Have things gotten better?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mx400ex72, Apr 21, 2019.
  1. Apr 22, 2019 at 10:09 AM
    #101
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    OP, Mx400ex72... it sounds like it would be worth your time to test drive a 2019 model. Maybe more than once, drive different vehicles from different dealers just to be sure it's consistent.
    Mx400ex72[OP] likes this.
  2. Apr 22, 2019 at 10:13 AM
    #102
    Mx400ex72
    Mx400ex72 [OP] Well-Known Member
    Lehigh Valley, PA
    2019 BR SR5 DCLB
    Cool, wasnt really asking why you liked your 3rd gen though.
  3. Apr 22, 2019 at 10:16 AM
    #103
    KDubU
    KDubU Well-Known Member
    2019’s are not much different based on your description. Love the look of them the way they have them setup is a disappointment from a driving perspective.
  4. Apr 22, 2019 at 10:37 AM
    #104
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Having had all generations, the 3rd is my favorite by far. I can only compare manual transmission models though, and I will say that it’s a much more enjoyable vehicle with the manual, if you can go that route. If you can take the auto out of the equation, then you’ll likely be ok. Little has changed though from a couple of years ago. I personally have had zero issues with my 17.
  5. Apr 22, 2019 at 10:42 AM
    #105
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Rolling along in 6th gear is where i notice the most difference, when approaching a hill in the 2nd Gen l simply rolled into the throttle a little and it scooted right up. In the 3rd I have to get a running start and hope there is enough momentum to make it, or downshift to 5th and some days even 4th just to make it. Out on the interstate doing 75mph my 3rd Gen honestly feels fantastic, would never go back to my old 2nd Gens as this one is way more comfortable and practical.
    R242 likes this.
  6. Apr 22, 2019 at 10:53 AM
    #106
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    There is a TSB that makes the transmission logic same. Nothing mechanically is different between them.
    2016Tacoman likes this.
  7. Apr 22, 2019 at 10:54 AM
    #107
    Mx400ex72
    Lehigh Valley, PA
    2019 BR SR5 DCLB
    Yeah pretty much this. It just always felt that it was in 1 gear too high and when you went to ask for a little more power it like bogged down before it shifted down. Maybe the gen 2 just held in the lower gears a little longer. I take it, that this had to do with meeting some mpg requirements while increasing the HP.
  8. Apr 22, 2019 at 10:56 AM
    #108
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    So I'm running ovtune 91octane, and my 3rd gen will put you back into the seat when you decide to gtfo. It pulls so much harder than the 2nd gen ever did, even when stock. What everyone seems to forget is where the power band is on this motor.
    2016Tacoman and StillNoPickles like this.
  9. Apr 22, 2019 at 10:59 AM
    #109
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    True, but you have to realize the gearing in the trucks are different. 5th gear in a 3rd gen is close to 5th gear in a 2nd. 6th is really an OD for MPGs so when your truck shifts down to 5th on the hill it should be like the 2nd gen truck.
    shakerhood[QUOTED] likes this.
  10. Apr 22, 2019 at 11:01 AM
    #110
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Gauntlet tow test video doesn't reflect that. It leaves 2nd behind by 45 secs with a 5K load up the hill.
  11. Apr 22, 2019 at 11:02 AM
    #111
    shakerhood
    Southern Ohio
    I have a Manual, the gearing works out to be pretty similar as before, I'm not bashing on my truck, love it but would not mind a little extra grunt down low.
    Thegenerik1[QUOTED] likes this.
  12. Apr 22, 2019 at 11:03 AM
    #112
    shakerhood
    Southern Ohio
    Right I am aware of that brother, was just talking about normal day to day driving
    TacomaSport86 likes this.
  13. Apr 22, 2019 at 11:08 AM
    #113
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Not a single problem with mine and very satisfied..and I have owned an '03 Tundra and '16 Tacoma...both terrific.
    2016Tacoman, mgmdclb and shakerhood like this.
  14. Apr 22, 2019 at 11:48 AM
    #114
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    I love how the 2nd Gen owners always have to jump in & say how much better there trucks are over the 3rd Gen LOL.
    2016Tacoman and mgmdclb like this.
  15. Apr 22, 2019 at 11:52 AM
    #115
    Atley45
    Atley45 Well-Known Member
    It's also reving a bit higher to pull that load. If I were going to regularly tow a load, even a moderate one, up that kind of incline, the 3.5l v6 would not be my first choice...but then again neither would the 4.0l v6 which preceded it.
    That aside, a higher top-end speed and horsepower does not necessarily equate to a better towing experience. It's how that horsepower is delivered that matters more...the 3.5l v6 is a high-reving engine, which is not necessarily what you want for a towing/4x4 engine.
  16. Apr 22, 2019 at 12:02 PM
    #116
    Mx400ex72
    Lehigh Valley, PA
    2019 BR SR5 DCLB
    No one said that, LOL.
    TacoBuffet likes this.
  17. Apr 22, 2019 at 12:03 PM
    #117
    StillNoPickles
    2020 RAV4 Hybrid LE
    Revs have little to do with longevity or reliability if that’s what you’re getting at. Having pulled with both engines, I think the 3.5 is far more predictable and controllable in a manual transmission setup.
    shakerhood likes this.
  18. Apr 22, 2019 at 12:05 PM
    #118
    shakerhood
    Southern Ohio
    That is a good point, someone mentioned something similar in another thread the other day. An Eco-boost was faster than the diesels in the Gauntlet towing test, but that certainly would not make it a better towing rig.
  19. Apr 22, 2019 at 12:10 PM
    #119
    shakerhood
    Southern Ohio
    Outside of Reverse I think the Manual does a pretty good job of towing too.
  20. Apr 22, 2019 at 12:11 PM
    #120
    StillNoPickles
    2020 RAV4 Hybrid LE
    Yeah backing with a loaded trailer isn’t much fun. Especially if at an incline. Luckily haven’t run into that scenario too many times
