Have you had Fog Light Mod issues ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nick54, Sep 27, 2010.
  1. Sep 27, 2010 at 5:35 AM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I did the fog light mod shown in the Cheap Mods Post about 2 weeks ago on my 2010 Tacoma DC and yesterday found my driving lights on after I shut off the truck. I had the driving lights on when I shut off the truck so I'm not sure they ever went out, however I believe they should go out when I turn off the truck. I got in the truck and turned off the lights without the truck running and then turned the switch to the on position and they came back on. I restarted the truck shut off the lights then turned off the truck and tried the lights again - they stayed off. Anybody else experience issues like this and if so did you resolve them and how?
  2. Sep 27, 2010 at 5:56 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    no issues here, my quess is you tapped the wrong wire
  3. Sep 27, 2010 at 6:02 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Post a link to the mod you did try. There is a whole bunch there.
  4. Sep 27, 2010 at 6:20 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    Tap to a wire that goes off with ignition. I did the mod with no problems.
  5. Sep 27, 2010 at 12:19 PM
    Nick54
    Nick
    Mentor Ohio
  6. Sep 27, 2010 at 12:24 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    its normal. the ignithion relay activates by itsef about 4 hours after the truck is off. it stays on for about a min. ive caught my trucks fogs on a couple of times
  7. Sep 27, 2010 at 12:34 PM
    SoCalR
    SoCalR Well-Known Member
    Rand
    San Diego, CA
    05 TRD Sport PreRunner
    To the OP: Double check and make sure the green wire you tapped into is in the correct harness. I think there was another member that did the same thing where the wrong harness was tapped into.
    David, you should also check your wiring too. I've never had my lights come on.
  8. Sep 27, 2010 at 1:08 PM
    cobrakenny
    cobrakenny Well-Known Member
    Ken
    Raleigh, NC
    09 TRD Crew Cab 4x4 LB
    No problems here..I did the mod with a minor adaptation..I stole the relay power from the marker light circuit so I still have complete control of the fog lights but they turn on and off with the rest of the lights when I turn the ignition on and off.
  9. Sep 27, 2010 at 2:42 PM
    Steig
    Tacoma TRD off road
    Nick54,
    That sure looks like the same green wire I tapped into (6-pin small white plug, SOLID GREEN WIRE which is the top left corner of the actual plug), mine works fine.
    I used an electrical tap instead of solder.
    I guess you will just have to make sure you turn fog light switch off when you shut off truck.
  10. Sep 27, 2010 at 2:55 PM
    Nick54
    Nick
    Mentor Ohio
    Steig, that's the plug and wire that I used and I used a splice connector as you did. I guess I don't know what to do at this point.
    Thanks
  11. Sep 27, 2010 at 3:09 PM
    Steig
    Tacoma TRD off road
    Not sure about your situation there Nick54, hopefuly you can get it worked out.
    I did find this article, and this can possibly make your fog lights come some times, but this is not the way yours or mine is wired.
    Just an FYI.
    "Find your light blue fog light relay, remove the relay and bend the top right pin from the relay to the side pointing outward, Attach a female butt connector to the bent relay pin. The other end of this wire will run to one side of a 5A fuse. Once you have your wire running from the relay to one end of the fuse, now run a wire from the other side of the fuse to the red 10A fuse that’s located directly to the right of the relays location.. Now you’ve completed this modification. Something you might note doing this modification this way, I’ve heard that in some cases if the fog light button is left on, your fog lights will sometime have a tendency to flicker on/off after 4-6 hours of sitting. The fog lights evidentially will come on for a minute or so then turn off repeating this process every 4-6 hours"
    This is not my writeup - just a quote on a article I found
  12. Sep 27, 2010 at 4:44 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I know the marker lights or headlights shut off when you open the door, not when you turn the key off. They also stay on after the key is turned off and the door is open if you turn the headlight switch at all after the key is turned off. Starting and turning off the engine resets the sequence.
    And for the record, I've never seen my fogs come on after the key's removed either.
    As for the fogs turning off with the rest of the lights, the green wire mod turns them off with the key. So you can't accidentally turn them on with the key off and leave them on until your battery drains. (I did that twice on a previous vehicle.)
