Has anyone heard of the stock cleat/rail system failing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joerc211v, Jan 13, 2012.
  1. Jan 13, 2012 at 5:17 AM
    joerc211v
    joerc211v [OP] New Member
    Joe
    Orlando, Fl
    07 SR5 4X4 longbed
    I just bought a new to me 07 double cab 4X4 and need to haul around a dirt bike (KTM 450) the cleats say they have a 200 lbs rating. I put the bike in the bed and tied down to them last night. There was a little flex when I moved the bike from side to side. I was a little worried about bumping down a dirt road. Has anyone had or heard of these failing? I'm referring to the adjustable sliding ones on the top of the bed in the front and side rails.
  2. Jan 13, 2012 at 5:19 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Yes they fail. They are not meant to tie down a bike.
    Add some d-rings to the front and middle and use them. I don't trust those POS cleats for anything. What happens if you rear end someone and thats all your using.......yup....bike to the back of your skull.
    Search "D-ring" and many threads will come up.
    Also search the motorcycle threads and some of the guys have come up with very ingenious ways to keep a bike or two secure.
  3. Jan 13, 2012 at 5:26 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Yup, add D-rings to the front bed bolts.
  4. Jan 13, 2012 at 5:30 AM
    08bluetacoma
    08bluetacoma Well-Known Member
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    6 inch fabtech alpine stereo flowmaster exhaust
  5. Jan 13, 2012 at 6:25 AM
    XXXX
    sKiP
    05 Prius
  6. Jan 13, 2012 at 6:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I put D-rings in the drain holes at the front of the bed. Not attached to the frame but very sturdy.
  7. Jan 13, 2012 at 6:31 AM
    XXXX
    sKiP
    05 Prius
    lol
    I drilled my drain holes out larger and added another so the crud washes out. My beds always full or dirt and crap.
  8. Jan 13, 2012 at 6:41 AM
    Pugga
    Massachusetts
    That's actually why I used the drain holes, they were too small to let the water drain out anyways so I figured I'd put them to use! Plus I had a tonneau cover and now a shell now so there's not a lot of water back there.
  9. Jan 13, 2012 at 6:45 AM
    Pugga
    Massachusetts
    I hear ya, I did it before I found this site and did not want to mess with the bed bolts (also didn't have a large enough torx bit to remove them either). I used a thick, rectangular metal backer plate on the bottom so it would take quite a load to crack the bed. At some point I might move them to the bed bolts but since I got the shell and a trailer, I don't use the bed for heavy hauling anymore.
  10. Jan 13, 2012 at 7:17 AM
    Pugga
    Massachusetts
    I was using them to hold down the Katana. The thing weighs 480ish but I'd bet each D-ring was seeing 300 lbs or so from partially compressing the front shocks. Right now they don't get used at all, they're under a plywood platform in the bed just rusting away... :eek:
  11. Jan 13, 2012 at 7:26 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It's not the cleats I would worry about, it's the rail system. It is definitely the weak point.
  12. Jan 13, 2012 at 8:28 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I use my cleats for tying down tarps and bungie cords but I wouldn't tie anything heavy down with them. I'd do what the others are saying and use D-rings mounted with the bed bolts. The cleats are useful but they do have some limitations.
  13. Jan 13, 2012 at 8:38 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
