
    Andy
    2023 TRD Off Road - Silver
    I am thinking of doing the same thing, and am doing as much research as possible as I want my '23 to be a 300,000 mile, 20 year truck. HATE the needless shifting. Arbitrarily shifts up while trying to accelerate and has to shift back down immediately, and downshifts on the freeway with a .5 degree incline. Cant make up its mind, and I feel like all the excessive, needless shifts that it makes instead of just using the torque it actually has is overusing the trans and causing unnecessary revving. For me, OTT would be for the shifting issue as I drive like a grandpa. I have found nothing across all my reading and video watching where anyone says they've had a problem due to the tune, or a warranty issue except for the instance that kona61 mentioned above. I have only heard good to great things about the OTT tune, and that most people only wish they had done it sooner.
    BBogey likes this.
  10. Sep 23, 2024 at 2:23 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    2023 Ford Raptor
    Give this a read: https://www.tacomaworld.com/threads/psssst-what-mileage-you-at.840735/page-5#post-30101552
    SoCalTaco23[QUOTED] likes this.
  11. Sep 25, 2024 at 5:59 PM
    TyBud850
    TyBud850 Well-Known Member
    Tyler
    Defuniak Springs, Florida (NWFL)
    2012 Black Tacoma DC TRD-OR
    3” lift Icon 2.5 shocks king 650 coils, ALCAN LP W/Sumo springs & FOX 2.0, CBI MOAB 2.0 Front Bumper w/Smittybilt X20 10K winch, CBI Rock Sliders, Mobtown Reinforced Steel Skids & Bed Bars, CBI rear bumper,
    Whats the best outcome from an OTT tune? HP, Torque, Throttle Response? Whats the main reason people want their trucks tuned?
  12. Sep 25, 2024 at 6:02 PM
    BBogey
    BBogey Well-Known Member
    2003 Tundra, 2012 Tundra and now a 2023 Tacoma
    My “main objective “ was to eliminate non stop gear hunting = success
    TyBud850 and r3k like this.
