Has anyone replaced their o2 sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bs 02 Taco, Sep 6, 2008.
  1. Sep 6, 2008 at 8:52 AM
    Bs 02 Taco
    Bs 02 Taco [OP] Well-Known Member
    Amelia, Ohio
    02 Tacoma 4x4 regular cab 5 speed
    Swiss cap Deckplate Stupid door chime Synthetics AFE pro dry JVC Ipod compatible head unit Vanilla air freshener :) 25%tint
    Just got back from my mechanic and replaced most of my fluids and plugs to find out that the reason for my engine light was an o2 sensor malfunction.
    My truck seems to be getting bogged down in 3rd through 5th gears while I am just driving normally...
    Anyone have this problem, and what did you do to fix it?
  2. Sep 6, 2008 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    O2 sensors go bad. Its an easy fix, as you just have to take off the old sensor and install the new one. Just requires unplugging the old one, and turning it with a wrench until it comes out. :)
  3. Sep 6, 2008 at 5:13 PM
    Bs 02 Taco
    Amelia, Ohio
    Do you know what it feels like when one goes bad? (dont want to spend $200 if I dont have to)
    I priced 2 of them and found the Bosh to be around $230 and the Denso to be around $180
    Does it really matter? The Bosch is OEM
  4. Sep 6, 2008 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bosch is the better sensor. If the guy read your trouble code, and it said the sensor is bad, then I guess you have to bite the bullit and replace it. Do you know what code you threw?
  5. Sep 6, 2008 at 5:42 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Did you do anything to modify your engine? Rich fuel conditions will Foul an O2 Sensor.. Bog down in 3rd and 5th? How long has it been doing that? Been using a lot of gas, or have you been getting Horrible gas mileage?
    If not, yeah.. they do go bad...
  6. Sep 7, 2008 at 7:19 AM
    Bs 02 Taco
    Amelia, Ohio
    The code was P1135 Heater Circut Upstream H02S
  7. Sep 7, 2008 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Do you have an aftermarket intake? If you have done any maint. on your truck recently, you could have disconnected something along the intake tract. If everything is good, replace your O2 sensor nearest to the engine. Its the H02S (heated O2 Sensor).
  8. Sep 7, 2008 at 7:45 AM
    Bs 02 Taco
    Amelia, Ohio
    I did the deckplate mod...
  9. Sep 7, 2008 at 7:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Make sure all of the intake hoses, vaccume lines, etc. are propperly connected. If so, and truck is running like crap still, replace the up stream O2 sensor. :)
  10. Sep 7, 2008 at 7:55 AM
    Bs 02 Taco
    Amelia, Ohio
    Great, thanks for the fantastic news :)
    Will take care of it ASAP
  11. Sep 7, 2008 at 9:49 PM
    poleman72
    poleman72 Well-Known Member
    Virginia
    02 Prerunner
    Yes! after 100k miles I had to replace it too. Engine light went on and the mechanic told me the heater element of the O2 sensor was worn out. It's an emissions part so it's not a big deal.
  12. Sep 8, 2008 at 6:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  13. Sep 8, 2008 at 7:08 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    It's super easy on the 1st gen trucks. One electrical connector and two bolts. Soak the bolts in penetrating oil for a while before you try to crack them. Don't get enough penetrating oil in the sensor hole to risk getting some on the new unit. Should take you all of 15 minutes.
    www.rockauto.com has the best prices I've found yet for O2 sensors (and a lot of other parts too).
  14. Sep 8, 2008 at 4:16 PM
    Bs 02 Taco
    Amelia, Ohio
    Thanks everyone!!
    I replaced it today, cost me $250ish from the parts dept.
    Took all of 30 mins for me to change it.
    Engine light went out after two starts as well.
    I am having a problem with my cab getting hot, like my exhaust or cat is getting too warm...
    Any thoughts on this matter?
  15. Sep 8, 2008 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Make sure your heater is not turned on...... :confused:
  16. Sep 8, 2008 at 4:24 PM
    HerNameIsLucy
    RIP Lucy.
    Leaving out the wise-cracks about it being hot outside (summer) :D, are there any funky smells, like exhaust or that "something is burning smell" that come with this heat?
  17. Sep 8, 2008 at 4:24 PM
    Bs 02 Taco
    Amelia, Ohio
    I hope that was a smart-ass comment :D
    I can actually feel the heat on the bottom of the drink holder that is directly behind the shifter
  18. Sep 8, 2008 at 4:31 PM
    Bs 02 Taco
    Amelia, Ohio
    I was referring to Chris, Her, but no there are no smells...
    Just heat, especially when I come to a stop and there is no more wind.
    Its like it has to catch up or something
  19. Sep 8, 2008 at 4:35 PM
    HerNameIsLucy
    RIP Lucy.
    Best I'd be able to say is figure out exactly what is under the spot that's getting hot inside the truck, make sure there's no exhaust leaks, pipe bent or mounted too close to the floorboard, take it from there.
    (Chris4x4 is a guy)
  20. Sep 8, 2008 at 4:48 PM
    Bs 02 Taco
    Amelia, Ohio
    I know Chris is a guy...
    I was calling you Her, due to the beginning of your screen name
    Thanks for all the advice, will try and find the problem
