Head Gasket or Intake Manifold Gasket
Discussion in 'Technical Chat' started by ImplicitlyAlberta, Dec 27, 2012.
  1. Dec 27, 2012 at 5:11 PM
    ImplicitlyAlberta
    ImplicitlyAlberta [OP] VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    So Im having more fun with my truck again. 2006 v6
    Not sure where the issue is. I have a warrenty so Im not entirely worried, though I am curious.
    I do have evapourate residue on my oil cap and down the filler stem, however I did an oil change and there is no evidence in the oil. I also did my sparkplugs at the same time and did not see any evidence there as well.
    Looking for some input.
    Anyone seen this before?
  2. Dec 27, 2012 at 5:13 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    It's normal. They all do it.
  3. Dec 27, 2012 at 5:22 PM
    KalamaKid
    Oregon
  4. Dec 27, 2012 at 5:25 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    looks like you need a new engine!
    or take yours on some longer hotter drives
  5. Dec 27, 2012 at 5:42 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    +1
    Need to evaporate the moisture from your oil so the PCV system can process it.
  6. Dec 27, 2012 at 5:53 PM
    ImplicitlyAlberta
    David
    edmonton
    Are you serious???
    This shit could be normal?
    Hmm I am actually now a little more frustrated then before.
    Lets build an engine that will make some frappé topping at the same time, these americans will shit bricks.
    Well thanks for the great input. Ill let you know if my engine shits the bed.
  7. Dec 27, 2012 at 6:01 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    It is normal, if you take short drives that don't allow the engine to get hot enough to burn off moisture in the crank case.
  8. Dec 27, 2012 at 6:03 PM
    ImplicitlyAlberta
    David
    edmonton
    Any idea if its bad. No moisture in the oil is really good but should I take the time and run a few hundred Kms every weekend in the winter?
  9. Dec 27, 2012 at 6:06 PM
    KalamaKid
    Oregon
    Hasn't cause any damage to me and my filler cap has looked like that all 50,000 miles I've driven it.
  10. Dec 27, 2012 at 6:17 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I would keep an eye on your oil level as well as coolant level just in case but generally this appears with short trips. I wouldn't go too out of your way to get it really warmed up. This small amount of moisture shouldn't cause too much harm to your engine.
  11. Dec 27, 2012 at 6:26 PM
    ImplicitlyAlberta
    David
    edmonton
    Awesome. Didnt think Id get a response so quickly.
  12. Dec 27, 2012 at 6:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It IS indeed normal. To echo what these guys said if you take short drives you are nnot giving the engine a chance to properly get up to operating temp which will in turn leave moisture residue around the oil cap area. Nothing to worry about.
  13. Dec 30, 2012 at 1:37 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    In a cold enough climate, even long trips won't eliminate it. The long filler neck is really why this happens, it creates a cool spot for the moisture to condense. Look down the tube with a light, there won't be any "mayonaise" below the botton of the tube.
  14. Dec 30, 2012 at 1:40 PM
    ImplicitlyAlberta
    David
    edmonton
  15. Dec 30, 2012 at 1:48 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I change my oil at 3-4k in winter instead of 5-7k in summer. You aren't going to change the way you drive so might as well change the oil. It is not common in warm weather so if it persists in summer look deeper.
  16. Dec 30, 2012 at 2:11 PM
    ImplicitlyAlberta
    David
    edmonton
    Good to know. Ive been changing my oil between 35- 5000km since I got my truck. Or depending on my driving. I will be keepng an eye on it for sure at least until I can get used to it. thanks
