Having a sqeeking noise when driving after lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hashemg, Jun 14, 2008.
  1. Jun 14, 2008 at 6:09 PM
    hashemg
    hashemg [OP] Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    Hey guys,
    I just put my lift in on monday and hadn't heard this til now.........when im driving i'm hearing a squeeking.....nothing major but enough to annoy me.
    its not necessarily on a bump...but when driving.......this is what i did
    camburg coilovers with upper a-arms
    all pro leaf springs in the rear.
    it sounds like the sqeeking in coming from the front but not positive.....also on the UCA i only put the grease they gave in the nipple......
    also i sprayed anti corrosion spray on the coilovers and a-arms
    has anyone experienced this squeeking???
    also when i step in the bed the leafs make noise...is this just part of the break in period....thank fo all your help!!
  2. Jun 14, 2008 at 6:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Camburg UCA's are known for being noisy. You can use some teflon spray lube on the uniball and see if that helps. For the rear, try some WD40 on the springs where they touch, and at the mounts. Have some one stand in your bed and move up and down to help isolate the squeek. :)
  3. Jun 14, 2008 at 7:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....wd40 will work, also, maybe try some dry moly lubricant or some white lithium grease on the rear springs and the uca, as this stuff wont slide off, and it penetrates pretty good.
  4. Jun 14, 2008 at 7:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont want to use the white lithium grease on the uniball of the UCA. Its not good for the teflon lineing of the cup. It should be fine for the bushings, though. I personally like Mobile 1 grease . :)
  5. Jun 14, 2008 at 7:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....shoulda added that:eek:. its actually decent for the spring bushings and such though. and yeah, the mobil1 grease is pretty good. great for packing between the leaf spring leafs for quietening them down(especially if you pressure wash the hell outta them after mudding and they start squeaking then:D).
  6. Jun 14, 2008 at 10:31 PM
    hashemg
    Eastern MA
    thanks so much guys i appreciate the feedback...i think i need to get to the UCA's with a greast gun in the fitting.....since i haven't done that yet. i only used the little packet of grease to fill it.
    i will def do that to the rear tho.
    and i will wipe off the the white lithium grease i put on the uniball tonight haha since i did think that was the problem too. thank you
  7. Jun 15, 2008 at 9:57 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    one more thing, if this doesnt seem to get rid of the noise, it might be the sway bar bushings- mine does it once in a while, especially when navigating a parking lot with sharp turning.
  8. Jun 18, 2008 at 5:58 AM
    hashemg
    Eastern MA
    I wiped off the lithium grease off the uniball pretty good (still some on there), sprayed some tri-flow on the uniball, greased the bushing with the lucas red grease.....and it still sqeeking.
    The only other thing i can think of is that i sprayed anticorrosion spray on The mcoil-overs and a-arms and def hit the uniball.......i know this creates a coating so is this stopping the tri-flow from penetrating???
    is there something i can use to get rid of the coating on the uniball???
    i know they're known to squeek but i'm trying to see what i can do to get rid of it
  9. Jun 18, 2008 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Have someone move your truck up and down while you are under it so you can isolate the squeak. If its the Uniball, just use a little more tri-lube.
  10. Jun 18, 2008 at 6:12 AM
    hashemg
    Eastern MA
    will doe that....also will lubing the bolt that goes throught the uniball do anything??
  11. Jun 18, 2008 at 6:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. But is it torqued to the correct value?
  12. Jun 18, 2008 at 6:43 AM
    hashemg
    Eastern MA
    depends...what is the correct value for that bolt......and als what should the long bolt going through the UCA be torqued to??
  13. Jun 18, 2008 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should have said in the instruction manual. I have TC's so Im not sure if yours are torqued differently. I think on mine, the big bolt attaching the UCA's to the truck was 85 ft.-lbs. and the bolt connecting the Uniball to the spindle was 35 ft.-lbs.
  14. Jun 18, 2008 at 8:08 AM
    hashemg
    Eastern MA
    yea camburg doesn't have instructions with theirs but i read on and install that 85lb is good i'll do that and trouble shoot today...
    and BTW my truck is so stiff that it won't bounce up and down. apparently the coil-overs haven't settled yet
  15. Jun 18, 2008 at 8:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek: How much lift do you have dialled into it? What is the rating of the springs?
  16. Jun 18, 2008 at 8:30 AM
    hashemg
    Eastern MA
    not sure the ratings...i'm only at about 2.5", of lift. they can go as high as 3.5" but not reccomended
  17. Jun 18, 2008 at 7:08 PM
    hashemg
    Eastern MA
    All set with the squeek ...i figured everything out......Sway-Bar bushing is what caused the squeeking. put some tri-flow on it and its all set thanks everyone
  18. Jun 18, 2008 at 7:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    glad you found the problem:)!!
