Hauling
Discussion in 'Motorcycles' started by taco bueno, Sep 28, 2010.
  1. Sep 28, 2010 at 8:58 AM
    taco bueno
    taco bueno [OP] Member
    Austin, Tx
    Prerunner SR5
    Any problems hauling bikes in the four door short bed models? I have a 2004 Honda CRF 250X and 2007 Suzuki DRZ 400s. I have measured and it appears it will work with the tailgate down of course. It is approximately 6ft to center of the back wheel on both bikes but have not actualy hauled them yet. Are the tiedowns on the rail system strong enough to haul a bike? Any tips would be appreciated.
  2. Sep 28, 2010 at 9:17 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    I would not use the rails to die down the bikes, add some d-rings in front but other than that my drz fits in my short bed, well did.
  3. Sep 28, 2010 at 9:27 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  4. Sep 29, 2010 at 6:58 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    I just put my DR650 into my Acces cab this evening to see how it fits. It is longer then the bed by about 2". So I put the bike in sideways, corner to corner on the side stand. I put a strap to the front D-ring on the opposite side of where the front wheel is. I then used two of the rail tie-downs (TD) to hold the other side of the bike up front. This spread the force to two rail TD. Then I found frame area on the back of the bike to tie down the rear. When I first hooked into the rail TD's it seemed to pull a little so I moved the TD to a point in the rail that has a mounting screw in the rail and it is much better. The Rail TD's are rated at 200lbs.
    I hope this makes sense, I'm going to be loading it again tomorrow and I'll try to remember to take some pics. The bike was very secure.
    I have a friend that has a GSXR600 and all he has is a piece of plywood with a wheel chock in it on the bed to hold the bike up and he ties the bike to the rail TD's. He does this a lot and travels long mile to where ever he may be racing.
    Paul
  5. Oct 4, 2010 at 5:27 PM
    psmcn
    Paul
    Rockville Md
    So I took these pics before going to a 2 day 300 mile dual sport. this bike hangs over the tail gait and I wanted it closed.
    Left side using 2 rail anchors
    View of where I put the anchor over the rail mount bolt
    Rear view. You can see there is still room left on this bed. May be different on yours
    Right side front is tied to D-ring on bed floor/ rear is to rail anchor
    The bike was solid a rock back there. Here is the total rig
    The ride was awesome as well!!! WVA is a beautiful state even though I bent the rear wheel, blew out a fork seal and blew out the rear shock seal... It's all good though
    Hope this helps
    Paul
  6. Oct 4, 2010 at 5:50 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. I wouldn't trust those bed rails to hold up a bike. Put some D rings in the front of the bed. I haul a road bike in a short bed without any issues.
  7. Oct 6, 2010 at 11:08 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    The JPMetal Fab brackets ktmrider suggested are the best. Bikes sit solid in the back...unlike using the jenky D-rings that Toyota supplies.
    I discovered that putting the front wheel against the front and side of the bed also helps. Plus it gives you a tad more room in the middle to tie your gear bag down.
  8. Oct 7, 2010 at 8:05 PM
    mxpilot
    mxpilot Well-Known Member
    NE PA
    2015 Access Cab
    minimal
    I bought the Yotarack, a bit more money, but seems better able to handle two bikes. www.yotarack.com
    I used to use the stock tiedowns in the rail, but had repeated heart attacks over railroad crossings, and most any other bumps.
  9. Oct 14, 2010 at 10:35 AM
    taco bueno
    Austin, Tx
    Prerunner SR5
    Thanks for the pics PSMCN and it looks like that setup works great.
  10. Oct 14, 2010 at 11:04 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    The nice thing about JP's solution is that it uses both the front and side rail to stiffen things up.
    Never a problem loading two bikes in the truck.
    On the other hand, the stock D rings feel like they'll rip out at any minute.
    In all fairness, I do know a guy that carried his 950 Adventure around using only those stock D rings for a while. Jenky yes. But they held.
  11. Oct 14, 2010 at 11:06 AM
    bnavin
    bnavin Negative Ghostrider
    Ben
    Littleton, Colorado
    OME lift, driveline spacer, iPod interface, rattle canned center console and radio face flat black, LEER topper, Yakima rack, 20% tint all around
    When I haul my bike I bolt a 4 ft piece of 90 degree bar to the bed rail and works perfectly the bike doesn't move an inch. I'll take pictures after school
  12. Oct 27, 2010 at 9:59 AM
    Hellmutt
    Hellmutt Well-Known Member
    Piqua, Ohio
    '08 SR5 TRDsport 4x4 DC
    sadly, I've only put Husky Liners in it thus far - tend to blow all my cash on my bikes and guitars.
    Hauled my wifes Suzuki Intruder 800 from southern Tennessee to western Ohio using the bedrail sliders, but had to "double" up on them......slid the back ones up against the fronts and tightened them both down good and hard........can't believe Toyota didn't put Drings in the front of the bed too -- I mean, who the hell hauls their bikes backwards anyway? :D
