head lamp shine direction?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtaco, May 9, 2011.
  1. May 9, 2011 at 9:49 PM
    jtaco
    jtaco [OP] Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    on my headlights on my 07 tacoma trd, my drivers side bulb shines up and my passenger side shines down to the ground. are they suppose to shine in different directions?
  2. May 9, 2011 at 9:57 PM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    x2
  3. May 9, 2011 at 10:07 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Yes they are supposed to be oriented that way - it is a feature to alert aircraft and to your approaching truck thereby averting possible tragedies when choosing a roadway to perform and emergency landing on at night. I have gone further and reoriented both of mine upwards in hopes of confusing migrating birds.
    OK, of course I'm not being serious here. Just some good fun... to be helpful, it is a simple alignment thing and easy to adjust yourself. There is a screw that adjusts the vertical angle. Here is a how to
  4. May 9, 2011 at 11:25 PM
    jtaco
    mine are socket bolts ,there is no where to put a screw driver, i adjusted and got them even by socketing back and forth using bottom alignment thingy,and watching them shine on wall, but being even now , one is still brighter then the other
  5. May 9, 2011 at 11:48 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    Make sure both bulbs are in there correct. Maybe the clip came undone or broke.
  6. May 9, 2011 at 11:55 PM
    jtaco
    i did find a link in here, says get a piece of paper and draw lines and what not, i went left to rt and up and down and can not get it to equal brightness as the other one.could one bulb be brighter then the other? maybe i need a new bulb, yea that is what i found wolfpack, thanks though for helpin me search, at least they are shining in same direction now and not one cok eyed out in the woods while drivin down the road but did let me see deer really well on edges of the forest. lol
  7. May 10, 2011 at 1:58 AM
    jtaco
    thanks guys!
  8. May 10, 2011 at 10:45 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    X2. Mine were aimed all crazy; the bulbs were not seated correctly with the clips.
  9. May 10, 2011 at 10:49 PM
    jtaco
    ok clip doesnt even work good, i bought aftermarket blacked out lamps, and they are just shoddy
  10. May 11, 2011 at 4:57 PM
    mountainwolfpup
    Vancouver, WA
    OK, that explains it - I was assuming stock OME parts.
  11. May 12, 2011 at 2:36 PM
    mountainwolfpup
    Vancouver, WA
    Duh. Ouch! What was I thinking - why is OME always on my mind? It's a curse or something.
    Good catch wolfpack
  12. May 12, 2011 at 5:27 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    I found some headlight adjusting procedure that says to vigorously apply 100 grit to the lens. How is that supposed to fix the headlight focus and aiming? That doesn't sound right...
  13. May 12, 2011 at 8:37 PM
    mountainwolfpup
    Vancouver, WA
    I think the "wet sanding" is for restoration of headlights that have become dull from minor scratches and sun a=damage, etc. I can bet my truck that it is not a meaningful approach to headlight alignment.
    What you need to do is apply a liberal coating of "OME" to the headlights. Reapply as necessary. The 885 is the best. May need to replace you UCA to get proper alignment? But hey, oyur lights will be great.
    OK, all kidding aside. It is just a screw you turn. If you can't do that then you should take it to the dealer. They love that sort of work. Quick money!
  14. May 12, 2011 at 8:41 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    I need to get mine adjusted.
  15. May 12, 2011 at 8:49 PM
    mountainwolfpup
    Vancouver, WA
    Any shop can do that for you.
    But all you need is a screwdriver. I drive to a shopping center parking lot at night and drive in facing a building strait on in a level parking area and do the deed.
    10 minute job.
