Haynes Manual Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Mar 28, 2011.
  1. Mar 28, 2011 at 1:56 PM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    For those that have the Haynes manual for the 2nd generation V6 Tacoma what weight gear oil does it call out for the front differential? The reason I ask is that my owners manual says 75w-90, the Chiltons manual says 80w-90 and the local dealership uses 80w-90. I know there isn't that much of a difference between the two grades...just curious what the Haynes manual says. Thanks
  2. Mar 28, 2011 at 2:15 PM
    OffroadToy
  3. Mar 28, 2011 at 3:37 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Haynes manual says:
    API GL-5 SAE 90W above 0degF
    API GL-5 SAE 80W-90 below 0degF
  4. Mar 28, 2011 at 3:41 PM
    OffroadToy
    Thanks bigmooze... That's the front diff right?
  5. Mar 28, 2011 at 3:48 PM
    bigmooze
    Richard
    Belle River, ON
    Yes sir. You're welcome.
