Hawaii Recon Wheel Alignment?!
Discussion in 'Hawaii' started by TacomaDriver8, Jan 15, 2014.
  1. Jan 15, 2014 at 8:32 PM
    TacomaDriver8
    TacomaDriver8 [OP] Member
    Does anybody know a place where I can get a passing alignment sheet? My truck's alignment came up red in some of the tests.
    Also, does recon double check those sheets?
  2. Jan 15, 2014 at 10:42 PM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    probably will need aftermarket upper control arms. just have a friend with a stock taco go do it with your info. fuck the government, no need recon.
  3. Jan 15, 2014 at 11:13 PM
    Airframes Chief
    Airframes Chief Well-Known Member
    Kekoa
    Kailua-Kona, HI
    Super white TRD 4x4 DCSB
    K&N drop-in filter, AFE performance exhaust, mild sounds by Kicker/Alpine and BedRug. 7.5" lift/18x10 Moto metal black 962/33" Toto M/Ts.
    If you are on Oahu, Island Brake & Alignment can get you fixed up properly and have your required sheet for recon all for a really good price. Tell him that Kekoa sent you as I am a very frequent customer and used them about 15 times (all lifted trucks/SUVs). Derrick the owner is sets the standard in quality and price. You will not be disappointed and good luck, Aloha! :)
    Island Brake & Alignment, Inc
    98-019 Kamehameha Highway # 1
    Aiea, HI 96701
    (808) 488-6521
  4. Jan 16, 2014 at 12:12 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    need to bring in green alignment sheet to recon.
    is your truck stock? it should align if it is.
  5. Jan 16, 2014 at 12:18 AM
    CBoy808
    CBoy808 Sticker Making Dude
    Tacoma Mall Crawler
    they can lean on your truck to get the spec to line up if its slightly out of spec. :)
  6. Jan 16, 2014 at 1:13 AM
    TacomaDriver8
    Lol trucks lifted, 6 in suspension and 2 in body. Ill tell them to try and lean on it lol they said they couldnt get the camber within specs
  7. Jan 16, 2014 at 8:20 AM
    luka
    Kailua, HI
    do you have aftermarket upper control arms?
  8. Jan 16, 2014 at 9:21 AM
    TacomaDriver8
    Yes, but theyre not the adjustable kind
  9. Jan 16, 2014 at 12:30 PM
    m0sing808
    m0sing808 Well-Known Member
    Can u get correct alignment specs with a 3 inch leveling kit???
  10. Jan 16, 2014 at 6:38 PM
    luka
    Kailua, HI
    might be the body lift.
  11. Jan 16, 2014 at 11:16 PM
    1uzrnr
    1uzrnr The NotaRC 4runner :D
    Honolulu
    86 4runner stockish
    Couple
    Body lift has nothing to do with alignments.
    Try cranking your C/O's down a little. Should help with the camber.
  12. Jan 17, 2014 at 9:31 PM
    xurusaibobx
    xurusaibobx Well-Known Member
    remember for recon your alignment sheet has to be within 30 days. last check i think recon is backed up 3 months.
    adjustments are made from the lower control arms camber and caster. whats the reading on the camber and caster?
  13. Jan 18, 2014 at 9:53 AM
    CBoy808
    Tacoma Mall Crawler
    Last time I called recon they were ok with the alignment paper being 6 weeks old cause that's how far the back log was.
    OP try call them directly they have always been helpful
    (808) 733-2542
  14. Jan 18, 2014 at 10:11 AM
    m0sing808
    I dont know....no like chance alignment if they not going be able to get correct specs...and waste money....has anyone been successful in getting it into specs with a leveling kit?
  15. Jan 26, 2014 at 10:43 PM
    xurusaibobx
    i usually can get them in specs but it all depends on how the control arm bushings are if get play or if the camber/caster adjustments are worn out too.
  16. Feb 13, 2014 at 10:04 AM
    AiNoFaKNKeA
    AiNoFaKNKeA Well-Known Member
    Hawaii
    '14 TRD Sport DCSB
    885's w/ 1/2" spacers on OME Sport Nitros OME Dakars w/ Sport Nitros & D29XL AAL 285/65 BFG AT KOs on 18" Dropstars 645B 0 Offset 4.5" BS Spidertrax 1.25" Wheel Spacers LED Interior and Exterior 6K HID Headlamps and Fogs 6K LED DRL Switchbacks Pop and Lock Codeable Smart Lock Tailgate Handle Debadged Wet Okole's Front and Rear Weathertech Digital Fit Floor Liners Husky Liners Custom Molded Mud Guards Tint AMP Research Bed Step AMP Research Bed Extender ImMrYo Rear-View Mirror Lift Bracket Viper Alarm ICE: Alpine PDX-V9 Audio Control LC6i Image Dynamics CTX65CS Image Dynamics CTX65 Image Dynamics IDQ12 KnoKnoise Sound Deadening
    Had anyone be able to get their alignment on a 3" lift within specs without aftermarket UCAs?
    Planning on getting the OME 885's with dakars and I want to just do it all one crack.
  17. Feb 13, 2014 at 12:09 PM
    MikeyTG
    MikeyTG Oh Herro
    Oahu
    I've got the 885x's/no aftermarket UCAs and my alignment is off by .01*
  18. Feb 13, 2014 at 12:10 PM
    CBoy808
    Tacoma Mall Crawler
    ^ Mike what is your caster at?
  19. Feb 13, 2014 at 12:11 PM
    MikeyTG
    MikeyTG Oh Herro
    Oahu
    I can't remember exactly, but I can grab my sheet tonight when I get home (drove the car to work today) and post it up.
  20. Feb 13, 2014 at 1:45 PM
    CBoy808
    Tacoma Mall Crawler
    sweet thanks
