Head gasket failure on 4.0 Toyota engines
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barley1, Oct 24, 2016.
  1. Oct 25, 2016 at 3:54 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I like that style of handling. :thumbsup:
    shakerhood, scottalot and Dalandser like this.
  2. Oct 25, 2016 at 4:08 PM
    devkurf
    devkurf Member at Large
    midwest
    Mine just started doing this, it's an 05. How would that be linked to head gasket failure?
    scottalot likes this.
  3. Oct 25, 2016 at 4:15 PM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    You lucked out, thats awesome. Im keeping an eye on my 05 but if it ends up needing to be replaced, ill be the one doing the work.
  4. Oct 25, 2016 at 4:17 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  5. Oct 25, 2016 at 5:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I swap head gaskets in my sleep.
  6. Oct 29, 2016 at 10:44 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    The head gasket having a hairline crack around cylinder 5/6 will be enough to push air into the cooling system upon combustion. So what you are hearing is bubbles in the coolant circulating through the heater core when you first start the truck. Also some coolant can start to seep into the cylinder, hence the extra ordinary amount of water vapor in the exhaust. A hairline crack is just enough to push a tiny amount of air into the cooling system, and leak a tiny amount of coolant into the cylinder to be pushed out of the exhaust, but not quite enough of a crack to be detected on a pressure test or trigger a missfire which would throw a code. Trust me I fought with diagnosing the problem for a long time! And the dealership swore nothing was wrong because no codes were thrown and pressure test results were fine. When I brought it in to have the head gasket changed, the dealership told me I did not need it done, I insisted (since I was paying for it) they did it. Next day I got a call from the service rep, he said "you were right, when the pulled it apart the head gasket was in fact pretty much destroyed!"
    When the crack in the head gasket gets bad enough the truck will start overheating when you drive at slow speeds. This happens because when the crack gets bad enough to where so much pressure from combustion in the cylinder is being pushed into the cooling system that the coolant will actually start be pushed out into the over flow jug, then out of the jug all together! The jug will look like a pot on the stove that is boiling over.
  7. Oct 30, 2016 at 7:17 AM
    devkurf
    midwest
    Thanks for the reply and info, it makes more sense now. I have noticed a sweet smell a few times which is concerning. I was hoping that the gurgling behind the dash after hard turns and during hard acceleration was simply a blockage in the heater core or condensate from the A/C getting backed up.
    So far, I've only tried putting the truck up on ramps and running it without the radiator cap on. It pushed coolant back out the top of the radiator, and didn't seem like it was cycling through, so I put the cap back on to save our new driveway. I also tried running a coathanger thru the A/C drain tube, but I couldn't get it far enough up to where it felt like it did any good.
    I just changed the oil, and it looked just like it should. There is some water coming from the tailpipe, but not an excessive amount, and never any white smoke. I'll keep an eye on the coolant level, and tinker with it some more when I get time.
  8. Oct 30, 2016 at 7:28 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I'll tell you from experience if coolant is being forced through the filler neck ( not just bubbling up but coming out under some pressure) then your head gasket is blown.
  9. Oct 30, 2016 at 7:30 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    ace96 and scottalot like this.
  10. Oct 30, 2016 at 7:43 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My second Tacoma was a 2005 V6 4.0.
    I had it for just over 4 years and put 102,000 miles on it.
    I had 0 engine problems.
    In Dec. 2009, I got my third Tacoma (2010 V6 4.0).
    I have had it for almost 7 years and have put 92,000 miles on it.
    I had (so far) 0 engine problems.
    [Of interest, my first Tacoma was a 2001 V6 3.4.
    I had it for almost 5 years and put 136,000 miles on it.
    Because a water drop was seen on the water pump during maintenance servicing, it was replaced on the '01 and '10 Tacomas.]
    R0dzilla75, scottalot and Mush Mouse like this.
  11. Oct 30, 2016 at 7:47 AM
    Lilbigman
    Lilbigman Well-Known Member
    2005 Tacoma Double Cab TRD SPORT 4X4
    20x12 Fuel Krank. 33x12.50 Toyo Open Country . 6" FabTech lift. Dirt Logic 2.5 Coilovers front Dirt Logic Shocks rear. Billet grille. Pioneer DVD touchscreen. Hertz 6.5 2 way in front & rear. 3 10" JL AUDIO 10w0 subs. 2 Pioneer amps powering the system. Magnaflow catback single in dual out
    Just had the check engine light come on ....
    Replaced egnition coil in cylinder #4
    2 days later the check engine light came back on then I was giving the bad news....
    My 4x4 2005 sport TRD DC with 131000 miles all recommended maintenance done .
    This is some real BS
    tacomakid96 and scottalot like this.
  12. Oct 30, 2016 at 7:49 AM
    Mush Mouse
    mush
    2013 SR5
    what check engine codes are you getting?
  13. Oct 30, 2016 at 7:53 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Cough...self inflicted...cough
  14. Oct 30, 2016 at 8:09 AM
    Lilbigman
    If I wanted to replace a head gasket I would have purchased a Chevrolet instead of a Tacoma
  15. Oct 30, 2016 at 8:18 AM
    #35
    Lilbigman
    Happy for ya
    I'm not so lucky
  16. Oct 30, 2016 at 8:21 AM
    #36
    Lilbigman
    Misfire cylinder #4
  17. Oct 30, 2016 at 8:27 AM
    #37
    David K
    Well, the engine was 0 problems but there were other issues with my '05 (brakes, clockspring cable, rear suspension,...) so I traded it after 4 years for the 2010 and what a great choice that was... the best Tacoma for me!
  18. Oct 30, 2016 at 8:30 AM
    #38
    Lilbigman
    I've put about $10k in my 05 looks like I'm going to drop a few more in it
  19. Oct 30, 2016 at 8:31 AM
    #39
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    At least on a Chevrolet it wouldn't cost so much. Damn overhead cams makes labour go up.
    My 2005 I just bought has 212,000 km, so 120-130k and I hope it goes a long time. I regilarly see tacomas for sale with 400-500k km and they never mention head gaskets being replaced. I hope it's not widespread
  20. Oct 30, 2016 at 8:59 AM
    #40
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    A dealer that initially doesn't want to take your money ?? Now that's rare.
