Has anyone modified the bed light to control aux ditch lights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Dec 3, 2019.
  1. Dec 3, 2019 at 12:19 PM
    OnHartung'sRoad
    OnHartung'sRoad [OP] -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I am considering using my bed light circuit to turn on aux ditch lights mounted to the sides of my cabrack by adding a relay from under the bed light. I know about the leak risk, but can properly reseal it. Has anyone done this? If so, how did you do it and how did it go?
  2. Dec 3, 2019 at 12:28 PM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
  3. Dec 3, 2019 at 12:39 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    You would tap the +12v near the lamp and use it to trigger the relay. Power and ground for the lights would still come from the batt on a decent gauge wire.
    Cargo lamp fuse is only 7.5a so not enough room to straight power the lights from there.
    OnHartung'sRoad[OP] likes this.
  4. Dec 3, 2019 at 12:42 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    The cargo lamp fuse will power side lights.
    But they will not turn on and off with the rocker switch on the dash (ask me how I know)
    Greg.Brakes.Tacos likes this.
  5. Dec 3, 2019 at 12:46 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Thats easy. Just use a relay.
  6. Dec 3, 2019 at 12:48 PM
    uploadadventure
    Dixon, Mo
    Someone posted how to do it off the cargo rocker switch in the Uptopoverland thread. I’m to lazy to look back where
  7. Dec 3, 2019 at 12:48 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Fuse is before the dash switch.. if you tapped after the switch it would control it.
  8. Dec 3, 2019 at 12:49 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    someone call @caribe makaira
  9. Dec 3, 2019 at 12:54 PM
    uploadadventure
    Dixon, Mo
    The wiring after the switch isn’t enough power (ask me how I know too lol)
    You gotta run a relay from one of the switch wires. I forgot which one.
  10. Dec 3, 2019 at 12:58 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    It would trigger a relay, that's what OP is looking for.
  11. Dec 3, 2019 at 2:18 PM
    OnHartung'sRoad
    Thanks for the reply. Yeah, I have heavy gauge positive and negative lead going from an auxiliary battery to a fuse block in my bed and was going to power and ground off that, and using a heavy amp relay switched on and off through the cargo light.
    I was wondering if anyone had actually done it and if there any suggestions for accessing the cargo light and other ideas for the project. It just seems like a very easy way to do it for those of us who have a shell and rarely use the cargo light anymore for anything else, otherwise it’s a waste of a really good switch already installed in the dashboard.
  12. Dec 3, 2019 at 2:20 PM
    OnHartung'sRoad
    what did you do...?:notsure:
  13. Dec 3, 2019 at 2:29 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I'm a fan of wiring in my own circuits, I try to avoid any splices or piggybacks on the OEM system.
    Addafuse and another switch would be my route.
  14. Dec 3, 2019 at 2:29 PM
    OnHartung'sRoad
  15. Dec 3, 2019 at 2:31 PM
    OnHartung'sRoad
    I agree, but it’s totally an unused circuit now, so in my case this would be a good way to do it. Besides, I’m planning on keeping my truck until just before it dies.
  16. Dec 3, 2019 at 4:33 PM
    caribe makaira
    Caribbean, Puerto Rico
  17. Dec 4, 2019 at 7:02 AM
    OnHartung'sRoad
    Thank you for the post, that looks to be very helpful! I’m curious though, will a basic five pin 12 V relay overload the hot wire going to the cargo light? that’s what Cidgel did here on step 3:
    https://www.tacomaworld.com/threads...pping-conus-only.599113/page-51#post-21704559
    It just seems like it would be so much easier to tie it’s low amp coil into the positive wire feeding the light up in the ceiling, especially for controlling lights that are mounted to the roof racks and with the power feed from my auxiliary power source and fuse box I already installed in the bed of the truck... not sure about the main advantage of what you posted in that case...
    uploadadventure likes this.
  18. Dec 4, 2019 at 7:06 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Hang on....the 3rd gen comes with a bed light?!
    Well that's awesome. Lol
  19. Dec 5, 2019 at 10:05 PM
    OnHartung'sRoad
    OK well this will be interesting, I am now planning on putting a junction box underneath my Prinsu cabrack for accessory 12 V power up on the roof (the source is a third battery I have in the bed). I will put a blue seas waterproof cigarette plug up there for powering various accessories I use outside and for my RTT, such as phone, camera and drone chargers, lights and even a diesel heater, along with a relay to run my ditch lights mounted on the sides of the rack. I will post about it here.
  20. Jan 10, 2020 at 7:07 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    I repurposed my bed light switch to work with the LED light strips underneath my MX canopy. I also wired-in a dimmer/remote control. The stock wiring is really small gauge (likely 18-22) so I don't know that it could support high wattage lights.
