Has Anyone Tried To,,,,,
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lickskillet, Jan 11, 2015.
  1. Jan 11, 2015 at 8:52 AM
    lickskillet
    lickskillet [OP] Well-Known Member
    Land Of Big Sticks
    2014 Tacoma
    Find the speaker for the seatbelt chime and make it stop that way? I see where on my 2013 the dealer can make it go away and even a mod to the belt clip itself but am wondering if the speaker it self can be removed or disabled. PLEASE, no wear it comments. You want to wear it, good, have at it but don't push your own desire for the thing on me... Time for popcorn :popcorn:
  2. Jan 11, 2015 at 9:04 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    That seat belt chime sucks. Especially when ffroading.
  3. Jan 11, 2015 at 9:08 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Dave here how can I help?
  4. Jan 11, 2015 at 9:14 AM
    Syncros
    Syncros Well-Known Member
    I put my seat belt on and it doesn't beep. Try that :)
  5. Jan 11, 2015 at 9:21 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    ^^what a dick.
  6. Jan 11, 2015 at 9:22 AM
    loki32687
    loki32687 Matt
    Peabody, Ma
    17 TRD Sport Inferno
  7. Jan 11, 2015 at 9:23 AM
    Adamar85
    Adamar85 Well-Known Member
    Adam
    Baker City, OR
    22 Ford F350 Lariat
    Just search it, there is a few vids/pics and instructions of people removing them
  8. Jan 11, 2015 at 9:26 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I just turned it off in my 2013. There is a tutorial on how to do it with a Bluetooth obd adaptor and the proper commands you need to enter into a putty terminal. The dealer can also use their techstream unit to turn it off.
  9. Jan 11, 2015 at 9:37 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Really did you not read his post? And yes what a dick is right.
  10. Jan 11, 2015 at 9:43 AM
    markc6606
    markc6606 Well-Known Member
    SoFlo
    '13 Off-Road
  11. Jan 11, 2015 at 9:48 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    This ^
    U can buy the knock off tech stream n USB adapter on eBay n diy. Worked for me. There are a lot of threads on this if u get jammed up
  12. Jan 11, 2015 at 9:55 AM
    markc6606
    SoFlo
    '13 Off-Road
    Maybe this way would be better for you. I originally had the dealer disable mine, but it didn't take care of the buzzer when the door was open. I removed the buzzer more because it drives me nuts when the doors are open and I have the stereo on. Either one works,
  13. Jan 11, 2015 at 10:01 AM
    B737
    Kevin
    Jersey Shore
    stock
    Another way to fix the door buzzer is to remove the lower steering column cover, just two screws, then unplug the little plug on the bottom of the ignition tumbler. It's only job is to trigger the door buzzer. Life is peaceful without it :)
  14. Jan 11, 2015 at 10:04 AM
    markc6606
    SoFlo
    '13 Off-Road
    Had done this also. Only bad part about it, the doors will lock with the key in the ignition. Easy to lock yourself out if your not prepared for it.
  15. Jan 11, 2015 at 10:05 AM
    nd4spdbh
    SoCal
    Problem with that is by doing that you will now be able to lock your keys in the truck when they are in the ignition.
    If you want the stereo on with doors open and truck off, do what I did and put a simple switch on the ignition on line to a 12v constant hot. Now I can turn my radio on whenever I want, or flip it back to have it turn on when the truck is on.
    Also you don't need to buy a knockoff techstream cable, all you need is an elm327 and a Bluetooth connection to a laptop, download the free program putty, set it up connect to the ecu input a couple of commands boom. No more seatbelt beep.
  16. Jan 11, 2015 at 10:07 AM
    B737
    Kevin
    Jersey Shore
    stock
    Ah the details :)
    Knocks on wood
  17. Jan 11, 2015 at 10:53 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I do most the time.
    But in the morning out in the dirt to go use the toliet. I really dont want to hear it. I buckle it behind me. And mall crawling it sucks too.
  18. Jan 11, 2015 at 10:55 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
  19. Jan 11, 2015 at 10:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yeah wow that is a lot of work. But hey if he hates the buzzer go for it.
  20. Jan 11, 2015 at 11:07 AM
    markc6606
    SoFlo
    '13 Off-Road
    Wasn't bad at all. I take my time with stuff like that and still don't think it took more than an hour.
