Having Issues with Rear Leaf Spring Recall with Toyota and the Dealership.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hilborn, May 25, 2017.
  1. May 26, 2017 at 8:29 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Appears the OP does not have or lost the receipt.
    ls1 prerunner likes this.
  2. May 26, 2017 at 8:36 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    They asked for proof. You can't supply it. Why is that their fault?
    Sucks, sure. But since you don't have anything but a story and a picture, what are they supposed to do?
    They're asking for a minimum criteria to be met, and you can't produce it. Not sure how a lawyer will change that. They're a business like any other, and can't be expected to write checks on request without documentation of why.
    tomwil likes this.
  3. May 26, 2017 at 8:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think the issue is that they should have been keeping proof and well documented visits. If they were this wouldn't even be an issue. It sounds like his service record is a shit show.
  4. May 26, 2017 at 8:40 AM
    T4RFTMFW
    Since you're getting the shaft because the dealership didn't take proper records of your purchase, then I'd start there.
    They are the problem.
    Press them to correct the situation and then go to bat for you and assist you on getting the situation handled with Toyota.
  5. May 26, 2017 at 8:49 AM
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Im just going to take the dealership to small claims court since they are the ones I'm having issues with. They are twisting their statements to avoid refunding me the parts I had to purchase before the recall was made.
    T4RFTMFW likes this.
  6. May 26, 2017 at 8:50 AM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    I sent you the service history for your vehicle direct from toyota systems in a pdf.
  7. May 26, 2017 at 8:53 AM
    Hilborn
    Michael
    Utah
    Got it. TYVM
  8. May 26, 2017 at 9:21 AM
    OKTACO
    Ty
    2005 SR5 Taco
    Can you take a picture of the springs that are on your truck wondering if the ones they sold you were ones still affected by the recall
  9. May 26, 2017 at 10:31 AM
    Hilborn
    Michael
    Utah
    That will not work since I ended up getting the OME they had there for sell.
  10. May 26, 2017 at 10:53 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    What they probably did then was do a quick inspection on the service drive without opening a repair order.
    If this type of thing happens to anyone else, ask the dealer to open a repair order just to document it. Get a copy and keep it. If they won't, then explain to them you'll be calling corporate which will most likely result in them opening one anyway.
  11. May 26, 2017 at 11:19 AM
    Hilborn
    Michael
    Utah
    Now that I have a copy of my service records. I have contacted corporate one final time showing them the lack of records kept by the dealership and how my records do not reflect theirs in the services I have had performed. All this comes down to is that the dealer kept piss poor records of my services and now that I have a complaint, they are fighting me because they can't refer to records they cant find.
    stickyTaco likes this.
  12. May 26, 2017 at 11:48 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Good luck with this Hilborn. Sounds like the service department at the dealer is a mess.
  13. May 26, 2017 at 12:48 PM
    Hilborn
    Michael
    Utah
    It disappoints me. Im a fanboy of Toyota. My girlfriend loves my truck and I have no intentions on getting rid of it. I actually plan on turning it into a overlander and getting a 4Runner as a daily driver. I have had no issues with this vehicle since I bought it other than this.
  14. May 26, 2017 at 12:55 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Sounds like your issue is with the dealer though, not Toyota. If the dealer had been inputting service information like they are supposed to this would have been corrected for you long ago.
  15. May 26, 2017 at 12:56 PM
    #35
    Hilborn
    Michael
    Utah
    I agree
